Old 04-26-2007, 01:37 PM   #1 (permalink)
Drivers seat starting to crack.
I have noticed that my drivers seat has started to crack. Need to find the original type of "Leather" and replace.
Does anyone know of good vendors for this material?
Ken
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
Ken1 is offline
Old 04-26-2007, 02:50 PM   #2 (permalink)
FamilyRide's Avatar
Re: Drivers seat starting to crack.
It's really not "leather" but a leather fiber impregnated vinyl. How's that. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Have you thought about recovering with somehting like Katzkin's?
Other than that, I'm sure a good upholstery shop would have, or can get it easy enough. It's pretty much what all manufactures use for their "leather seating surface".
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 04-26-2007, 04:01 PM   #3 (permalink)
Mine did the same thing. I bought the replacements for the captains seats (Excursion) from HERE . These are factory replacements, so they have all the hold downs and the right cut already.
Proud American
01 4WD PSD Ex - EBM2 - Autometer's on the A, Mag-Hytec Tran Pan, Front Hitch, Dome Light Override, TTM, CCV Re-route, Coolant Filter, Hellwig Bar, Walker BTM, BTS Trans, DP-Tuner, BIG SMILE!
scott-c is offline
Old 04-27-2007, 01:33 AM   #4 (permalink)
Replacing the seat cover with a fomoco replacement is a pretty easy do-it-yourself job. Pulling out the seat, dis and reassembly is pretty straightforward.
I replaced my seat bottom foam at 105K to get a firmer seat, like on my passenger side. Was a 1 hr job.
Mike
2000 PSD X / 6" Lift / oilGuard bypass / coolant filter / tranny filter / autometer guages / Tymar / Racor CCV / Mag-Hytec diff cover / Alpine IVA-D300 / NVE-N851 Nav / MB Quart speakers / 3 JL Audio amps / Dynamat / Centramatics balancers / Piaa driving lights / wife who doesn't understand
mcjones44us is offline
Old 04-27-2007, 06:55 AM   #5 (permalink)
Thanks for the replies
Ken
Ken1 is offline
Old 04-27-2007, 12:11 PM   #6 (permalink)
Mike
How bout cost????
Paul B
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 04-27-2007, 03:53 PM   #7 (permalink)
FamilyRide's Avatar
Looking at prices for the Ford OEM covers, pleather covers are anywhere from $150-$200. The others are cheaper.
Looking at the parts list though, they usually only list the Limited.
I'm sure the Ford system has all of them. I'd just be worried about cost for the other pleather covers like for EB. If they aren't in the same demand, they could be much more expensive. But it might make sense that the Limited's seats wear quicker being more subtle and smooth. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Old 04-27-2007, 06:14 PM   #8 (permalink)
Had cracking on the driver side seat at 104K miles when purchased in 03 and it really hasn't gotten much worse. The steering wheel was also had a hole in it then and it's gotten bigger since (covered now). Today on the way home from up North noticed a small crack on the driver side armrest, 173K miles.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 04-29-2007, 09:26 PM   #9 (permalink)
I've been thinking of getting a seat from a wrecked unit as the seat itself is starting to sack out along with being torn where the 'leather' meets the cloth at the back of the seat bottom.
-2000 Excursion Limited. 2WD. White with tan. Hellwig rear anti-sway bar. Bilstein shocks. Rear air bags.
2000 VW New Beetle TDI
2005 VW Passat TDI...totalled
2006 VW Jetta TDI
DR.billZ is offline
Old 05-01-2007, 10:07 AM   #10 (permalink)
Has any one looked at the cost of the King Ranch Leather?
I am sure the front would fit the second row looks close I have no ideal if they are even close.
Having real leather in an X would nice.
There I go again modifying the X with Ford parts!
Bruce
Bruce1954 is offline
Old 05-01-2007, 12:18 PM   #11 (permalink)
FamilyRide's Avatar
Bruce
I'd probably look at Katzkin's before the KR. It seems like someone in the General forum had priced it, and it was expensive. Katzkin can be customized with good quality real leather that you could match much better.
I'm not sure about cost with Katzkin though. [img]/ubbthreads/images/graemlins/ooo.gif[/img]
» Sponsor Links
»Garage Storage and Cabinets
