When I accelerate hard (almost WOT) from a dead stop my 04/04 6.0 X has a slight rumble in the drivetrain. Seems to go away once it shifts into second and goes through the rest of the gears quite nicely.
Anyone else notice this with their X?
Anyone know what it may be?
04/04 PSD X 4X4, Oxford White EB, October '03 build, all options except 2nd row captain's chairs and chrome step tubes, stock drivetrain, no flashes (still have quiet idle and original tow/haul), Donahoe 4.5" Spring Hanger Lift, High Angle Driveline CV Driveshaft, American Racing 17X9 Chrome Chamber Rims, Toyo 35X12.5R17 Open Country M/T's, PSD Badges, Yakima MegaWarrior roof rack with extension and King Cobra bike carriers mounted outboard, AMP Research Power Retracting Running Boards, Brakesmart Controller, Radius Rods, Firestone air springs with on board compressor, C-Bet'r mirrors, Marinco block heater plug in front bumper. Towing 28 ft. Sunline TT with slide room (7500#).
2001 Dodge RAM 1500 Quad Cab, Intense Blue/Silver two-tone, 4X4, 360, auto, 4.10 gears, Off Road Package, Daystar 2" front lift, 285/75R17 MT/R's, K&N Intake, Gibson stainless cat back, Line X spray in bed liner, Firestone air bags w/ on board compressor. Boss 7'6" plow.
My 2000 model does it. Not sure what it is, but I'm not losing sleep. It's still under warranty, but I figure they would screw it up worse if they tried fo fix it.
Rich DeFrancisco
2000 Excursion Limited PSD 4x4, Oxford White, X-code springs, F350 blocks, Husky Liners, Banks 4" Monster Exhaust w/Power Elbow, Hutched and Pooned, Ford Outfitters/Hella 60mm Driving Lights, Bilstein.
1998 BMW M3 Dakar Yellow (her car), 18" M-Parallel wheels, always at the mall.
1974 Truimph TR6, will be Sapphire Blue, in the process of restification.
Have noticed this "rumble" also occurs when accelerating while on the fly. Seems to disappear once the mass of the big beast gets up to speed.
I do not suspect a driveshaft balance issue as it is super smooth unless my foot is in it.
Looking for confirmation from others that this is not unique to my X. I recall one of the PSD 6.0 X's I test drove before ordering felt the same.
Looking for any ideas on what it could be. It's been too cold here in the Northeast to get under the truck and blindly nose around. I sure as heck do not want to take it to the dealer as I know they will be of no help and could create some new problem if I let them touch it.
Other than this rumble it seems to run perfect. It does romp a little on start up when cold if not plugged in but I expect that of a diesel. Idles perfect when warm.
Just kicking this question back out there to see if anyone new will respond.
I don't have firsthand experience yet but the local drive train guy, good rep, hangs at the local BIG ford dealer and tells me that they're changing out alot of new rear ends...might be good to have ford check it out...don't know if a TSB is out yet.
If the rear end assembly isn't leaking or doing anything obvious Ford is unlikely going to do much unfortunately [img]/ubbthreads/images/graemlins/shrug.gif[/img]
BILL
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
