Re: Engine Oil Loss
Interesting thought Andy, and it makes sense to me, I have never had any problem with oil consumption, it uses a half of a quart to a quart and half at the most in the summer heat and only if running very hard (fast) in 4K so I hardly ever add any. But last time we changed it my youngest was helping and we over filled it a bit, close to a quart. I did not think it would bother it so I checked during a long drive right after and still high but no foaming so I let it go. Now the interesting part after about 1000 miles the extra oil was gone, right at the full mark, and now 2k after that it is down just a bit more, very normal. Your dealer may be right I would try leaving it a ˝ quart or more low and see if it stays there however you are just now fully broken in as mine used a several quarts between changes when new and did not “level off” till about 20K I would not expect it to go back up till well over 200K or more as I have had gassers that did almost that good, except for a little blue smoke on start up when they get about 175k on them. I don’t think I would worry about running it a little low, a friend of mine took his service truck to the dealer and got it back with a note that it was 6 quarts low, he never figured out how that happened but it did not seem to bother it. The mark on the stick is for 2 quarts just try it in the lower half and see if the dealer is right.
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
