Old 07-18-2004, 04:34 PM   #1 (permalink)
Coolant Leak - HELP
I have a coolant leak it appears just below the water pump right from the center of the engine, but it does not seem to be coming from the pump itself, but below. The truck is not over heating.
Can anyone guess what the source is?
Thanks.
Kevin
2000 Excursion, Limited, 4X4, PSD, Airaid Intake System, Bilstein Shocks, Hellwig rear Stabilizer, Pro-comp steering stabilizer and the Diablo Chip.....
FireTruck is offline
Old 07-18-2004, 07:58 PM   #2 (permalink)
rock_doctor's Avatar
Re: Coolant Leak - HELP
This is kind of a hard question to answer...with out having ESP.... You need to get in there with a light and see what is wet. It is either coming from the water pump gasket (water pump to timing gear housing) or out the weep hole in the top of the water pump input shaft housing. Of course assuming it is not leaking down from the thermostat housing... Take a better look and see if you can isolate it. There are just too many parts that come into contact with the coolant on the front of the engine.
good luck,
mark
2005 Excursion w/ 6.0L PSD
rock_doctor is offline
Old 07-18-2004, 09:27 PM   #3 (permalink)
I guess I can look better, but it look like it was coming between the timing cover and the water pump, but I could not see the exact source. Do they attach? I was under the impression that the water pump bottom bolt was about two inches from the timing cover.
Bet still the water pump? I will know tomorrow.
I appreciate your response.
Kevin
Old 07-19-2004, 05:55 PM   #4 (permalink)
I would too as hard these engines are on water pumps. Hope all goes well for you.
John [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 07-20-2004, 08:40 AM   #5 (permalink)
Just had my waterpump replaced on my 00 X, I had the same problem. It should fall under warranty if you are under 100K. I hope so, I think that it was several hundred dollars in TX to repair it. Don't go to Rockwall Ford took them 3 times to get it right.
Dzl_X_4x4
DZL_X_4x4
2000 Excursion Ltd PSD 4X4, ProComp 6" lift, (6) MX-6 Adj. shocks, dual shock hoops, ProComp traction bars, dual shock steering stabilizer, 35x12.5x17 ProComp Xterrains, 17x10 Welds Stonecrushers, SCMT 1705, AFE StageII PG-7, Hellwig Sway Bar, TV/VHS/PS2/DVD, Billet Grill, Chrome Brush Guard, ProComp Lights
dzl_x_4x4 is offline
Old 07-20-2004, 10:40 AM   #6 (permalink)
FJF
FJF's Avatar
I went through the same problems,I saw a little antifreeze under the water pump and on the pulleys (no doubt a water pump).I was going to change it myself I didn't want Ford touching it but sence I also had a oil leak all coverd by waranty I sent it in. Got it back Ford said it was the thermastat.I found that inpossible.Well by the time I got home it was leaking again. Went back and and gave them a ear full and said this time change the waterpump this time. It's a miracle they changed the waterpump and the leak stopped.The pump only had 56K on it. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2000 Excursion Limited 4X4, 5" Hypermax Exhaust,TS 4 Bank chip(D/P Tuner- stock,Tow,Econo,Race) A Pillar DiPricol Gauges (white face)Hellwig swaybar,Skyjacker stablizer,AFe Stage2, Slotted&cross drilled rotors,BB Turbo,Pioneer AVIC D2 <font color="RED"> *** ALL GAVE SOME, SOME GAVE ALL(FDNY 9/11/01)***
FJF is offline
Old 07-21-2004, 06:59 PM   #7 (permalink)
84K on mine when it went out. Pretty normal. It should definately be covered if under 100K.
While your there...
Get the upper, lower hoses, and thermostat housing replaced(they may charge for those),
The intercooler blue boot should be oily(they should cover that),
See if they'll throw in a cam position sensor(keep your old one as a spare in the "rear glove box").
My 2 cents
[img]/ubbthreads/images/graemlins/cool.gif[/img]
Ryan
KwikStix
2000 PSD Excursion Limited 2WD, 150+K miles, Chestnut, Medium Parchment Leather, Limited Slip 3:73, BTS Tranny, Diesel Innovations 4-Way (Valet-Tow-Crazy-Stupid Fast), AutoMeter Carbon Fiber Gauges(boost,pyro,tranny), AFE Stage 1 intake, Magnaflow 4" down to 5" Stainless tip, Whicked Wheel, HX Crossover, KYB's, Hellwig rear sway, Michelin 285's
kwikstix is offline
Old 07-21-2004, 10:11 PM   #8 (permalink)
MotionMan's Avatar
Leaking out the weep hole is your sign it is time for a new one. The ceramic seal on the impeller wears and this is where it leaks from. It is a sign, make sure you heed this warning [img]/ubbthreads/images/graemlins/cool.gif[/img]
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 07-24-2004, 05:06 AM   #9 (permalink)
You were all correct. It was the water pump. It took them a day of pressure checking and running die to determine the problem. Dealer acted as if it is unusual for the water pumps to malfunction.
Is a coolant filter necessary? I just flushed the coolant at 60K and the pump still malfunctioned at 75K.
Old 07-24-2004, 09:04 AM   #10 (permalink)
"...unusual for a pump to malfuncton."
I just put the third one in our Ex. First went out at 45,000 miles. The second at 84,000.
'00 Excursion LTD, PSD, Oxford White, Parchment Int, 6CD, 2nd Row Cap't chairs, Badges
'01 Sport Trac, Oxford White, Graphite Leather, V6 gasser, 4.10, loaded, no stinkin' badges
rfalcone is offline
Old 07-25-2004, 07:52 AM   #11 (permalink)
My Photos: (16)
I flushed out the coolant system using the method given on this board. This included removing the rear plugs on the block etc. I flushed the system 4 times. Nice and clean no crud. I installed a coolant filter thinking that for a couple of bucks why not. I thought that I might get a little bit of stuff from the FW-16. After a couple of mths I decided that I would change the filter and take the old one apart. To my surprise it had casting sand in it.
So is a filter nesessary...yes.
DUNC
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
DUNC is offline
» Sponsor Links
»Garage Storage and Cabinets
