Old 04-14-2007, 11:47 AM   #1 (permalink)
DVD System (factory) application question
I am thinking of bidding on a complete system however, the add states' '03-05 Excursion.
My question is this, my Excursion is an 2001 so, what is the difference? This comes with all the mounts and brackets, something tells me the harness to plug it in is already there.
Does anybody have experience with this and can confirm the harness?
2001 Excursion 7.3 PSD, 2WD, Limited Edition, 3.73 gears, 230,000 miles, Hpypertech Stage 3, Boost,Trans Temp and EGT, 22+ MPG, Love this SUV!
Dragracer61 is offline
Old 04-14-2007, 05:50 PM   #2 (permalink)
BenBone's Avatar
Re: DVD System (factory) application question
I think the factory head unit is different for the newer truck vs the older ones. This is importnant since they control the factory dvd and sound of the dvd thru the system.
2004 6.0l 4WD Limted Excursion
Road Armor Stealth Bumper with Titan Guard, BFG AT 305's, AR Mojave Teflon's, Tint, Stereo, Remote Start Alarm, Strobes,MBRP Turbo Back T-409 Stainless Steel Exhaust System, AFE Pro Guard 7 Mega System, Edge Insight, Coolant Filter, ARP Studs, Hybrid Turbo, EGR delete
http://bbonepics.shutterfly.com/
1999 Ford F250 CC LB 4x4 7.3L
DP F5, MBRP 4", AFE Satge II,Garrett Power Max Ball-Bearing Turbo,80hp injectors DM 3 pod, 95 Gallon Transfer/Toolbox Chest, BGF AT 295's, AR Mojave Teflon's,Tint, Road Armor Stealth Base Front Bumper with Lonestar Guard
BenBone is online now
Old 04-14-2007, 06:05 PM   #3 (permalink)
FamilyRide's Avatar
Check the For Sale forum though. There are always a bunch of newer OEM head units for sale.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 04-14-2007, 11:34 PM   #4 (permalink)
The system went from VCP to DVD as a running change during the 2002 model year
Not sure when seems like sometime in early 02. My 02 built in Sept of 01 was the VCP and it was mounted in the back of center consol.
So I think the wiring would be different.
I am sure you could make it work but you will need the wiring info.
Hope this helps.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 04-15-2007, 09:10 AM   #5 (permalink)
Rich_Kimball's Avatar
I put a factory DVD unit in my 02 EX when I had it that I got off eBay. No wiring harness in headliner area for sure. Head unit was not setup to control. You can get a module to accept line audio and control it with the CD changer function in the head unit. I didn't do that. I ran a wireless FM modulator to the audio out of the DVD player and just tuned the radio. A wired type that plugs directly into the FM antenna would work better but is harder to install.
I posted a writeup about this back in 03 and is in the archives somewhere.
Good luck on the brackets and mounting. I opted to order a factory bracket and dropped the headliner to install. Not too bad. Did it in the driveway in 20deg weather with the truck running in a couple of hours. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Happy trails,
Rich Kimball
2000 F350 XLT CC LB SRW 6spd 4x4 Toreador Red @375,750 miles
'08 Center Console,Ranch Hand Grill Guard, SBC ConO clutch w/Kevlar Bushing, DP Tuner (60T,80E,120R),Gauges,Ford AIS,Walker BTM,AIH delete,HPX Oil Crossover, Wicked Wheel,TurboMaster WG Contoller,Riley BRV+,Riley Boost Boots,EBPV Gut w/mod. pedestal,IH Bellowed (donut less) UpPipes,Final Charge ELC coolantw/heater bypass,Riley Coolant Filter,Ford AIC,Centramatic Wheel Balancers,115gal Aux tank,Firestone airbags w/cab control. Oilguard Bypass Filtration,DFA 'Cross Connect' Fuel Lines,
Rich_Kimball is offline
Old 04-15-2007, 03:05 PM   #6 (permalink)
FamilyRide's Avatar
Depending on how much you're getting it for, I'd think going after-market would open up the opportunity for much better quality and the chance to customize it to how you'll use it.
Old 04-19-2007, 02:17 AM   #7 (permalink)
+1 i have the pioneer avic-z1 (double din) and its prob the best $$ ive ever spent (parts wise)
'01 all blk EX
'95 blk/blk turbo cobra
'90 blk/blk mustang gt
'02 blk/blk explorer limited
cobra29svt is offline
Old 04-19-2007, 04:24 PM   #8 (permalink)
My Photos: (12)
your better off getting an aftermarket unit. you can find the audiovox 10.2 with built in dvd player for about 800. biiger and a lot less hassel than the factory.
99.5 F350XLT CC LB 4X4, 8" SUPERLIFT, 17X10 WELD SANDSTORMS, 40/13.50X17 GOODYAER MT/R, AIR INTAKE HEATER PLUG, AFE STAGE II, WHICKED WHEEL,JOHN WOODS TANNY STAGE II, DYNATRAC SUPER DUTY COMBO KIT, AGR ROCK RAM SYSTEM, 6 POSITON CHIP WITH JODY TIPTON BURNS, HOG 4" TURBO BACK EXHAUST, 4.56 GEARS FRONT AND BACK WITH ARB AIR LOCKERS, ARB AIR COMPRESSOR
ECLIPSE 5495, SOUNDSTREAM CONTINUUM, 2 PAIRS ECLIPSE SC8365 3WAY COMPONENTS, ECLIPSE SW9102 SUB. 10" FLIP DOWN SCREEN, PS2, AND LOTS MORE!
truck pics
2002 EXCURSION LIMITED 7.3TDI, AFE STAGE II, DIPRICOL GAUGES, DP TUNER F5 CHIP, 4" HOG PERFORMANCE TURBO BACK EXHAUST
2005 VOLKSWAGON JETTA 1.9TDI, KERMA QLOADER, 100 HP AND 40+MPG IF I AM GOOD.
WAMPAKU is online now
» Sponsor Links
»Garage Storage and Cabinets
