Excellent in the snow - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 02-18-2010, 10:30 AM   #1 (permalink)
I am still amazed every time I get the Ex in the snow as how good it is. I have a 2WD and am amazed at how good it goes. Also it's a very willing 'hook slider'. Very controllable rear end slides under power!
Just how well is the 4WD in the snow? I can't imagine how good it would be.
-2000 7.3L Excursion Limited. 2WD. White with tan. Hellwig rear anti-sway bar. Bilstein shocks. Rear air bags. 185,000 miles.
2000 VW New Beetle TDI
2005 VW Passat TDI...totalled
2006 VW Jetta TDI
DR.billZ is offline
Old 02-18-2010, 08:03 PM   #2 (permalink)
With the Revo's pretty much unstopable
I have often driven on ice with Far Less efffort than it takes to walk on the same surface
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 02-19-2010, 11:11 AM   #3 (permalink)
i couldnt keep mine from doing donuts in the warehouse parking lot!!!! Must be something wrong with mine.
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 02-19-2010, 12:01 PM   #4 (permalink)
boomboom's Avatar
I think your FUN FACTOR might be set too high !!
boomboom is offline
Old 02-19-2010, 01:49 PM   #5 (permalink)
Its called truck ballet while the wife is in the grocery.
Beast is offline
Old 02-19-2010, 02:36 PM   #6 (permalink)
Its not often we get to "Ballet" down here but with 14.5" of snow last week I had to "parking lot pirouette" a little!!!
Yea the pregnant wife got all bent when I did it with her!!
TXANGLER is offline
Old 02-20-2010, 10:52 AM   #7 (permalink)
MotionMan's Avatar
Of the 217,000 miles on this truck I bet 2/3rds are trips from Holland, MI to Grand Marais, MI....372 miles all in snow, sleet and freezing rain, with 285 Coopers I can't get this truck to move on the Hwy. I have been in 7"s of snow going 70 with the cruise on, I blew by a cop going 30 and dusted him like a desert storm, he looked over at me as I passed and never even tried to stop me. I did have one time at about 60, passing another slow poke and the rear broke free, I was in 2wd and I swear the truck was sideways in the hwy....I let up, steered like crazy and it came back....in the same lane with a car next to me.....it was a little scarry but I pulled it off. I truly believe that if you get a chance take your truck to a vacant lot and just spin until yout dizzy, its the only way to know what the truck will do in a situation and it teaches you how to steer out of it. I do it all the time and it has paid off many times. Many times I load split wood from the front seats to the back and to the ceiling....the weight glues me to the road and nothing will move me. One time my sled got stuck in a slush puddle and I had to drive the X down a trail in 14"s of snow to pull it out, with all the wood it just pushed tru the snow, often over the hood, and I got to it before it froze in.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
MotionMan is offline
