where are the customer access wires in the dash of an 02? what about the customer accessory wire that comes off of fuse 29? what color wire is non dimmed of the light switch?
thanks
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
Look under the dash to the right of the steering column. There should be a wire tagged for customer use or something like that. At least that is what I found on my 01 EX.
On both my '02 and'03 F-350 the keyed hot was in the area between the accel pedal and the heater duct, up high, white with black stripe and wrapped together with some other wires and labeled. The customer access wires that pass through the firewall were in the area of the emergency brake pedal, up high. I'm thinking that the Ex should be the same.
I can't help on the non-dimmed light switch wire.
I took the cluster out, the stereo out and half the dash apart I still can't find them are they in pigtail that could have been removed
The customer access wires went through the firewall with a large bundle of wires. I found the ends when I had the headlight switch out. They were in that area. They are red, blue, white, & black with a heat shrink on the end of each one. The switched hot was poking out of a bundle approx the size of your little finger with a little black heat shrink on the end and labeled "see body builders manual" or something like that. It's 18 gauge white with a light blue stripe not a black stripe.
I'm sorry I don't have a digital camera to post some snaps. I looked for them for a while also.
Look right with the wires going down to the OBDII test port under the dash, it runs right with that harness but doesn't go all the way down to the plug.
2002 Limited Ultimate Premier No Boundries Excursion 7.3l 4X4 all black with every option Ford could come up with. X-code F550 front springs, full size leaf added in the rear, 265 Bridgestone Dueler Revos, Edge Juice with Attitude, Edge Evolution, Autometer sport comp guages, IDM mod, Walker BTM muffler, SPDiesel exhaust brake with t/c lock up control, Catch-All floor mats.
