Old 09-02-2005, 01:52 PM   #1 (permalink)
Diesel smell
For about the past week, I smell diesel (not exhause but more like fuel) in the car while driving. It is most noticable when the AC fan kicks on when first started. I've looked at the floor in case I tracked some in, but that doesn't look like the problem. Then other thing is it is intermittent. Not sure if it is a real problem yet, or not. I am wondering if anyone else out there has had the same 'symptoms'? BTW, I kinda like the smell [img]/ubbthreads/images/graemlins/smile.gif[/img]
Len
2002 Excursion PSD Limited, 4X4, Aspen Green, Cortex Tuner, Walker BTM, A pillar gauges, Bilstein shocks, Ford finned diff cover, Hellwig Sway Bar, and BFG LT285/75R16E tires.
coldpizza is offline
Old 09-05-2005, 11:15 AM   #2 (permalink)
My Photos: (11)
Re: Diesel smell
Lok for a fuel leak. Have you noticed your fuel mileage being a little off lately? I don't know where all the X's can have leaks, but when my 95 started leaking I had a terible smell in the cab.
Good Luck
His: '95 F350 CrewCab, 3.55 SRW, 5spd std w/ Royal Purple, LUK SMFW, VDO Pillar gauges, Homemade open air intake, 3" Downpipe W/ 4" cat-back exhaust from Tymar, Tunes by DP Tuner, Baby Seat Mod on rear bench, 198K miles. It gets 21-23 mpg consistently (on the highway) and 17 mpg in town. My remaining planned mod list includes Amsoil & electric radiator fans.
Hers: 2004 Chevy Malibu Classic; 2.2Ecotec 4 cylinder. VERY dissapointed in mpg's.
Company Car (Daily Drive): 2007 Chevy Impala, Jet Black
cmichalik is offline
Old 09-05-2005, 11:44 AM   #3 (permalink)
Re: Diesel smell
I had a similar problem with my 2001 7.3 a year ago. I replaced the fuel filter and that smell went away. I could not see any fuel leaking and when I installed the new fuel filter I made sure I oiled the rubber seal. Good Luck!
score522 is offline
Old 09-05-2005, 01:52 PM   #4 (permalink)
Re: Diesel smell
i had this issue once make sure you fuel filter lid is tight
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Racerxautomotive.com for your upgraded E4OD/4R100 needs
BlindViper is offline
Old 09-05-2005, 03:20 PM   #5 (permalink)
Re: Diesel smell
As with any trouble shooting...
Ask yourself what changed just before the issue came up?
Usually THAT's the cause...
now if nothing was changed just before then...
the research has to be a little more detailed...
and you got some great suggestions so far...
good luck...
JohnBoyII is offline
Old 09-06-2005, 04:49 PM   #6 (permalink)
wow
Re: Diesel smell
If you haven't changed anything in a long time, you could have a loose injector. Sometimes 1/4 turn is all it takes.
Wayne
2004 X Limited. Medium Gray Metallic, 4x4, 6.0L Diesel, DVD, LimitedSlip Differential, HD Tow Group, Transfer Case Skid Plate, Radius Rods, Remote Starter, Magnum Hitch, Nitto Terra-Graplers, Running Boards Removed, Large Payments.
wow is offline
Old 09-12-2005, 10:11 PM   #7 (permalink)
Re: Diesel smell
Take a look in the valley on top of the motor. A common leak is at the fuel/water drain valve on back of the fuel filter housing. (Or like others have said, it could be leaking around the fuel filter cap.)Do a search on fuel leak or fuel +valley in the 7.3 engine and drivetrain forum and you will find plenty of info on the problem.
"Thinking is the hardest work there is, which is probably the reason so few engage in it." - Henry Ford
"The greatest lesson in life is to know that even fools are right sometimes." - Winston Churchill
"Life is tough, but it's tougher if you're stupid" - John Wayne
2000 F250SD Lariet SC, PSD, 4X4 Offroad Pkg, ESOF, AT, Shorty, Tow Pkg, On-board air, Grover air horns, Isspro EV gauges & A-pillar mount, Zoodad, SCMT, 10k Variable Resister, $20 AIC, T/C LED & lock, custom oak console w/integrated switch panel and gun lock-box, heater valve mod, acetoned badges, 203* thermostat, Harpooned tank, in-tank and pre-pump mods, Brakesmart controller, Turnover Ball gooseneck, Hella driving lights, DIY HD headlight harness, Viper 791xv, KCM SS HPX, CCV filter mod, Severe Duty AIS, fuel regulator shim, transgo tugger kit, PI Torque Converter.
To be installed: Wicked Wheel
Proud member of the vast right-wing conspiracy.[img]/ubbthreads/images/graemlins/smirk.gif[/img]
Smoke Signals is offline
» Sponsor Links
»Garage Storage and Cabinets
