I just bought a 2000 Excursion and the power locks are giving me a hard time. I talked to a couple of people that say the accuators are worn out probably from kids messing with the door locks. Has anyone else run into this? What did it cost you to have it fixed? All doors are weak including the rear. If it sits for awhile it works o.k. but if gets used alot they will not unlock and sometimes will not lock. I tried moving the lock by hand and they all seem to move freely.
I think it's a pretty common problem. If you search on the forums there were some good posts in the last year on how to replace them. I think they're not that expensive if you're willing to invest the sweat equity. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Good luck,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
It happened to me. Both front actuators went bad at the same time. Service manager says he's seen all five go bad at once! They're approx. $75.00 each and can be a pain in the neck to replace.
00 PSD Excursion LTD 4x4 born 6/00 Dark Green Satin/Med. Parchment, 3.73LS, Telescopic TT Mirrors, CDchanger, Htd Seats, Reverse Sensing System, LT265/75R16D AT A-Pillar Pod, VDO Vision Series Gauges - Boost, Pyro & Trans Temp, Tekonsha Sentinel, Bilsteins, PSD Emblems, U Code Springs
Kevin: I got about the same $ from the dealer and that is just for the parts. I had all five replaced today with aftermarket electromagnet accuators. The fronts were $50 per door installed lifetime warranty. I do not know the $ for the rear yet.
Another thing is that the ford ones apparently use a plastic screw type accuator. This is a weak design according to my alarm and stereo shop. Spal is the name of the accuators that they used. Here is a link to the ones they used: link They gave me a lifetime warranty on parts and labor
Thanks for the "TIP" on the SPAL door lock acutators....I called them, and ordered some from the company in Sunrise Fl..$50 for the set of 4...The guy down there said they would work with either a 2 or 5 wire set-up,,,,I'll pop open the interior panel and see what I acutally got....The Ford dealer here in Waynesville, NC. gave me a verbal estimate of approx $300 for the front two on my "X", and maybe another $300 for the rear....I'll try to do it myself, the first opportunity I get.....I mean $500 savings ain't hay!!!! ""IF"" it took me the whole weekend...that's still $250 a day paycheck
No problem. I wish I had known they were that cheap before I had them done and I would have attempted it myself. My X has the 5 wire set up and it looks like they only used two wires for the new accuators and the others are taped off. I don't know how yours is but my back door was not working very well also. Not any more they all work great! [img]/ubbthreads/images/graemlins/grin.gif[/img]
does anyone know how many wires are comming from the ford accuators? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Crustydoughboy
2000 EXCURSION Toreador red (diesel of course). Bilsteins, Hellwig. No Sway-No Way
30' Jayco
97 ULTRA GLIDE Blue&Gray
Waitin for my ship to come in.
Mine all quit at once. Door switch, key pad, or hand clicker, no diference, all bad.
Oley [img]/ubbthreads/images/graemlins/frown.gif[/img]
(Member Since April 2000)
2000 Excursion LTD, AXD1, TS 4 way tuned at BTS
3 WD gauges on the post with EGT in exhaust manifold and 203* T-stat
FleetGuard pre-pump spin-on fuel and Oil Guard by-pass oil filters and homemade ccv re-rout
{homegrown air intake} Western Diesel Ram Air scoop with HUGE 'TYMAR STYLE' paper filter,
ATS turbo housing W/Wicked Wheel on stock Garret, with Riley air charger boots
and intake heater deleted also Billet aluminum air intakes
{Exhaust is} Jardine 4" with 3 1/2" DP
{She's been} "hutcned" & "TT"d & HX oil crossover hosed
BTS/W V10 cooler, BD TorqueLoc, and Cyclone fan clutch, Mag-Hitec tranny & rear end pans
For ride and tow she's got the Hellwig rear anti-sway bar, Edelbrock IAS shocks,
Firestone Ride Rite over-loads, Tekonsha Prodigy, and Hensley Arrow
