Old 01-16-2006, 05:38 PM   #1 (permalink)
Connecting gauge senders thru firewall
I recently purchased a 3-gauge pod that goes underneath the cubby storage area. It looks great and access to the fuse panel from this location couldn't be easier. So... at this point I have high hopes for a smooth install but the thing I can't quite see yet is how to get my sender unit wires through the firewall. Is there a spot people normally use for this? I searched the term firewall and saw that there are 3 12V wires that go through the firewall that people use for DRL, but I need to get a sender unit wire through there. Well, actually I need to get 3 sender units through, some other wires to control a relay under the hood. TIA.
Charlie
2000 Ex Limited running wvo on two tank/checkvalve system (modeled after fordnut but not as fancy); Bilstiens; Coolant filter.
Charlie_M is offline
Old 01-16-2006, 06:18 PM   #2 (permalink)
Re: Connecting gauge senders thru firewall
Well, honestly I haven't done it yet, but I read that most people are running it out where the wiring harness goes through the firewall. There should be enough space to shove a couple of wires through.
2000 Ford Excursion, 7.3L PSD, 4X4 Limited, 110,000 miles:
Ford AIS Intake, FT Valve Body, 3-guage windshield mount, CCV Canister & Return Mod, OilGuard Single By-Pass Filter, Valvoline Extreme Duty Synthetic Oil, Coolant Filter, High Pressure Oil By-Pass, Air Intake Heater Delete, 203d T-Stat & Alum. Housing, E-350 Upper Hose, Bilstien Shocks, Goodyear Silent Armor AT 265/75/16,
To Be Continued...
I don't know much about diesels, yet, but I'm a Home Designer & Builder so if you have any questions about that I can help.
KahrBean is offline
Old 01-16-2006, 06:48 PM   #3 (permalink)
I just completed the install on my 2000 Ex a couple weeks ago. Going thru the Firewall was difficult as there is insulation on the outside and inside firewall. Trying to shove that boost tube thru the main harness is not a good option. The best way to run on the Ex is to take all connections for the Boost, Trans Temp, any Pyro thru the floor where the Transmision shift cable exits the cab. Just pull back the carpet on the driver side about 4 inches and you will see it. There is a rubber grommet on the floor that I reamed a small hole in and ran the lines then put some silicon around hole to reseal. Be careful to use nylon ties and keep everything away from the exhaust, but it works well and has a minimal disturbance on the stock appearance of the truck.
2000 Ex,4X4, Limited. HX crossover, Isspro 3 gauge cubby mount, CPS blue, AIS intake,
1999 F-250,CC,SB,4X4. AIS intake, BTM, HX crossover, DP-Tuner,Isspro 3 gauge cubby mount.
graybuck is offline
Old 01-16-2006, 07:34 PM   #4 (permalink)
I used the customer access wiring to wire my gauges. The only wire and hose that runs through the fire wall is for the pyrometer and boost gauge. I ran them through by the bracket that holds the master cylinder so I really didn't have to disturb the insulation much.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 01-16-2006, 07:37 PM   #5 (permalink)
Will do. Thanks!
Charlie
Old 01-16-2006, 08:31 PM   #6 (permalink)
Where did you purchase this type of gauge/mount package?
2002 Black 7.3 PSD Excursion 4X4 Limited. Magnefine Tranny filter (3/8), ProComp Steering Stabilizer (222-560), Hellwig rear sway bar, Fumoto (F111N), dieselsite coolant filter, V Code front spring (6/3/2007).
http://community.webshots.com/photo/...84805295YUbTxL
1995 Jaguar XJ12
2006 Kawasaki EX250 baby Ninja
blackx is offline
Old 01-16-2006, 08:39 PM   #7 (permalink)
william_04_X's Avatar
i ran my air line(for bags) and attitude cable through large rubber grommet behind e-brake...
04 EB X w/03 PSD
Southern Nevada Power Strokes.Org
william_04_X is offline
Old 01-16-2006, 08:52 PM   #8 (permalink)
FamilyRide's Avatar
There's a triagnle shaped plastic plug you can drill through (I used a 3/4" hole saw) then fill it once the wires, tubes etc. are through. Although I also used the trans cable through the floor trick for something; maybe the tranny temp and maybe the thermorcouple lead.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 01-17-2006, 12:17 AM   #9 (permalink)
06Clone's Avatar
My Photos: (5)
Where is that triangle plug located? I am trying to find a route for my new behind the grill fog lights switch. Also, any suggestion on switch location?
Do you or anyone elso know what the four rubber capped wires are for under the hood, right above the fuse box? They just hang there.
06Clone is offline
Old 01-17-2006, 09:07 AM   #10 (permalink)
Same here. I believe that plug is where the Clutch linkage would go through the firewall for a manual transmission truck. Really easy to use since it just "pops" off. To locate it start at the brake master cylinder and look below and to the left I believe. (been awhile since my head was in there). On my truck it was shaped like a diamond I think.
Regards,
Dave
Have a good one,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 01-17-2006, 09:09 AM   #11 (permalink)
Four wires are customer courtesy wires to use as you wish. They go out to the engine area in front of the drive side up near the crowl area.
The black triangle thing is tucked way up under the dash behind the emergency brake pedal, hard to get to but convenient to pass wires through after drilling the right sized hole for such purposes(it pulls out for drilling).
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 01-17-2006, 09:48 AM   #12 (permalink)
I used this on my 02 and will again. It is for the clutch push rod,
with the auto is is just a plug you can remove work on gromit or what ever and replace, on my 02 there was also a perfed cutout in the insulattion around it.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 01-17-2006, 10:10 AM   #13 (permalink)
06Clone's Avatar
My Photos: (5)
THanks for the info. [img]/ubbthreads/images/graemlins/vulnerable.gif[/img] Can you tell me where the four customer courtesy wires are on the inside?
06Clone is offline
Old 01-17-2006, 11:37 PM   #14 (permalink)
www.egauges.com
Their website is very user friendly - just select mounting options by vehicle, and go under ford trucks and you'll see various options. I liked the one under the cubby area; some prefer the a-pillar mounts. There are other options also.
Good Luck.
Charlie
Old 01-18-2006, 08:37 AM   #15 (permalink)
Mine were under the dash just right of the steering column maybe a foot and back about the same. Should be four wires with black end boots. You may have to look and dig a little bit but they are there. They then go to under the hood drivers side near the top were the wire loom is.
Paul B
2000 Honda CRV EX
PIC'S
