Did the 6.0 motor ever get sorted out? I had a 7.3 but was hoping to "move up". - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 09-22-2008, 04:01 PM   #16 (permalink)
aklim's Avatar
Originally Posted by 2006hdf35060 View Post
They denied warranty solely on the fact that there was an aftermarket chip on the vehicle.
To this point no one at Ford can give me a technical reason to justify how they can say it was caused by the Banks kit.
DON'T BUY A FORD with this engine, it has problems see their TSB 06-231-2 for details. And don't put a chip in it. It is going to take a long time to make up for the $10,000 repair bill and the $3,000 for the Banks kit.
Keep it stock and make Ford warranty your truck.
Did you try and hide it?
Did you threaten them with a suit or something?
$3000 for the Banks kit? What does it do?
Problem is stock sucks.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 09-22-2008, 08:37 PM   #17 (permalink)
Well I cant say anything bad about the 6.0
I just had mine in two weeks ago for some trans problems and it did have a code for the engine, turned out to be glow plug #8 and they replace the injection control module and the glow plug module not sure why they did both modules then fixed the problem the glow plug, How Typical!
Bad news is they replaced the front seal on the trans they said it was leaking now it is leaving spot of SP where ever you park it so back today for more work on the TS trans.
I am at 99,025 with 100K ESP but I did get the 200K engine warranty at a way reduced cost due to my agravation, Ford did it not the dealer.
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 09-22-2008, 09:08 PM   #18 (permalink)
Racer-X's Avatar
There are a variety of issues that have plagued the 6.0.
Ford and Navistar had a long and heated battle over some of the issues.
One thing that concerns me is that some trucks sat for over 2 years near the Oakville truck plant without ever being started once. And I mean lots and lots of trucks. This killed a lot of them.
There were some sort of injector issues as well.
My buddy is a heavy diesel mechanic. He said to stay away from the 03-04 trucks, but by 05 most of the issues were sorted.
He drives a 2001 7.3. I bought a 2000 7.3 based on his advice.
By now I would hope the previous owners of the trucks in all years have suffered the headaches, and that Ford has suffered the warranty issues.
Racer-X is offline
Old 09-23-2008, 10:36 PM   #19 (permalink)
MotionMan's Avatar
My X has 186,000 on a 12/02 built 7.3....the last one I bet because it has not even burped yet, all it had was a leaky O ring on the HPOP, not a big deal...oh and a CPS...which I have carried an extra for 100,000 and it still works...buy International parts for it too....so the 7.3 has made a joke of every motor since, it weighs like a diesel, sounds like a diesel and runs like a diesel....not a glorified mini van diesel that is meant for soccer moms so they can order thru the drive thru without shutting it off...try that in a 7.3......or better an 02 Cummins... Heck I don't even have a catalytic converter, no one believes it did not come with one....but it didn't because I have put every inch of those 186,000 on myself.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 10-02-2008, 12:28 PM   #20 (permalink)
06Clone's Avatar
My Photos: (5)
Originally Posted by 86GLHS View Post
...And it eats rotors. Tried the slotted and drilled ones and now they are making noise and shuttering...
If you are burning up rotors it is the module under the brake pedal. Push it hard: push it when starting, push it several times while stopped in drive - if it ever once pushes back, it needs to be replaced immediately. I know this $1600 later as my perfect condition 2000 X at 60k mi had all original everything until the brake module went. I cooked four rotors, four calipers and of course four sets of pads, and yellowed all four chrome wheels – gave me an excuse for the big brake upgrade. Got the wheels almost clean, but they will never be the same.
I told my friend not to buy the 05. He did anyway. Nineteen trips to the dealer later they allowed him to trade it in with $3K for a 08. So he made out. That comes to a $80 a month lease.
I like the HPCR 5.9 Cummins because it is the loudest and most efficient truck engine ever put on four wheels. So I get the "Firewall" joke.
06Clone is offline
Old 10-03-2008, 11:00 AM   #21 (permalink)
I think that ford was stupid for not finding a way to get the 7.3 to meet emissions. I bet it would be one hell of an engine with a modern common rail system on it and a vgt turbo.
NavyF350 is offline
Old 10-03-2008, 01:10 PM   #22 (permalink)
BlueMuleTrucking's Avatar
Send a message via AIM to BlueMuleTrucking
I agree 100%. The previous owner who bought a 6.4L F-450(job 1 apparently) for her farm, wishes she never sold me the truck. She offers more then I paid it to get it back and I say no. These day's I'm sorry to say that Ford's diesel offering isn't acceptable. If I needed to replace my truck would probably be a Dodge as much as I cringe when I say it.
Evan-
2003 Ford F-350 Crew Cab L/B/Dually XLT FX4 7.3L/Auto- Gooseneck Hitch Fifth Wheel Rails, Firestone Air Bags/ Toolbox
BlueMuleTrucking is offline
Old 10-03-2008, 02:22 PM   #23 (permalink)
CZDiesel's Avatar
My experience, for what its worth, with the 6.0 has been excellent. Right at 80,000K on a 2004 built in June of 04. It tows heavy all the time and I am nothing but happy with it. Maybe the exception but when I go to look for another work truck it WILL be a Ford SD with a 6.0. You can find them all over with low miles and the owners asking low $
CZDiesel is offline
Old 10-03-2008, 02:46 PM   #24 (permalink)
aklim's Avatar
I would think you are the exception as opposed to the rule
When I went looking for an Excursion or Truck (preferably excursion), I found all sorts of them all over. Whittle out the gas ones and there were fewer. Whittle out the 6.0 and the closest one I could get was 7 hrs away. The salesman was telling me how the 6.0 was better. YUet they had all kinds of 6.0s running around. No 7.3 at all. Why? He said the 7.3 owners were driving them into the ground. Yet in 06, I could get plenty of 6.0s that were 03, 04 or even 05.
Add that to the fact that the International shops like the 6.0 because they made more money on them than the 7.3 vehicles and the fact that it was repeated by Ford techs sold me on the 7.3. Also, the 6.0 was the one that had all kinds of disputes over warranty between Ford and International. Makes me wonder why. Not to mention that the 6.0 is only a few years old while the 7.3, which probably had it's problems has had them ironed out over the years.
aklim is offline
Old 10-03-2008, 03:41 PM   #25 (permalink)
Originally Posted by BigCat View Post
Am I setting myself up for trouble with a 6.0?
That depends on who you ask.
The 6.0 is a great little hotrod diesel powerplant.
You need to know it's heat limitations with a set of gauges.
I think the cooling system could be a bit larger but than again maybe I just live where it's too blasted hot anyway.
Again, each person will give you their opinion, based on their particular situation.
The best advice I can offer is for you to run an Oasis report on a given vin and find out for yourself if that unit had issues to beging with.
Stock is not an Option
2006 F-350, King Ranch FX4
35 x 11.50's,
Camper Pkg,
H.O. Alternator option
SCT Xcal2, Coolant filter
Hot Seat mod, 30% 3M Tint
Line-X liner, A.R.E. Top,
4" TB Magnaflow polished SS tip
5 Phantom II's, w/green LED's
Benchwrench is offline
Old 08-27-2009, 05:35 PM   #26 (permalink)
I haven't visited this board for some time and haven't posted since maybe '04. I ended up buying an '04 EX with the 6.0, built in November of '03. I would have bought a Burb if they had put the diesel in, but I didn't. Now it is 5 1/2 years later and I have 160,000 miles on my 2wd that is mainly used for just me for commuting and road trips for work. Other than a reprogram in early '04 the next time it goes in the dealer will be the FIRST! I have had about 75 cars and trucks and I have never has as reliable or dependible vehicle in my 64 years. It has the original shocks, I have put new rear pads and have the set waiting to put on the front, but why toss something that still works. I have logged every drop of fuel since I picked it up at the dealer and my average is 17.8 mpg. I do my own oil and filtere, about every 8-10,000 miles with Rotella Synthetic. I change the fuel filters about once a year (30,000 miles) but I do always go to stations that pump lot's of fuel so less water. I am a diesel fan and have a 7.3 in a 350 van that my wife tows a TT with to dog shows, but it's a lot noiser and not much easier on fuel, plus harder to work on in the van body. I wish our government would wake up and smell the diesel fumes and let more here in the states, but they are so deep in the pockets of big gas they never will.
I have to give Ford credit for JOB #1 and making one great vehicle.
Mine - '04 EX 6.0,4 x 2, Black LTD. Limited slip, T&T mirrors. Built 12/16/03 Add=ons: C-Betr's, Bug Screen, Rear Deflector, Floor Mats, XM Roady with PIE adaptor, Ultimat dash mat, Bel Detector, Hellwig 1 1/2" front and 1 1/4" rear bars, SS door edge guards, 22" Trico Teflon blades...160K! Avg MPG UP from 17.3 to 17.8 with new tires.
'03 E350 - 185k, 7.3ltr. Empty gets upper teens and towing a 30ft light trailer still gets 11.
"Ours" KW T2000, Series 60 (435 hp), 1,409k. Autoshift.
'02 Jetta and '08 smart - both gas.
RussBarnes is offline
Old 08-27-2009, 09:02 PM   #27 (permalink)
i bought a 6.0 liter and its been a great runner i get 17 mpg in town and about 19-20 on the highway
2004 f350 is offline
Old 08-27-2009, 09:22 PM   #28 (permalink)
MotionMan's Avatar
210,000 now, it has been almost a year since my last post. I don't drive to the UP anymore so the miles are not racking up like they used to. Still on the same serpentine belt. Same coolant, same everything except oil and trans fluid at 190,000. I am thinking about plugs, wires, cap and rotor and dist......oh yea, it doesn't have that crappy technology. Suck, squeeze, bang, blow....right past the tune up shop.
Old 08-27-2009, 11:26 PM   #29 (permalink)
I have a 2000 and pushing 376,000
Stock 2000 Excursion limited 4X4 7.3
wbutton is offline
Old 08-28-2009, 08:45 AM   #30 (permalink)
FMTRVT's Avatar
My Photos: (16)
And I'll jump in since there are so many who "know" without actually owning one.
My '03 noted in the signature is over 120k miles with no engine related faults ever and has never had a tuner on it with it's original May 2003 programming. Just changing the coolant without a coolant filter and the Autoenginuity shows oil and coolant temperature with spec of each other.
The only failure repairs have been 1 driveshaft carrier bearing (warranty), replacement of mirror turn signals (warranty), replacement of drivers seat belt (recall), 1 pinion oil seal, rear DIH brake replacement, resolder a resistor in the OH display circuit board, and 2 replacements of the OH garage door opener door. Driver's seat leather is cracking.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
