Old 01-09-2005, 12:47 PM   #1 (permalink)
Cold Weather Starting Problems
I have a 2000 Ford Excursion 7.3 diesel 4x4 and I am receiving no power across the manifold heater solenoid with the ignition on (solenoid #1828565C1). The “check engine” light stays on. I can’t find a replacement solenoid at the Ford dealer. I replaced it with MR99 GP Sorensen from SMP Corp. Please advise. Thanks.
jagusti is offline
Old 01-10-2005, 03:15 PM   #2 (permalink)
Re: Cold Weather Starting Problems
I'm not sure that the IAH should be powered on start-up. Pull the codes from the computer, as the glow plug system has diagnostics. Dale
7.3 Excursion, it's a diesel thing.
Chicago MOB member.
shamuex2000 is offline
Old 01-10-2005, 07:21 PM   #3 (permalink)
It doesen't work that way. This is out of the Ford PCED shop manual
To reduce white smoke during long idle periods at low ambient temperatures, the PCM will activate the intake air heater. Specific conditions must be present before the heater is activated:
ambient temperature must be below 0°C (32°F)
engine oil temperature (EOT) must be below 55°C (131°F)
vehicle power (IVPWR) must be between 11.8 and 15.0 volts
parking brake must be applied on manual transmission vehicles
the transmission must be in PARK or NEUTRAL on automatic transmission vehicles
glow plugs must be off
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 01-18-2005, 02:51 AM   #4 (permalink)
crumm's Avatar
My Photos: (38)
There is the key. When you turn on the key the glow plugs turn on. The intake air heater is not on when the glow plugs are for the simple reason that the batteries can only supply so much power.
You say your "check engine light" stays on. Do you mean your "wait to start light" stays on when you turn the key on or is it your "check engine light"?
1996 F-350, 4X4, XLT, C/C, 5sp, 4.10, Chip, DPPI Down Pipe, Tymar intake, Shackle reversal, 315 Toyo MT's, 67,000 miles.
crumm is offline
» Sponsor Links
»Garage Storage and Cabinets
