Lookin to add some extra cooling and fluid to my 01' X. Anybody have a good idea for a new pan, and were to get it. Thanks
Nick
01' Powerstroke Excursion, 4x4, DR 9" lift, 39.5 x 13.50" IROK radials on 16x10 Eagle Alloys, Autometer ProComp Guages mounted on dash pyro, boost, tranny, CB radio custom install in dash were cubby hole under 4x4 select switch used to be, DP Tuner chip 60, 80, 120, and High Idle(1200 RPM), DIY gears and lockers, Lockright up front, Detroit locker in the rear, 4.30 gears, Dynatrac front hubs (REAL HUBS), BTS Tranny, 4"dp to 5" exhaust dumps infront of rear pass. tire NO MUFFLER, Tymar intake,WW, AIH Delete
Nick
[/ QUOTE ] A transmission pan that larger will not cool the transmission, it will just take it a little longer to get up to the same temp you were running before.
I would suggest a cooler from a 6.0 or one off a V10. Both of these coolers are larger than what you are running at this time.
I also don't think the Mag-Hytec pan will fit on the Excursions due to cross member interference. I have heard the PML ones will work.
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
Nick
I would suggest a cooler from a 6.0 or one off a V10. Both of these coolers are larger than what you are running at this time..
FMT
While Mark Craig might disagree, I agree with you and so does my tranny guy [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
Also if you heat up that much more fluid it will take that much longer to get it back down to temp and if you have the OTW cooler in the radiator any "warming" in cold weather will take just that much longer. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Larry
__________________ <font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
