Old 04-04-2005, 10:24 PM   #1 (permalink)
Doors - Snap, Crackle, pop!
Help! It's driving me crazy. Now that the weather is getting warm, I'm getting a popping sound in my drivers side rear and passenger side front doors. One of them was here last year in the warm weather but it's worse now andI have another door doing it. Any ideas what this is and what I can do to stop it?
Thanks!
Pastuki
2000 Crew Cab Powerstroke F250. Black Beauty
2002 Excursion V10 Limited
pastuki is offline
Old 04-04-2005, 10:36 PM   #2 (permalink)
CHPMustang's Avatar
Re: Doors - Snap, Crackle, pop!
If you're going down the road and it's rattling with the bumps even minor ones,the hinges/latches/strikers just might need a little adjustment.
Bill
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 04-04-2005, 10:57 PM   #3 (permalink)
Thanks Bill! Any suggestions on the best way to adjust them and / or to know which needs adjustment?
Pastuki
pastuki is offline
Old 04-04-2005, 11:13 PM   #4 (permalink)
CHPMustang's Avatar
I'd try applying some white lithium grease to the door latch mechanisms and strikers first,put some WD40 or alike on the mechanisms if the grease is not available.
If that doesn't fix it then you'll have to loosen the door striker/s and tap em inwards a couple times with a rubber mallet but wouldn't move the striker for more than a 1/16"-1/8" before testing the door/s to see if they close better to eliminate the rattle,just don't make the doors too tight as it could accelerate the paint wear on the top of the inner door to the roof weatherstrip.
There's supposed to be a rattle kit out there but haven't read anything positive on them.
Try out the grease first for sure.
Bill
Old 04-05-2005, 08:16 PM   #5 (permalink)
MotionMan's Avatar
Mine did this when new in the cold, was better in the warm but has gone away now. The pop may be the body mount (rubber hockey puck thing) I don't know why mine stopped but it did. I found if I cracked the window it went away, try this to make sure it is not the mounts.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is online now
Old 04-09-2005, 01:43 PM   #6 (permalink)
I don't know whether this might be the issue with your noises, but try silicone spray on the weatherstripping (it's good to do it occasionally anyway) It cured all window squeaks, rattles and other pops in my X...minor as they were, but very annoying.
Check carefully around the doors where the weatherstripping meets the metal. You might see evidence of rubbing.
1997 PSD-250HD, 4x4, 5 Speed, standard cab, downpipe, buried muff., 4.7 advanced, Baldwin open air element, Fumoto F-111 plug, Isspro pyro and manifold pressure gauge on pillar, Gulf Coast oil by-pass filter, M/T Baja Radial MTX's.
-SOLD- 2003 Excursion 6.0 Oxford white, Eddie Bauer 4x4. Turbo Lifesaver, Oil Guard by-pass, Fumoto plug, Rancho RSX'x up front, Rancho RS5410 stabilizer, custom rear air shocks, 30MM rear stabilizer, Radius-Rods by Landyot, Ranch Hand-front and rear, 5 IPF off road lights, Marinco heater plug receptacle, 305's Cooper Discoverer S/T on MT classic II rims, pillar pod with Isspro pyro, trans temp. & boost, V and F code springs.
"The polite society, is not one which nobody is armed, but rather one in which everybody is..." Robert Heinlein.
kojakone is offline
Old 04-09-2005, 05:39 PM   #7 (permalink)
I was at the Ft Worth auto show a few weeks ago and noticed the design of the weatherstrip molding has chnaged on the '05 Ex. Maybe it is better than the poor engineered w/s on my '02.
05 Ram 2500 Cummins 4x4 G56
02 X Limited Ult PSD 4x4,Edge Juice-Evolution,325/60-18 Nitto's on Weld Cheyenne 8's,V Codes, mini spring pack,F350 rear springs,5" blocks,Helwig,AIC
'00 Ram 3500 4x4 6-speed Cummins 374/829 DFW Dyno Day (Sold)
Chaw is offline
Old 04-11-2005, 07:39 AM   #8 (permalink)
My Photos: (16)
Can anyone post a pic showing difference.
Y2K X Ltd 4X4 PSD.Estate Green all options. DI 4 POS CHIP 50-75-100-140HP/K&N,Ram air,Regulated turbo vacume,Zoodad,Banks s/s 4" dwn pipe/exhaust,5" tip. Pre pump,tank mod, 203Thermostat and billet housing, Racor 460 filter-heater-water sensor,coolant filter,shift kit,exhaust brake, T/Q lock up,4X4 Front wheel lockout,High output alt with low rmp curve for max amps,Hellwig sway bar,4X2 Hatch Struts,Air horns,Viar 450 compressor,cab/Runningboard lights(Euro flash),Monroe Reflex,V Springs front,F springs modified rear,PowerSlot Cyro F/R, Hawk LTS F/R,Dueler Revo A/T 285/75/16,PSD badging, Isspro guages.C.B ,APCM, Locking Fuel Cap, Mud Guards, Door Edge, Bug Deflector, Window vents, Custom made Excursion leather jacket, General Coach Y2K 30' Citation T/T, Reese Dual-Cam Sway Bar, Reese Brakeman Digital control,Running light momentary switch.Back-up Camera.
DUNC is offline
Old 04-13-2005, 08:06 AM   #9 (permalink)
Bill, when you are referring to the striker is that the black piece on the body pillar ??
-Chris
2001 4x4 Limited X PSD
Chromed SuperDuty grille, HeloMaxx8 17x9,BFG315/70/17,Edge 3' leveling,
Hellwig rear sway bar, AIS intake, PowerElbow, 4" Monster Exhaust, Aeroturbine,
Banks Big Head actuator, Banks Compressor Wheel, Banks Transcommand,
Tag's I and II (and love'm), Hx crossover, 2003 headlights, Bilstien shocks, Rancho stearing stabilizer,
203t-stat and billet housing, and Edge Evolution, 24" PIAA wipers, intake heater delete,
Garmin Street Pilot 2610 GPS
<font color="red"> New BTS trans</font><font color="#OOFFOO"> LANDYOT radius rods</font>
"If you don't get everything that you want, be thankful of the everything that you don't want that you don't get !!!"
drchris1024 is offline
» Sponsor Links
»Garage Storage and Cabinets
