ex brakes - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 10-26-2009, 08:18 PM   #1 (permalink)
ex brakes
Hello everyone, I have a 2003 ex and im changing the brakes and rotors.Has anyone changed the rotors and how difficult is it.thanks all
over the edge is offline
Old 10-26-2009, 08:38 PM   #2 (permalink)
Matt0987's Avatar
I have done it and it is not bad.
Remove the tire.
Remove the entire caliper unit. 2 bolts I think.
Be careful not to drop the caliper. I usually take a clothes hanger, cut it, bend it, and make a hanger out of it to hang the calipers on from something sturdy. I usually put the hook through a caliper bolt hole at one end and something sturdy at the other.
Slide the old rotor off. Slide the new one on.
Replace the caliper. Bolt it on.
Replace the tire. Bolt it on.
Some manufacturers recommend that you clean the plate at the base of the studs that the rotor slides against. I usually use a pnumatic wire brush.
I recommend that you get out your torque wrench and torque any, and all, bolts.
And let me say that I am not a mechanic. Rotors are easy.
The pads are, I believe, more work than the rotors. Simply because you have to make sure the springs are properly in place and the anti-squeal goop is in the proper locations.
Note that there are rotor recommendations on this website, if you have not purchased yours yet.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer Yaesu FTM-10R & a Comet CSB 790A
Matt0987 is offline
Old 10-27-2009, 09:07 AM   #3 (permalink)
njneer1's Avatar
Ditto on what Matt0987 said.......... make sure you have a good jack, jack stands and a good level solid surface. These things are NOT lightweights !
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
njneer1 is offline
Old 10-27-2009, 09:11 PM   #4 (permalink)
Smile lovin my ex
Thanks guys i did the front today,brakes,rotors and new calipers.Back tomorrow.Anyone do hubs on front?Where are the best place to buy hubs and what kind?THanks for all your help i couldnt do it without my dieselstop brothers and sisters.
