Door Ajar, Cant figure out which one! Interior lights stay on! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 02-18-2006, 08:19 PM   #1 (permalink)
My Photos: (12)
Ok.. The damn door ajar light stays on, and I cant figure out which door is sticking open... Is there a fool proof way to tell? The running board lamps, and the interior lights stay on... Should I just pull the fuse for the lights?
-Rhino
2001 Ford F250 Platinum Edition. Airaid intake, and the Juice/Attitude combo, Magnaflow 4" stainless dual system, Harley Edition front grille/bumper 14.5 inch Donahoe lift, crossover steering, fox 2.0s, rolling on 22.5 Alcoa floats!
2003 Excursion XLT 4X4
2001 Monster F350 XLT CrewCab 4X4 7.3 PowerStroke, Bright Amber Metallic 12" lift, Dual 2.5 King shocks. Prerunner light bar with 4 PIAA Pro Racing 80XT lights. 39.5" Super Swampers on 16.5X12 Weld Typhoons. Drivelines by High Angle Drivline. Gone but not forgotten!
HugeF3fity is offline
Old 02-18-2006, 08:33 PM   #2 (permalink)
Re: Door Ajar, Cant figure out which one! Interior lights stay on!
I have had the same problem a couple of times....drove me crazy. I never did find which door was sticking. I took silicon and sprayed everything I could see on every door. If fixed my problem and it hasn't happened again in the last year. My gut tells me it is one of the rear passenger doors, but I am not certain.
2003 Excursion Limited 6.0 PSD, Mineral Grey Metalic, 3.73 Ltd Slip, 2nd Row Buckets, Tele PWR TT Mirrors, DVD
dgreen1069 is offline
Old 02-18-2006, 08:55 PM   #3 (permalink)
My Photos: (12)
Thats what I'm thinking too, but I'm not sure...
-Rhino
Old 02-18-2006, 09:06 PM   #4 (permalink)
fordmastertech's Avatar
The upper tail gate latch switches usually are the most problematic on the Excursions. Spray both of the tail gate latches with some WD40 or PB Blaster and slam the gate several times. If that doesn't work move on to the next door and do the same thing.
FMT
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 02-18-2006, 09:48 PM   #5 (permalink)
Perhapse its a fuse, panel is under your stearing colum just pop it and test them. worth a shot [img]/ubbthreads/images/graemlins/smile.gif[/img]
smokedemon is offline
