Old 09-24-2005, 01:45 PM   #1 (permalink)
Does anyone know if this works on Excursions?
http://dan.prxy.org/Truck/Other/High..._idle_mod.html
04 X, 4x4, 6.0
Tony2Co is offline
Old 09-24-2005, 02:32 PM   #2 (permalink)
Re: Does anyone know if this works on Excursions?
I'd guess it wouldn't since our trucks are not designed to be upfitted with a PTO.
2001 Black Excursion, 4x4, XLT, PSD, LS, (EBM2), Super-Duty grill, 4" MBRP exhaust, Bilsteins, X-springs, OilGuard bypass filter, 295's, Badges, Suvlights harness, APC headlights, Weatherboots, Centramatics, Clear corners, AIC w/ITP mount, ISSPRO EVs, BTS trans, Open element intake, ATS compressor housing, Thule rack, BD Torqloc, F350 rear blocks, Randy Ellis lightbar with a couple of Lightforce 170s, Front receiver hitch, DP Tuner chip
1975 Ford Bronco, neglected since I bought the Excursion
AJ'sDad is offline
Old 09-24-2005, 05:32 PM   #3 (permalink)
FamilyRide's Avatar
An Auto Idle Control (AIC) can be installed on an Excursion. Check the General Aftermarket forum. I think there have ben several people add them. As for a control integrated wiht any PTO functionality, as was already said, Excursions don't get any PTO provision as you can get with the SD's.
Do you have a specific use for it?
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 09-25-2005, 06:28 PM   #4 (permalink)
Mainly for the A/C in the summer in Tx when I pull over to fill up and run in the store on hwy trips, and when we move to Co, the winters there. I know the X's don't have a PTO option. Is this wiring the same though? Is there a wiring diagram the shows these being different from the X to a truck with PTO option. This is s really simple and cheap way to elevate the idle.
04 X, 4x4, 6.0
Tony2Co is offline
Old 09-26-2005, 07:53 AM   #5 (permalink)
Yes, it works....
other site has a lot of discussion and raves about it...
JohnBoyII is offline
Old 09-26-2005, 01:36 PM   #6 (permalink)
What other site?? Would like to look into this more.
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 09-26-2005, 01:45 PM   #7 (permalink)
FamilyRide's Avatar
Check your PM
Old 09-26-2005, 02:24 PM   #8 (permalink)
OK, will it work on a 7.3L?
I'd like to find out about that "other site" too
2002 X Limited PSD 4x4 - Mineral Gray, WeatherTech floor mats, cargo liner, and Weather Visors, Ford "Tire Organizer", Silverstar headlamps, Hellwig rear sway bar, "Steveracer" fog light mod, TTM, XM Roady 2, completely stock drivetrain. Tow 24' Osprey Fisherman on Long AL2570 trailer.
overcurrent is offline
Old 09-27-2005, 06:31 AM   #9 (permalink)
Any tricks for a 2001? Does not have a digital trip odometer
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
Ken1 is offline
Old 09-28-2005, 02:07 AM   #10 (permalink)
What is this "other site"?
04 X, 4x4, 6.0
Tony2Co is offline
Old 09-28-2005, 10:48 AM   #11 (permalink)
FamilyRide's Avatar
Check your PM's.
Also search here in the general aftermarket forum. A lot of good info is sometimes overlooked here when a search will find a ton. TDS search sucks, only if you don't look at search tips and search the right way. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Old 09-28-2005, 02:19 PM   #12 (permalink)
Can someone clue me in on the "other" site too? This site is great, but I would like all the info I can get!
Thanks.
duckkilr is offline
Old 09-30-2005, 12:21 AM   #13 (permalink)
The factory AIC for the pickups works great in the X. I wired mine in and it works flawlessly.
AJ'sDad is offline
Old 09-30-2005, 03:23 PM   #14 (permalink)
How did you do it AJ and do you have any pics?
2005 Excursion 6.0 4X4 EB 4" MBRP Turbo back 5" tip, Zoodad, Steveracer, Midland 79-290 CB, Wilson 5000, outlook monitor, DR 3" lift W/ Bilstien Shocks, U and Mod B codes, Billet Badges, 05 Powerstroke Badges, Weld Cheyennes 18x10, Mickey Thomspon 325/60-18's, DynaMated interior, Strobes, Train horns, 30mm rear and hellwig front sway bar, HIDs in Headlights, Fogs and backups, AIRAID Intake system, Randy Ellis light bar, 4 KC's, oilgaurd, FASS, LED markers, Bean's 190cc Injectors, Bean's Turbo, ARP Headstuds, Banks IC, Custom Fuel System, SCT by Kermit, More to come...
14.109 @ 95.96mph best 1/4 for now, Oh ya @ 8520lbs
AUGSX is offline
Old 09-30-2005, 04:52 PM   #15 (permalink)
I don't have any pics, but I got the information from a post here a long time ago.
The AIC ony requires 4 wires to hook up.
Switched power
Ground
Data line
Data line
The data lines are contained in the twisted pair right behing the OBDII plug. It was VERY easy to wire up. Let me try and find that post that gave the wire colors and connections.
AJ'sDad is offline
