Old 01-17-2005, 10:08 PM   #1 (permalink)
clamgulch's Avatar
Door Ajar Sensor Problem, 2000 Excursion
I need some ideas of where to start: the 3 doors on the back close tightly but sometimes won't shut off the sensor circuit so the interior lights and running board lights stay on until they time out. I've loosened the screws holding the sensors on the doors a couple different times, but it still does the same thing. Sometimes I can slam the doors and it will quit, but not always.
Any suggestions?
clam the powerstroke grinch
2000 Excursion LTD 4x4
Slightly tweaked HPCR 5.9 Cummins
Allison 1000 5 speed auto
clamgulch is offline
Old 01-17-2005, 10:19 PM   #2 (permalink)
FamilyRide's Avatar
Re: Door Ajar Sensor Problem, 2000 Excursion
Some have fixed it with a shot of WD40.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 01-17-2005, 10:28 PM   #3 (permalink)
clamgulch's Avatar
I never would have imagined that one for a fix-
I'll try it!
Thanks- [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Old 01-17-2005, 11:24 PM   #4 (permalink)
crumm's Avatar
My Photos: (38)
WD-40 fixed mine. The only trick is to decide which door you are going to try last and do it first [img]/ubbthreads/images/graemlins/wink.gif[/img]. When I lubed mine I about gave up but the last door I tried is the one that needed the WD-40.
1996 F-350, 4X4, XLT, C/C, 5sp, 4.10, Chip, DPPI Down Pipe, Tymar intake, Shackle reversal, 315 Toyo MT's, 67,000 miles.
crumm is offline
Old 01-17-2005, 11:44 PM   #5 (permalink)
Works great to figure out what switch is bad or sticking. I replace the switches if there under warranty or I will not get paid. Got to replace something to get paid from Ford. The WD40 trick may have to be done again but it cheaper and easier than replacing those dam switches.
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
Old 01-17-2005, 11:48 PM   #6 (permalink)
crumm's Avatar
My Photos: (38)
WD-40 has been working for over two years without another application. Does Ford make you replace the engine when the oil needs changed? Replace the door hinges when they squeak? Things like this makes me real nervous taking my rig to the dealer..
crumm is offline
Old 01-17-2005, 11:57 PM   #7 (permalink)
No fussy customers do.
Excursion Pics
Old 01-18-2005, 09:59 AM   #8 (permalink)
FamilyRide's Avatar
LOL Bingo!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 01-18-2005, 10:13 AM   #9 (permalink)
WD-40 or some good old PB Blaster!
99 F250SD 4x4..5in Exhaust.. MircoTuner
01 EX....stock
outplayn is offline
Old 01-18-2005, 09:28 PM   #10 (permalink)
I used WD40 on mine ... worked for awhile ... then replaced all 6 switches. A couple switches were in the old boxed containers (versus the newer plastic bags), so I had the problem arise again after replacement 'cause the replacements were the old style switches. I finally studied the Ford wiring diagrams and wired in 4 toggle switches at the GEM under my dash; one for each front door, one for the pair of rear doors, and one for the liftgate. Oddly enough, my door ajar switches haven't given me a moment's problem since installing the switches last summer. I was hoping I could at least narrow the problem down to a pair of them. Anyways, should the problem flare up again, I'm ready to disconnect the offending switch without turning the juice off to the electric windows and other items ... can't even shift out of park if you pull the door ajar fuse.
Hoowasat is offline
Old 01-18-2005, 10:01 PM   #11 (permalink)
Tim, please don't take this personally, 'cause it's not meant to be. But your comment reminds me of our experience with one Merc dealer. The wife bought a new Sable LS wagon in Feb. '87. In May, tried the A/C and it didn't work. Took it in and the technician said it needed a new controller, not in stock , so it was ordered. Two weeks later, the wife goes in for the controller. When the car was ready, she tried the A/C. Guess what? No cold air. So she parked it blocking the bay door and went for the service mgr. She explained the situation. He calls over the technician. When asked about the A/C, the technician responds to the Service Mgr. with "you told me to install it, not to check it!" Final resolution: when the car was built, they forgot to install the fuse for the A/C.
Fussy customers only want the vehicle they paid dearly for to work as advertised.
That said, I could never work in retail because I couldn't deal with some of these customers. [img]/ubbthreads/images/graemlins/grin.gif[/img]
//bruce
2000 Excursion Limited V10 4x4
ART brakes, Rancho RSX shocks, Hellwig rear sway bar, SD grille, V10 badges, Sylvania Silverstars, clear corners, and Bridgestone Dueler A/T REVO 285s.
rozett is offline
Old 01-18-2005, 10:08 PM   #12 (permalink)
I can agree with this. That tech will not last long in this dog eat dog business.
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
Excursion Pics
Old 01-19-2005, 10:30 PM   #13 (permalink)
clamgulch's Avatar
Thanks, everyone, for your input. The WD40 seems to have stopped the problem! That was sure easy... [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 01-19-2005, 10:39 PM   #14 (permalink)
FamilyRide's Avatar
Ok gentlemen, our work here is done. Good job.
Now let's go home!
