Old 02-14-2004, 12:32 PM   #1 (permalink)
door speakers
Guys, I'm interested in upgrading the factory speakers to something better. Does not need to be high end stuff, just better than the usual low end the factory puts in. For curiosity's sake I was looking at the Crutchfield website, and they list nothing available for the front doors. They do list several for the back doors and the last row back. Has anyone here installed anyting decent (pioneers,jbl's etc.) in the front doors in the 6X8 size that did not interfere with the windows or anything else without modifications, and still kept under the door panel so it looks stock?
Thanks.
vc
2002 LTD 4X4,Bi-Xenon HID's,Amsoil Dual Remote,Wicked Wheel,under dash 3 gauge pod(Isspro's), 203 t-stat,aluminum t-stat housing,evans coolant,TRU-COOL MAX tranny cooler,external tranny filter,Western Diesel RamAir intake,Edge Evolution tow tune, Edelbrock IAS rear shocks,Landyot's Radius Rods,5 new Pirelli Scorpions courtesy of Ford.
boaterholic is offline
Old 02-14-2004, 07:20 PM   #2 (permalink)
Re: door speakers
I installed 3 way 6x9s in the doors. The panels are a snap to get out, just a few screws and the door panel lifts up and out. The tough one was the far rear. that one took a lot of time but it was worth it. You can use other sizes if you make a panel to fill in the gaps. It takes very little to upgrade these POS speakers. I have the top of the line 6 disk changer from Ford and it is still a joke. I had to retain the deck due to the DVD but I am getting close to wiring that up seperate and getting something with XM capabilities. I have 2 10" subs, 6 replacement speakers and two amps, one for the speakers and one for the subs. I ran the back door and rear panel speakers in series. It is so worth the time and effort, the amount of room in the truck makes for great sound and some serious bass. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 02-14-2004, 08:25 PM   #3 (permalink)
Re: door speakers
so did you have to make any mods to get the door speakers in?
Old 02-15-2004, 12:17 PM   #4 (permalink)
Re: door speakers
I'm looking to upgrade the stereo ASAP...will the DVD system prevent this? Thanks.
mambodottore is offline
Old 02-15-2004, 03:39 PM   #5 (permalink)
Re: door speakers
WHen my in-dash factory 6 CD changer started changing tracks by itself I took to the Audio shop. It was out of warranty. Needless to say the tech said that the unit was about to die. Said they see these units pretty often.
I decided to upgrade to a Pioneer CD/XM radio unit with Pioneer 6x8 inch speakers in all the doors. It made a world of difference in the sound. The 6x8 speakers were a perfect replacement fit. No modifications needed. When I looked at the OEM speakers its clear they are a joke.
My Daily Working Truck - 200,000 miles, 2001 X Wedgewood Blue, 4x2, Rancho 9000s, K & N Air Filter, Helwig anti-sway bars front and back, Weathertech catch-all rear mat, window vent shades, Molded mud flaps, Pioneer XM Radio, Escort 8500 Passport Radar Detector, Pioneer in-dash CD/FM/AM changer, SCMT (It Rocks!), Michelin LTX M/S 285/75 16 RD, Badged, Super Bright Back-up lights, Sylvania Silver Star Headlights, Thule roof rack system with Evolution Carrier Box, Extended Arm Rests
jpbrake is offline
Old 02-15-2004, 07:39 PM   #6 (permalink)
Re: door speakers
jpbrake,
do you know what model speakers they were?
thanks
vc
Old 02-15-2004, 08:55 PM   #7 (permalink)
Re: door speakers
The speakers I put in were Pioneer, model TS-A6880R
They are 4-way speakers, 6 8 inches, rated at 240 watts
They are custom fit for Fords.
I got them at BB for $100/pair
Got two pair.
Install was painless. A perfect fit.
jpbrake is offline
Old 02-15-2004, 10:35 PM   #8 (permalink)
FamilyRide's Avatar
Re: door speakers
If you pulled all the factory speakers, are they all the same? The Expedition with the Mach system used the good speakers up front and the standard speakers in the rear. Wondering if the Ex is the same....
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 02-16-2004, 05:04 AM   #9 (permalink)
Re: door speakers
Each of the 4 door speakers are identical
jpbrake is offline
Old 02-18-2004, 02:45 AM   #10 (permalink)
Re: door speakers
Motion man,did you have to convert to low level audio inputs to the amp's?Also are your sub's mounted in the rear cargo doors?
Thanks,Joe M.
My Photos
<font color="red">2002 EXCURSION, PSD, XLT Premium, 4X4, Medium Wedgewood Blue,8' Meyers E-Z Mount Snow Plow,14.1" rear LCD video monitor and DVD, FS2500 bypass oil filter, Mobile 1 synthetic ATF, Rotella T 5w-40 synthetic oil, Baldwin transmission filter, K&N filter charger with Zoodad mod., Banks Trans Command, Bilstein shocks, Rancho steering stabilizer, Hellwig rear anti-sway, XM Commander satellite radio, C-Bet'r convex mirrors, factory remote start, daytime running lights, Silverstar headlamps, "Xtra" reverse lights, Hidden Hitch front hitch receiver.Cabela's Winter Grill Cover by Fria</font>
1996 Ford Crown Victora P-71, white, blue cloth buckets, super clean and super fast.
2006 Subaru Forester 2.5X Premium(I highly recommend it in snowcountry)
2005 Gulf Stream Canyon Trail 29TEBH,with Reese D/C HP
JOE_M is offline
Old 02-18-2004, 09:49 AM   #11 (permalink)
My Photos: (11)
Re: door speakers
So here is a question from the electrically ignorant. If I choose to replace the speakers with Pioneers like jpbrake, is there any extra wiring I need to do, or are the speakers plug and play. Also, does the stock Ford 6-disc deck have enough power to push the Pioneers?
Mike
2003 X LTD,6.0L,Torqshift,4x2 (wife's toy)
Autometer Z-series Tranny/Boost/Pyro in Under-dash pod
Hellwig Rear Anti-sway bar
Stull Billet Grill
AFE Intake w/ Proguard-7
Magnaflow XL 4" Turbo Back Exhaust
20x8.5" MB Gunner 8 rims on Michelins 305/50R20
CobraMike is offline
Old 02-18-2004, 04:14 PM   #12 (permalink)
Re: door speakers
CobraMike,
if it's anything like when I replaced the 4 speakers in my last truck - a Dodge - no problem pushing the Pioneers. I can't imagine any less power from the Ford stock radio's.
As to wiring, I got some adapter plugs from Best Buy that pluged to the stock harness plug on ene end and the other was for the pioneers. I did not have to do this as you can certainly cut off the stock harness and crimp on the appropriate terminals to slide onto the Pioneers. But I did because I did not want to cut the stock harness in case I ever neede to return to the stock set up.
vc
Old 02-25-2004, 09:56 AM   #13 (permalink)
My Photos: (11)
Re: door speakers
So here is a question for the speaker gurus! I went to Ultimate Electronics and Car Toys this weekend and both places told me that a round speaker actually gives better sound compared to an elliptical speaker like the Pioneer TS-A6880R. Something about a round speaker pulling on a round coil vs. an elliptical speaker pulling on a round coil. Anyway they pointed me to the Infinity 5002i, which is a round 5.25" speaker. They said to install it you can just use adapter plates in the doors. So I looked at the specs and the Pioneers are 50W nominal,240W max, and a range of 30Hz-30kHz. The Infinitys are 45W nominal,135W max, and a range of 60Hz-21kHz. They also said that unless you are trying to bust your ear drums max voltage doesn't matter, just nominal. So give me your opinions. By the way, they are the same price. Thanks!
Mike
Stull Billet Grill
Old 02-25-2004, 08:11 PM   #14 (permalink)
Re: door speakers
I doubt any of us could tell any difference in a top line speaker while drving in this big honkin' diesel truck.
My feelings? just buy what you see at the store. Anything is better than the stock speakers.
jpbrake is offline
AutoForums.com is the premi
