I'm having problems starting my 01 PSD Excursion. At first, I would hear this clicking noise which seemed to come from the fuse box under the hood, directly in front of the driver. That stopped for a while, but now when I go to start the Ex, all the lights go dim, it won't turn over and I get the code for low system voltage.
As soon as I remove the key, the interior light goes back on.
I have checked both batteries with a voltmeter and cleaned the contacts. I'm convinced it's not the batteries.
It seems like it's a relay or fuse, but the fuses I've checked seem to be ok.
Any idea where I should start looking/replacing parts?
thanks
I bet it really is the batteries, especially if they are the originals. I'd suggest having them tested, and replacing both if either test bad. A voltmeter doesn't put enough of a load on them to tell if they are good or not.
Mark
''Wise men talk because they have something to say; fools, because they have to say something.'' - Plato
2001 Excursion 4x4, v-codes, Western Diesel guages, AIS with fender sleeve & zoodad, MBRP 4" exhaust, Tru-Cool Max tranny cooler, 203* thermostat, BFG AT 285/75-16's, RS9000X's, Rancho steering stabilizer, tightened steering box, Hellwig sway bar, Air-Lift springs and compressor, Draw-Tite trunnion bar WD hitch, SUVlights.com harness, PIAA driving lights with homemade harness, Cobra 25STWX radio
thanks
Welcome to TDS....
Now it would help now and in the future if you gave a tad bit more info. on your X.
I say it's the batteries too. These beasts need almost full batteries to turn over fast enough to fire things off. Weak batteries and no startie.
I recently had a intermitant rough idle and surging when in cruise control. My truck was at the dealer for 7 days and they replaced my engine wiring harness, the cam sensor and my fuel pressure rugulator. all of the above info., but I still have an intermitant non starting issue. I replaced both batteries and still have the non start issue. Still working on this one. I have a 04 6.0l with only 28K on it in AZ.
__________________ 2004 4x4 FX4 Lariat color White F250 6.0L crew cab with 6 in. lift, BF Goodrich A/T 315 x 70 x 17, 3.73 gears, 4 in. Magnaflow exhaust from turbo with 24 in. X 5 in. end tip, Fox Racing shocks, Donahoe Racing dual steering stabilizers, Firestone Air lift (air bags) in the rear, all to hual a 2006 28ft. Rampage 5th wheel toy hauler with loaded weight of 12,500 lbs. ebehrman@cox.net
I recently went through an intermittent non start issue.
After I got rid of the piece of junk Visteon light duty starter these X's come with, problem solved.
My symptoms were, turn key to start, get a click, keep trying...keeps clicking (one click per key start), then randomly it would fire right up. This was a random problem that slowly got worse.
__________________ TurboDave, EWCS(SW)USN Ret H&N Turbo 6 Racing
Seviervile TN A MAN AND HIS TRUCK, IT'S A BEATUFUL THING 01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, TTS Race Magnum (original owner) 86 GN (original owner) 87 GN (second owner) 08 Honda Accord EX-L
Well, just got word from the dealer and after they replaced the CPS, it fired up but runs rough. In addtion the alternator isn't putting out very much and will need to be replaced.
Unfortunately, I don't have a lot of choice, so they're going to replace the alternator and do a compression test.
I help they gave you an Estimate. I can change my own CPS (I don't that is your problem) for under $75.00 and ten minutes. The ALT for about $250.00 or less in about 15 minutes.
I still think you have a battery, Alt or starter problem.
Best Regards,
Moxie (from 1828 Noah Webster Dictionary) : The ability to face difficulty with spirit.
I just got my X back today and it was something you wouldn't think of. We checked over all the fuses and so forth and everything was good and we couldn't find a problem. I got sick of looking over the truck so I had it hauled to the Ford dealer here. Hooked up to their computers they found the problem right away. It was the stupid ignition box that went to hell.
I used the truck that morning and afternoon but when work closed there was trouble. It started but shot off right away. It did it again and that was it. Turning the key would just turn the truck over and over and not 1 pop.
Older cars/trucks didn't have all these computers and were much easier to fix. Need a Good Brain to figure them out today.
Guys I sure am Sick of my FORD. I'm back to where I started. I was hooking up to my trailer so I got out to see how far away I was. I got back in and put it in reverse and hook the hitch up. Now I was going back the trailer into the shop. I put it in reverse and it did not move so I put it in drive and it did not move. I then put it in Park and it shut off. Tried to start it and it just turned over again. To have this problem fixed today I had to pay $535. What a waste of money. I'm sure not going to pay them again tomorrow when it gets towed there.
I think I might just trade this in, once it's fixed, on the NEW CHEVY DIESEL 4 door TRUCK.
My best advice to you is to find a good diesel shop.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
