Hi, hope I can answer some questions for ya. first of all, a little ground work has to be established as I don't know for sure what you did.
You can't mix wire types with the thermocouple (TC) as it makes another temperature junction. If you purchase more TC wire, (use type "K" wire only), you have to make sure that you hook the same wire color together. When you hook the wires up, you have to use a screw type tightner (preferable) or a crimp connector as soldering them makes them go haywire, too. In order to test the TC, pull it out and hook it directly to the gage and them QUICKLY hold a match under the tip, burning
and see if the gage moves. If nothing moves, either the TC is bad or its the gage. Once you get that working, then you can tackle the TTM and you can use the same TC wire for that. e-mail me if you have any other questions.
Johnm
johnm@me.unlv.edu My F250 PHOTO's
Propane Install
HOT ROD's
[This message has been edited by johnm (edited 11-02-2000).]
Sorry, it takes me so long to respond. I have difficulty typing and seeing small type. I can read better if it is in caps, so I'm not shouting, just trying to see what I type.
2004 VW Golf TDI - Automatic, 100 HP Diesel gets 42 MPG around town. XM Satellite Radio
2001 Monaco Knight - 265 HP Cummins gets 12.5 MPG towing the TDI
click on or cut & paste for forum rules
http://www.thedieselstop.com/faq/forumrules.php3
