has anyone had to replace their key fob and chipped key. Is there anywere else to buy them except from ford. i'm down to only one key now ,lost the other with the fob. i'm told ford will need the truck to reprogram the new key since i don't have two keys. Whats the scoop on this.Also if the truck needs to go back in to get the key programmed does the superchip need to come out to get the correct program. can i get a aftermarket and do it myself.
offtopic -whats up with the search engine on this site. i tried to do a search just for keys and i still get every post that has been posted weather or not it has any thing to do with keys or not. i've noticed this for couple of months now. kinda useless. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I believe you will need to go to the dealer. Unfortunetly its a rip off. Once I found out you needed two keys I went out and got two more. If you have two you can program them yourself.
The transponder keys for the Excursions are available on Ebay,I'm thinking about buying an extra pair to program up.
To have the new key programmed you'll have to go to the dealer as it requires the original two transponder keys to program additional keys so if you only have one you're stuck at the dealer.
I think the cost is like $100 or something in that area.
Contact www.1stfordparts.com or www.fordpartsonline.com to get discount pricing on blank transponder keys if Ebay isn't your first choice [img]/ubbthreads/images/graemlins/wink.gif[/img]
__________________ 2002 Ford Excursion 7.3L 4x4 XLT 9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas CLICK HERE for more Information & Register Here
I would put the truck back to stock. Yes you need 2 keys to program any others. The first 2 keys programed will be the original keys and any of the others, up 8 in total, will be the copy's. The dealer should charge about 1/2 hour plus the key.
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
Gotta love the "Should" [img]/ubbthreads/images/graemlins/wink.gif[/img]
I was told around 75 for the key and 45 for the fob at the dealer. Looks like i'll just get it at the dealer since it doesn't look like i'll save enough to hassle getting them off the net.and yes i think I'll bite the bullet and get two just in case there is a next time.
I was told by the guys at my local Ford Stealership that it would cost $25 for a key and $75 to program it. But you could buy as many keys as you want and have them all programmed for $75. I only have 1 key so I was going to buy 3 blank keys and get them programmed for a total of $150.
The secret is in tipping a good service rep. Mine gave me a new key when I needed it, and a mechanic that I take care of programmed it for nothing. It takes all of about 3 minutes to do it.
scott
01 Black Excursion XLT PSD 4x4, loaded, 3.73LS, 305/70R16 Goodyears, Husky mats, Manik tube steps, J & J grill, K&N, Clifford Alarm, 4" exhaust-turbo back, 5" Magnaflow SS tip, Dynomax Race Magnum sound suppressor, Clear corner lens, back door storage bins."Scotpart 4X2 liftgate strut mod", 2002 headlights, Hellwig sway bar, Monroe Shocks, American Racing Wheels, Driver's A-post handle, Go Rhino 3000 front push bar and rear step.
It actually takes 10 minutes to gain security access to the system if you only have 1 key to start with. Then the programing goes from there. In all cutting the key programing checking the system figure a good 1/2 hour.
My new 2004 came with two keys, and I bought three more for $25 each and programmed them myself. According to the dealer, you have to have the two ORIGINAL keys in order to program others. In other words, if you only have one key you'll have to pay the dealer to make you more - the duplicates will not work.
Wayne
2004 X Limited. Medium Gray Metallic, 4x4, 6.0L Diesel, DVD, LimitedSlip Differential, HD Tow Group, Transfer Case Skid Plate, Radius Rods, Remote Starter, Magnum Hitch, Nitto Terra-Graplers, Running Boards Removed, Large Payments.
I'm dealing with a chipped key on an '04 explorer. The truck had a remote start installed and in doing that they had to put a key in a box in the truck. I am wondering if I can hit the remote start to trick the explorer into thinking the 1st key is in. Starting it with the key I have for the second key. And using a new key as the third. Will this program the third key?
-Rich
__________________ '04 F250 Lariat PSD CC FX4 SWB, Auto, Dark Green Satin, Med. flint, Heated captains, ESOF, Remote start, AIC w/ wood grain cover, Chrome cab steps, Reciever hitch, Power rear slider, Clearance lights, Rubber mats, Rhino, Extang bed cover, XM Roady2, Brakesmart , PIE
'05 Isuzu NPR flatbed dump
'04 Isuzu NPR diesel flatbed dump
'90 F350 box dump
Kubota L4240 HST (Front loader, Harley rake, Rototiller, Brillion Seeder, pulverizer) , Perma Green Centri (ride on spreader), Walker Mowers (the best), Shindaiwa and Stihl
Toys:
36' Pacemaker Sportfish
'90 Mustang GT 5.0
'90 Jeep Wrangler 4.2
'72 Triumph Spitfire
15' Boston Whaler 70hp Yamaha
Yamaha GP760
Sunfish
1...Some and i am sure there is a few Key Smiths that mite have the correct machine to do the Transponder Keys. Try them...sometimes they are cheaper and then sometimes they are not!
2....Find a local REPO Shop...MOST will have the machine to do the Transponder Keys....I know we do!!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Since you're checking in you must be volunteering your services for the Excursion crew [img]/ubbthreads/images/graemlins/wink.gif[/img]
