Old 02-22-2007, 09:37 PM   #1 (permalink)
Converting glowplug module to relay as trucks
i have 2000 X, and i want to change the glow plug module to a relay system like the 250 and 350s
has some one done this or know how to?
thanks
2000 X with 4"straight pipes, Tymar style intake, guages AND Saving for the Kelderman Airride(dont tell the wife)
mybimota is offline
Old 02-22-2007, 10:05 PM   #2 (permalink)
Re: Converting glowplug module to relay as trucks
Why The glow plug controller module is a better more reliable system. [img]/ubbthreads/images/graemlins/confused.gif[/img]
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 02-22-2007, 10:44 PM   #3 (permalink)
?? What are you talking about? I did not know there was a difference between the two.
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
Old 02-23-2007, 04:12 PM   #4 (permalink)
FordMastertech:
i think my module is dead cause my 2,4,6,8 glow plugs are dead.
i am going to check the connector and read the voltage to make sure its the module.
I just like having the relay alot simplar and cheap to replace from international. my module here in canada they want 350 bucks.
also i know the 6 leakers are using these module part #1828565c1
mmsafd:
our X have modules that comunicate with the pcm letting us know each glowplug is working or not. i thinks its californa emission thing.
the 6L use this module thing also.
heres a pic of the two. (left side is trucks and right is our X's)
<pic of both relays
thanks
mybimota is offline
Old 02-24-2007, 12:47 AM   #5 (permalink)
mybimota-Unfortunatlly for me your pic did not work.
Thanks for the info. I knew the EX had Cali emissions and have seen some different stuff under the hood. If this module senses a bad glow plug does it set the SES light or anything? JC.
99.5 F250 4x4
2000 Excursion 4x4
mmsafd is offline
Old 02-24-2007, 03:08 AM   #6 (permalink)
I just have the relay on mine, no controller
2000 Black Excursion,PFC 2 piece rotors,Tipton tuned,BDP stage 2 singles, BDP H2E, AFE stage 2, Spearco 7.3, ITP Reg. return fuel system, Evans, BTS, 186,000 miles....And still goin' strong! Thanks Beansdieselperformance.com and Puredieselpower.com for all your help
BBBxcursion is offline
Old 02-24-2007, 09:39 AM   #7 (permalink)
[/ QUOTE ] The early 00 Excursions did come with a relay instead of the controller. I am not sure of the switch over date but both systems monitor the glow plugs and will put the check engine light on if it sees a issue. I still feel the solid state controller is a better system as very few go bad, even on the 6.0s. I can guarantee all the glow plug relays will go bad and sometimes several of them in the life of a truck. Relays are cheaper but not better. The relay for a X is not really that inexpensive for the correct one and a NAPA GPR109 is not the correct one and usually dies pretty quickly on these PSDs.
FMT
Excursion Pics
» Sponsor Links
»Garage Storage and Cabinets
