Old 09-23-2003, 06:56 PM   #1 (permalink)
Died, Start of a Problem?
Hello Guys,
Took the day off work to try and get caught up on spousal chores. Was pulling out of Sam's across a busy 4 lane and the X died in the middle of the turn. Was if someone pulled the coil wire off of a gas burner. No warnings, no missing, just a straight shut off. While sitting in the middle of the highway, watching traffic approach at 60mph, I hit the starter and she fired right up, put it in gear and hit safer waters. Pulled on off the road, started and restarted several times, nothing. Got on it on pretty hard on the way home, nothing. Changed the fuel filter about 4,000 miles ago @ 12,000. Is this the start of a CPS problem? Had a CPS go out a couple of years ago on our 550, but it gave me no warnings prior. Anything else I might be over looking? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Gary
2003 4X4 LTD Edition PSD Excursion Rancho 9000's, Hellwig swaybar, U Codes,; 2001 F550 4X4 XLT PSD Smeal 6T Pump Hoist; 2001 F250 CC 4X4 XLT PSD
anoxic is offline
Old 09-23-2003, 11:03 PM   #2 (permalink)
Re: Died, Start of a Problem?
Sure sounds like CPS to me. Have the dealer check to see if it threw a code (they sometimes don't). If it did, you're in luck, the dealer should replace it for you. If no code, you might buy a CPS unit from a navistar dealer and throw it in your glove box that next time it goes out on you in the middle of traffic, you can change it yourself and be done with it. I had this happen 3 times, first two times in traffic and no code, the third time it died on me @ 60mph and boy what fun. After that it would start and die every 10-20 ft. This time it threw a code and the dealer replaced it. Pain the A _ _ !
Dan
2001 XPSD limited 4x4 with SCMT and K&N, 3.5" down pipe, egt, trans temp gauges, Catch-All floor mats.Clear cornering lights Mobile video system w/ dual 6.8" screen overhead w/ DVD player and 5" front monitor. Yakima roof racks w/ Load Warrior.Rancho steering stabilizer Tekonsha Prodigy brake controller <font color="blue"> AIS Severe Duty </font>
99.5 F-350 CC-LB-DRW 4" exhaust,<font color="blue"> SCMT 1705 80hp mode </font> ;<font color="green"> SP DIESEL Stage I </font>;<font color="red"> WICKED WHEEL </font> ; autometer phantom gauge, bilstein HD shocks; berlin tonneau cover,tekonsha prodigy brake controller--
1993 Mazda Red Miata- 30mpg daily commuter..Jackson racing supercharger, HKS springs, Tokiko shocks, Toyo T1-R tires
rxbike is offline
Old 09-24-2003, 10:12 AM   #3 (permalink)
CHPMustang's Avatar
Yea the CAMP sensor is the biggest PIA part for the FORD dealer to get a code read from.
If you're operating an International badged truck like a 4300 and up and the CAMP sensor does the same thing,the International dealer replaces the sensor without even taking the time to code read it as they "Know" the problem first hand.
Now if only Ford Truck service would follow the same que [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] Not!!
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 09-24-2003, 11:09 AM   #4 (permalink)
This is what I'm afraid of, that it did not push out a code. Called the dealership this morning and got the same song and dance, "If it did not put out a code, then we can not replace....." This might be okay if we were not headed down to FL next week with an 85 year old grandmother and 2 little ones. For kicks I'm going to let the dealership look at it in the morning, and if they will not do the right thing, then head over to International and pick up 2.
Searched over on the 7.3 forum for those replacement instruction I saw awhile back, anybody know where they went?
anoxic is offline
Old 09-24-2003, 11:29 AM   #5 (permalink)
I've got a buddy who works at a local Ford dealer....he said all their techs are aware of the issues and replace the CMP whenever there is even a hint there could be a problem. He did the one in my '02 before I traded it in one day when I was down there to get the PCM upgraded.....he did the CMP cause I mentioned a weird missing I had a few weeks earlier.
Too bad you aren't close by or I'd tell you to go see him.
Whip
'02 Ford F-150 SuperCrew FX4
fabtech 6" suspension lift, pro-comp traction bars, nfab nerf-steps, weld racing typhoon, summit mud dawg 315/75R16, flowmaster 40 series dumped, clear eyes, euro clear corners, 100w off road lights, alumistinger draw bar, manik brush guard, flex-a-lite 270 electric monster fans
http://community.webshots.com/user/issanni
issanni is offline
Old 09-24-2003, 04:38 PM   #6 (permalink)
rock_doctor's Avatar
Ok I give what is the "CMP" sensor? Most owners carry an extra CPS sensor in their glove boxes along with a deep socket 10mm wrench to change it. I suggest you just get an extra sensor from International and carry it along or just change it and be done with it.
good luck,
mark
2005 Excursion w/ 6.0L PSD
rock_doctor is offline
Old 09-25-2003, 01:15 PM   #7 (permalink)
CHPMustang's Avatar
CAMP or CMP should be the same as "Cam Position Sensor" They're called CPS in the Ford camp and CAMP at the International service shops.
Old 09-26-2003, 08:38 AM   #8 (permalink)
Anoxic, from your description I'd agree with the other advice you have gotten on replacing the CPS. I just did this a couple of weeks ago. The truck would die at intersections or miss at high speed. After it died coming up to an intersection, I realized how dangerous this can get trying to steer and stop 7k lbs. of truck with no power!
Mine threw a code which I couldn't read, but since I would have had to pay the dealer $100 on warranty, I just got one at International and replaced it using the instructions from this group. Took about 5 minutes. And the best part is, no more missing or coasting into intersections with no power.
2000 F250 Lariat CrewCab, PSD, Auto, 3.73 LS, Towing Pkg, Aux. Idle Control, White/Gold
Bob Norris is offline
Old 09-26-2003, 08:44 AM   #9 (permalink)
Part number please. [img]/ubbthreads/images/graemlins/confused.gif[/img] I want to throw one in the glove box. [img]/ubbthreads/images/graemlins/grin.gif[/img]
Thnaks,
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
Old 09-26-2003, 03:37 PM   #10 (permalink)
Still have the part box at home so will check and post the number this evening.
Old 09-26-2003, 03:40 PM   #11 (permalink)
Purchase order from International Truck says 1825899C93. I'm sure the box doesn't have that many numbers on it so, as I said, I'll check it when I get home this evening.
Old 09-27-2003, 06:53 PM   #12 (permalink)
Verification on part # 1825899C93. Picked one up Thursday at the International dealer. $79.00 plus tax. For kicks stopped by dealership and the best I could talk them down was $172.00.
So it is in the glovebox along with a 10mm wrench. Now the 3 dollar question, where does this sucker go? I've searched the 7.3 forum, and I can not find the post that showed how to replace. Where is the CPS located? [img]/ubbthreads/images/graemlins/confused.gif[/img]
Thanks,
Gary
anoxic is offline
Old 09-28-2003, 06:43 AM   #13 (permalink)
My Photos: (16)
Is the part # the same for the year 2000 up to 2003 with the 7.3?
DUNC
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
DUNC is offline
Old 09-29-2003, 11:47 AM   #14 (permalink)
DUNC,
Yep !
Certain it is good through 99' From what I understand both the C93 and C99 will work, just an issue about connection.
Gary
anoxic is offline
Old 10-01-2003, 01:53 PM   #15 (permalink)
just above the crank pulley off center a bit to the right side of the truck. you'll see the wire leading down to it.
it has a O ring that keeps it in there pretty good so dont be scared to pry (easily) to get it unseated.
i would also recommend putting a film of oil on the new one's seal before installation.
2005 Midnight Blue Dodge Magnum RT...Yeah, it's got a Hemi!
TRADED 2000 "X" Limited, 4x4, Superlift 6", ProComp 35/12.5/16 Mud Terrains. Two Time Member: CPS F.O.R.D. club. water pump replaced at 51K.
4 SALE: 1996 Impala SS, Dark Green/Grey Metalic, 77K, Bridgestone Potenza RE730's, Dynamax's W/stainless tailpipes, 3:73's
Todd T is offline
