Ok so how many of you have had the EBPV removed on your EX when you did the exhaust? i have had the SES light on ever since because of the 475 code and its driving me nuts...I understand (I think) correctly that the EBPV and the exhaust pressure sensor are tied together right? i have the eliminator for the pressure switch but not the EBPV. do I have to have both? My F350 was gutted and I have never seen the SES light ever on that truck...Help!
Tom
CTFD
Contact Info.. tom@reynolds-excavation.com
512-762-1485
LATE 1999 F350 CC Dually 2WD,4" stainless Magnaflow.Highly Modified GT38 Turbo
DP-Tuner 4 Pos. chip, PS2000,4" intake with fleetguard filter ,Suncoast Tranny With Triple disc T/C, Lunar Guages
12 Speaker 770 watt Fosgate,Sony and Infinity system with (((XM))), Stull Billet,BFG's and acetoned badges.ART rotors, More to come. 8100lbs.
1/4 mile 14.80 @ 94.24 MPH
2000 Limited 4X4 Excursion Toreador red and tan,(((XM)))Rancho RSX's, Hellwig anti sway,V codes on front, skyjacker dual stabilizer, Edge Evolution AFE with PG7, Eddins House of Diesel 4" Exhaust with Polished 5" tip, Suncoast tranny with triple lock, 15.1" DVD monitor,now rolling Akuza Bounce 20's w/ Toyo 305/55/20 AT's
I'm not sure I follow. I had my exhaust done and nothing but the exhaust was touched and I've never had any CEL or DTC related to it.
The EGR and EBP were replaced last December but that's it.
Try the SP Diesel EBS eliminator. $30 and your problem is solved. Installs in 5 minutes. I've had good luck with mine. [img]/ubbthreads/images/graemlins/smile.gif[/img]
'99.5PrairieTan/XLT/4x4/CC/SWB/7.3 <u>PARTS FROM DI:</u>6 pos Chip, MM inj., Custom DIIC, AFE2, Fass 150/180, Garrett GTP38r, Full fuel system w/ Billet sump and reg. return, HX mod, Built tranny w/ PI TQ. Conv., 4 pod w/ Autometers, Centric slotted rotors/pads
If the EBPV is the butterfly valve just before the down pipe, yes mine was removed when the Banks Power Elbow was installed. No issues, warning lights, etc.
I do miss the wooshing sound from our X as it was warming up but that's about it.
-Mike
__________________ 2002 Excursion ~ Limited Ultimate ~ 7.3L PSD ~ 4x4
Mineral Gray, Limited Premier Group & Monochrome Package, two tone leather interior (pre-Eddie Bauer), TTT Mirrors, 3.73 Limited Slip, F250 Lariat wheels.
Kentucky Born: 4/9/2002 Improvements: 2002 PSD Badges, and lot's more!!
I got the eliminator already...but does the connector at the EBPV need one also? this is what I am trying to determine and to see if it is an
"Excursion" thing....any guesses????
Tom
CTFD
512-762-1485
