Old 11-02-2009, 09:33 AM   #1 (permalink)
Code Reader Recommendations?
Hi All,
This weekend, my "Service Engine Soon" light came on. I would like to find out what is going on, so I need to pick up a code reader.
Does anyone have a recommendation for what I should consider buying?
Thanks!
Jason
jasonp is offline
Old 11-02-2009, 10:17 AM   #2 (permalink)
chuckster57's Avatar
Don't bother going to the auto parts store for this one. You will need a scannner/reader that will have the ability to retrieve the DTC's from a PSD. The overwhelming choice here is AutoEnginuity. It is a software program that you load onto a laptop and it has a cord that plugs into the OBDII port. It will allow you to retrieve DTC's and a whole lot more. Well worth the $$.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually Photos
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
chuckster57 is online now
