Engine won't stay running
2000 Ex 7.3L engine starts fine but it runs very rough and dies within a minute. Can restart but same thing happens. Codes I get are P1209 - injector control system pressure peak fault, P-340 - CAM position sensor circuit malfunction, P-1211 - injector control pressure above/below desired.
I had the CAM sensor recall done by Ford in September 2009.
Can this be a CAM sensor or the wiring harness under the valve cover problem? Or something else...Thanks
2000 Excursion, 7.3L, 4x4, Dueler Revo 285/75/16 Tires, DP Tuner F5, 60 econo, 80 econo, Decel, 80 tow, 120 race, 140 extreme, 4" exhaust, AFE stage II w/pro guard 7 filter, 6.0 Transmission Cooler, 3 gauge Pillar Pod w/Di Pricol gauges (EGT, Boost, Trans Temp), Rancho 9000X Shocks, ART Cryogenic Rotors, Hellwig rear anti-sway bar, 203* Stat, HID 55W conversion kit
