Use number 2 down to about 20 degrees or so. For temps below that use a mixture of about 30% #1 and 70% #2. If you live in a cold-weather climate most stations will offer 'blended' fuel right out of the pump so you don't have to mix them yourself.
Wayne
2004 X Limited. Medium Gray Metallic, 4x4, 6.0L Diesel, DVD, LimitedSlip Differential, HD Tow Group, Transfer Case Skid Plate, Radius Rods, Remote Starter, Magnum Hitch, Nitto Terra-Graplers, Running Boards Removed, Large Payments.
In Florida I have seen almost NO stations which post which fuel they are selling. Most stations charge, now, about $2.23 a gallon except one Sunocco which charges $1.99. The other shell stations did post #1 or #2 on the pumps but all the posts seem to have gone by-by.
I think they just chargen #1 high prices even when selling #2.
I don't know any other way to tell the diff. between them. Is there something I can look for to tell?
Thanks for any help.
Mesu
Excursion 2004 4X4 Limited - PUEBLO GOLD - 6.0L T-C Diesel - 5-Spd Auto Trans -AM/FM Sterio In-Dash 6-CD - Rear Seat Entertainment - DVD - 2nd Row -Dual Bucket Seats - PWR HTD T-T Mirrors - 3.73LS Axle - T-Case Skid Plate - Thule Top Rack - SC Tuner
Veh. Built 7/16/03 Eng. Build date 6/27/03 by International - Purchase Date 9/1/03 Milage on date 6/9/04 = 15,000 11/15/04 = 26,890 4/19/05 = 35,639 12/12/05 = 49,810 8/29/06 = 63,750 3/27/08= 100,003 Rancho 9000 shocks F & R.
It is hard to take travel serious when every time you leave home you take an Excursion !
I can't speak for Florida but here in Cali the fuel type is posted on every diesel pump that I have ever seen or used. It is also usually posted on the diesel advertisement sign listing the current fuel prices for that particular station.
Diesel prices down to $2.01 on the Peninsula. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Mesu
I think down here in the south, you won't find #1 at all. Maybe at some larger truck stops. Here in Texas I haven't seen a pump yet that was marked #1 or #2. I assume it's all #2. In Colorado I filled up and it was marked as a Blend. Dang the truck was LOUD running that stuff!!
I know were running a blend though the pump is marked #2 as the engine sure got abit louder after fill so I had to add a little more ****tail to make up the difference for the junk fuel [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Plunked down $1.68 per gal,that must be the blended special price.
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
WOW, maybe that's why some diesel prices seem really low! I never knew there was any blended down here. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Diesel #1 has less cetane(thus less MPG)in it versus the better performing #2,soon as April comes around my MPG takes off and the engine quiets down alot.
