Old 09-27-2007, 10:55 AM   #1 (permalink)
Do the Excursions have automatic door lock systems?
I noticed somnething wierd the other day, for the first time in 3 years, when I placed the gear selector in park, it sound like the door locks were trying to activate.
Am I missing something or, was this just an illusion?
2001 Excursion 7.3 PSD, 2WD, Limited Edition, 3.73 gears, 230,000 miles, Hpypertech Stage 3, Boost,Trans Temp and EGT, 22+ MPG, Love this SUV!
Dragracer61 is offline
Old 09-27-2007, 11:06 AM   #2 (permalink)
Re: Do the Excursions have automatic door lock systems?
you can set it to do that. its in the owners manual somewhere. on a side note, mine won't allow you to lock the door with the engine running and nobody sitting in the drivers seat. you lock it, get out, shut the door, and it unlocks by itself.
Diesel horns make me smoky!
2003 Excursion Limited 6.0L as stock as they come
thesixcar is offline
Old 09-27-2007, 11:26 AM   #3 (permalink)
If memory recall is correct both of the above can be programed in door locks
Look on diesel van form for Larry's little secrets and the procedure could be listed in his items
But 5+ years ago the method of programing was listed on froum
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
Ken1 is offline
Old 09-27-2007, 07:23 PM   #4 (permalink)
On my 05 I reset to not lock when put into park I don't think much has changed.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 09-27-2007, 08:33 PM   #5 (permalink)
My '05 EB has the auto-lock feature, but it was not available on my '01 Limited ... so yes and no. I'm not sure which year they started carrying that feature as standard.
Hoowasat is offline
Old 09-28-2007, 12:00 AM   #6 (permalink)
FamilyRide's Avatar
Mine locks when I key-on the key.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 09-28-2007, 03:08 AM   #7 (permalink)
HWNSTYLX's Avatar
Same here, mine locks with the key in the on position.
00 "X" Limited 7.3L PSD 4X4, 4" Turbo Back Exhaust w/BTM, Edge Juice W/Attitude, EVO, Pro Comp Ultra Lite Trans Temp Gauge, Pyro, and Boost, Pro Comp 4"Lift, 35's w/Welds 16.5X10, Exhaust Brake, Airaid Cold Intake, Clear Headlights and Turn signals, Billet Overlay Grill, Centric Slotted Rotors, Zoodad, IC Wrap Delete, CCV Mod, Air Horns w/5gal tank.
PICS
2003 18FT Wanderer TB
HWNSTYLX is offline
Old 09-28-2007, 08:01 AM   #8 (permalink)
Mine must have had it all disabled because the only way it will lock is if I hit the PDL switch. I haven't tried to lock the doors with the key in the ignition because I just have one key for right now. So, if I go to a truck-stop and want to leave the AC running for the dog, can I just take the key fob with me to lock and un-lock the doors? Will the system let that happen?
2000 Excursion LTD 4x4 PSD 186k stock for now
1995 PSD F-250 2WD XL SuperCab LB super-beater, stock, AT, 180,xxx miles and climbing
steelsoldiers is offline
Old 09-29-2007, 07:06 PM   #9 (permalink)
I believe that once the engine is running, the fob/remote no longer operates the locks ... at least that's how it responds on my '05.
Hoowasat is offline
Old 09-30-2007, 10:31 AM   #10 (permalink)
Dunbar's Avatar
I have 2 keys and 2 fobs. I can lock the truck with the engine running with either fob. I like to leave the truck running with the AC on in many situations.
My doors do not auto lock ever. I have to hit the paddle switch to lock mine when driving. I would not mind auto lock when engaging gear but do not want to loose the ability to lock the truck running so I might not mess with it.
I am thinking of getting a remote start. In Houston it would be nice to start it before going out to get the AC cranking. They also allow you to remove the key from the ignition leaving the engine running. In Texas is is illegal to leave the keys in the vehicle but I do not believe that it is illegal to leave the engine running. The remote start also allows you to take the keys and have the engine turn off after so many minutes allowing for turbo and EGT cooling.
Dunbar
David Dunbar
2003 4x4 7.3 Excursion Ltd
4" exhaust, CAI, Vcode & modified Fcode, Helwig, Bilsteins, Isspro 3 gauge w/ windshield mount, BTS VB matched to DP tuner 80-60tow-40tow-HI, 6.0 31-row ATF cooler
Tomball Texas
Dunbar is offline
Old 09-30-2007, 01:12 PM   #11 (permalink)
bpcheramie's Avatar
I have an 01 and it locks when I put it in gear or should I say when the darn door lock work. It can be nice when you are going in those not so nice area to know the doors are locked. So it looks like from the way people have responded that some have it turned on and ohter dont. Good luck with finding what you are looking to do. I wish I could help you out.
Brent
01 Excursion 4X4 - DIY Injectors, Garrett GT38R, DI Regulated Fuel Return, HX CrossOver, AFE stage II, Diamo 17 Karat 18x10.5 w/ 325x60x18, 4" straight pipe exhaust, DI 6 position chip, X and F Springs with F350 Rear Blocks and .....................
01 Excursion 4X4 - RIP 2/22/2008
All work has been done by Diesel Innovations!!!!! Thanks to MR POWERSRTOKE RACER for all the help.
bpcheramie is offline
Old 09-30-2007, 06:37 PM   #12 (permalink)
FamilyRide's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Dunbar</div><div class="ubbcode-body">I have 2 keys and 2 fobs. I can lock the truck with the engine running with either fob. I like to leave the truck running with the AC on in many situations.
Dunbar </div></div>
I have the Ford Gold system and do that quite a bit. If I stop for a few minutes, I hit the button and take the keys.
Old 10-01-2007, 09:45 AM   #13 (permalink)
I reviewed my OM over the weekend and saw nothing about the autolocks, I see Ken posted the procedure, will give that a try.
BTW, I have lost my code for the door key pad. Any ideas how to correct? I have searched the car over for the "hidden" code and cannot locate it.
» Sponsor Links
»Garage Storage and Cabinets
