crankcase bypass removal - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 07-09-2007, 06:04 PM   #1 (permalink)
mike650's Avatar
Thinking of removing my crankcase bypass system and going back to OEM. I pulled the old parts from the shed and I may have put the old screws onto the wrong side of the old sleeve. If I position the sleeve into the mount the way I think it should be, the little tower, inside the sleeve where the crank case exhaust fumes enter, point towards the airbox and not the turbo. Is this correct? Kind of looks like the cool air would enter the crankcase as well as the turbo. Sorry, I not a mechanic and at times I'm loaded with dumb questions? [img]/ubbthreads/images/graemlins/crazy.gif[/img] There is what looks like an arrow, with a part number stamped on it, on the side of the sleeve that may be an indicator as to which what the air is supposed to flow.
Thanks!
-Mike
2002 Excursion ~ Limited Ultimate ~ 7.3L PSD ~ 4x4
Mineral Gray, Limited Premier Group & Monochrome Package, two tone leather interior (pre-Eddie Bauer), TTT Mirrors, 3.73 Limited Slip, F250 Lariat wheels.
Kentucky Born: 4/9/2002
Improvements: 2002 PSD Badges, and lot's more!!
mike650 is offline
Old 07-09-2007, 06:11 PM   #2 (permalink)
fordmastertech's Avatar
Re: crankcase bypass removal
Yes that is the way it goes.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 07-10-2007, 12:43 AM   #3 (permalink)
mike650's Avatar
Thank you sir!!
-Mike
mike650 is offline
