Old 07-10-2008, 05:55 PM   #1 (permalink)
Did the 6.0 motor ever get sorted out? I had a 7.3 but was hoping to "move up".
Am I setting myself up for trouble with a 6.0?
BigCat is offline
Old 07-10-2008, 09:38 PM   #2 (permalink)
I wouldn't chance a great running 7.3 on a roll of the dice. I've heard of too many people who wished they had not gotten rid of their 7.3 for a 6.0. It's hit or miss with them. My best buddy has an 03 and not one problem but also know a guy who has a 05 and the things been in the shop more times than not.
The 7.3 makes less power but is argueably one of the most reliable diesel engines ever produced.
I'd keep it personally.
2001 PSD Excursion 4x4 Limited 7" Superlift Softride lift, 315/75/16 Toyo M/T, Fox shocks, Hellwig rear sway-bar, Air-lift airbags, Autometer Ultra Lite tranny/pyro gauges, DP tuner, Swamps 175/146 single shots, Wicked Wheel, AFE Progard 7, 4" turbo-back exhaust, John Woods tranny w/ 6.0 billet TC, and T/C lock-up switch, Tru-Cool Max tranny cooler. Topped off by Jody's famous tunes.
Audio System: Eclipse 8053 head unit, Arc Audio XXK4050 amp, Arc Audio XXK1500 amp, 6" Morel Integra, JL12w6v2.
WannabePSD is offline
Old 07-10-2008, 10:34 PM   #3 (permalink)
GOT14U's Avatar
i had a 04 6.0 brand new. started having all the infamis problems with it. so i traded it in for a duramax truck. and looked for a 02 excursion with the 7.3
owning a 6.0 almost made me quit buying products. $47,000 dollars and the thing didn't make it to 40,000 miles....keep your 7.3
02 EXCURSION (4" EXHUAST,DI CHIP, FS2500 FILTER, 4 GAUGE PILLAR, AUTOMETER PHANTOMSII,ALPINE DECK,BOSTON ACOUSTIC 12",1000 WATT AMP,COOLANT FILTER SYSTEM,TRANNY BYPASS FILTER,AMSOIL FLUIDS ALL AROUND, V10 TRANNY COOLER, CAI, 200AMP ALTERNATOR, DIESELSITE BILLET THERM HOUSING, DIESELSITE OVER BOOST RELEASE VALVE, BTS VALVE BODY)and still more coming
04.5 GMC DURAMAX.....i know...i know !!
07 28' WEEKEND WARRIOR(12,385 lbs gvwr)
07 DUCKS UNLIMITED RHINO
5 KIDS
1 WIFE
3 DOGS
THANKS TO SHAWN @ RAGIN FOR ALL HIS ADVICE AND HELP!! U NEED SOMETHIN GIVE THIS MAN A CALL.(NO BS, AND NO UP SALES)
GOT14U is offline
Old 07-11-2008, 04:09 PM   #4 (permalink)
I have an early 04 with the 6.0, bought it used with 64k on it, didn't take long to lose an EGR cooler and blow the head gaskets. Got it all fixed under warranty, added ARP studs at the same time. Also modified the passenger side up-pipe to make sure all of the exhaust flow goes where it belongs, i.e. into the turbo. That helps with the coolant puking problem. Seems to be ok ever since, now at 108k, although it did get hot and puke a little coolant on a brutal climb recently. Tranny is acting a little strange, especially if I'm running a hot tune, wouldn't be surprised if it needs a rebuild sooner or later. All in all, I'm not sure I'd buy the 6.0 if I had it do do over, because I still don't really trust it. I probably could have gotten a slightly older truck in similar condition for around $10k less, and used the money to build a beefy tranny and get the 7.3 running strong. That would likely be a more reliable and satisfying combo.
ps: Also forgot to mention that the mileage on my 6.0 stinks. I'm not a leadfoot, but best I can do around town is about 14, highway cruising unloaded @65-70 about 16, maybe 17 if I keep it strictly down to 65. Friend I know with the 7.3 does much better, and his is taller with bigger tires.
04 X/4wd/6.0PoSD/EB/XM
3" lift/Fox Shox/Centerline Grizzlys/305-55-20 Nittos
MBRP&Banks exhaust/AFE Stage II/Spearco CAC/intake elbow
Innovative tune/ARP studs/coolant filter/Performance radiator
Upgraded regulator & high flow banjos
Coolant bypass & up-pipe
http://photos.thedieselstop.com/data...Ex_reduced.JPG
28magicat is offline
Old 07-12-2008, 11:41 AM   #5 (permalink)
I would rather have either my '00 or my '02 with the 7.3 back, than my current '05 with the 6.0...
ABoater is offline
Old 07-14-2008, 09:24 PM   #6 (permalink)
I have an 2005 , 6.0 and havent had a bit of trouble . But I'm sure "now" I will after running my mouth about it . 67k miles on it .
2005 Eddie Bauer . Green and Tan . Stock . Bought it in FEB with 33000 on it . 4 inch lift , Pro Comp Chip , Dual Steering Stablizer , 33 AT BFG'S on 16 inch Pro Comp Wheels .
2000 ARGO , 8 WHEELER
thogue is offline
Old 07-15-2008, 01:02 AM   #7 (permalink)
I'm the same -- daily driver, rarely worked hard, but 80,000km and no issues.
2005 Eddie Bauer X -- all stock.
Wren is offline
Old 07-15-2008, 08:46 AM   #8 (permalink)
My wifes X has 190K miles. The motor and tranny have never been touched. Two CPS's, alternator, batteries, and gpr.
There is a killer deal on a local 00 X PSD, 265K miles all freeway, $8,600. Sort of makes me think about buying another. The poor guys wife is forcing the sale
If something happened to my wifes X we would start looking for the lowest mileage 00 X to replace it. A low mileage 03 7.3 would be my second choice but like the idea of forged rods especialy considering the miles we would put on it and what it would tow.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 07-15-2008, 02:18 PM   #9 (permalink)
Same here. I just turned 67,000 miles. Except for a CPS and an altenator, no problems. Except for an accident or someone stealing it, it will not leave me for a long time.
John
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 07-15-2008, 10:44 PM   #10 (permalink)
I should add other than the little stuff.
Broken into three seperate times, passenger front side window broke twice. Last time it was my wifes fault as she didn't lock or arm the vehicle with the alarm. Guess to look on the bright side it saved me making a third glass claim in three years! Hit while parked once, clean get away just left a small dent in the driver side door.
And it eats rotors. Tried the slotted and drilled ones and now they are making noise and shuttering.
About six months ago on autrader saw some 16-30K mile 00 X PSD's. You can still find nice low mileage 03 7.3's.
86GLHS is offline
Old 07-16-2008, 12:25 AM   #11 (permalink)
clamgulch's Avatar
6.0 heads are junk- almost all of them that are brought it for rebuild are cracked between the valves. That may or may not cause anyone concern- they run ok that way, and they will run a long time- just plan on buying new heads at rebuild time.
Personally, I'd advise you to keep the 7.3 and don't fiddle with it. They are prone to expensive breakage when thrashed or modded too much.
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 07-16-2008, 06:17 PM   #12 (permalink)
william_04_X's Avatar
How would you know clam?.....
william_04_X is offline
Old 07-16-2008, 06:34 PM   #13 (permalink)
clamgulch's Avatar
Not counting the $50,000 I've dumped into drive train rebuilds and swaps, I wouldn't. I'm just guessin'. Wanna help install a firewall...and I don't mean on a router, I mean in my excursion!
Old 07-17-2008, 11:09 PM   #14 (permalink)
Is it a safe assumption that a Ford tech would inspect for this while doing a head gasket replacement? How about a valve job or inspection? I forgot to ask when they did my gaskets last year and was curious. Also, if cracked, are there any symptoms or ill-effects that one should look for? Hoping to keep my 6.0 healthy for a very long time so need to get educated!
Thanks,
-Brian
Old 09-22-2008, 12:31 PM   #15 (permalink)
Thumbs down Cracked Heads - Both on exhaust valve 2nd cylinder
I have a F350 Harley Davidson that I use to pull my race trailer. I noticed some coolant in the engine compartment last year but shrugged it off as just a possible overheating. This summer my son came back from Quebec and said the vehicle was overheating so when he got back we took it in to the Ford Dealer. Sure enough both heads were cracked in the exhaust valve seat on the 2nd cylinder in each head. Ford is not going to cover the warranty because of the existance of an aftermarket product on the truck. They can not prove it was caused by the Banks kit. They denied warranty solely on the fact that there was an aftermarket chip on the vehicle.
To this point no one at Ford can give me a technical reason to justify how they can say it was caused by the Banks kit.
DON'T BUY A FORD with this engine, it has problems see their TSB 06-231-2 for details. And don't put a chip in it. It is going to take a long time to make up for the $10,000 repair bill and the $3,000 for the Banks kit.
Keep it stock and make Ford warranty your truck.
2006hdf35060 is offline
