Has any Power Stroke Excursion owners done any dyno testing? Would like to see how their testing went, and to compare it to a friends results. Thanks, JCL First post.............
Dave. Thanks for the reply. Thats fairly close to the HP readings we got. The best was 249.1 HP, but the torque was large at 778.5. The mods were 4" Grand Rock QP exhaust with 4" STS HP Baffle, and the Superchip.( Turbo Diesel Excursion-2WD)
We did get a "stock" run before doing the mods. That got 181.8 HP, and 431.7 torque.
With just the 4" exhaust/baffle upgrade,, it pulled 182.4 HP, and 540.8 torque. Not to bad for a 4" exhaust/baffle up grade.
These were all done on a Mustang Dynamometer (inground) and 4 pulls back to back. Best one chosen.
Would be curious about others tests to compare. Thanks for the welcome. JCL
Wow . .I'm glad to see someone else having huge torque numbers. Mine was a single pull on a portable mustang, and my torque number was 698. It didn't seem to make sense to me that it should be that high. I'm not sure if torque is reduced 20% for drivetrain losses though. Possibly it isn't. If it isn't then mine was right on the money for what I would have expected.
Take care,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
Dave. It will be interesting to see if anybody else is in the ballpark with about the same mods.
We did put on a K&N air filter set up, but only jumped the torque 4 Lb's. Needless to same that particular model went back.
I had another friend several weeks ago get the same large increases with a Dmax. Same set ups. The shop that had the dyno said these were true readings. I mean you have to + or - the readings somewhat, but not a lot. There are still variables, just like anything. Thats why we did 4 pulls back to back. Happy Holidays. JCL
The reason I don't know about Torque driveline losses is because of the way in which it's measured. I've done some reading but can't find a good answer. The Horsepower is definately reduced because it's a function of torque x RPM divided by 5252. So if you have slippage and friction loses I can see how you'd have horsepower loss. (it's a measure of work). Torque on the other hand is a measure of twisting force. If you had the TC locked when dynoing then I'd think the only loss would be the friction of the driveline on it's bearing surfaces, across the gearset. This wouldn't be as great as it would be for horsepower.
Of course if I knew what I was talking about then I'd know the answer! [img]/ubbthreads/images/graemlins/smile.gif[/img]
The main reason I question whether there's the loss is that the 698/705 number would be reasonable with no losses.
I was at a Dyno day in Meridian Idaho and my excursion '00 ran 218hp 501tq stock, 315hp with a bullydog dyno dominator chip and 5" exhaust, 407hp 817tq after I added my propane.
03' 6.0L psd/ Bully Dog chip, Bully Dog 4" exhaust, Bully Dog propane
Last Dyno: 281hp 459tq (stock)
449hp 862tq (w/upgrades)
You'll spend less and get more with BullyDog Technologies. They also have great service. They will send u a bran new chip if anything goes wrong. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
WantmoreHP. Looks like good numbers to me. My friends stock numbers were fairly close to yours.You really got some HP gains with the chip and the "5" inch exhaust. What was the torque with that set up? I have another friend with a new Excursion thats going to dyno test after the first of the year. It's a 4X4 with 4" exhaust, STS Baffle, Dual chip, and Propane. It should be very interesting to compare yours and his. Will keep you posted.
Thanks,JCL
