My 2001 x has a rusted out hitch and I can't find a fit guide from any manufacturer that list the x. Has anyone had a problem with the hitch rusting behind the receiver, mine has rusted to about half the original thickness. Any info on a replacement would be great.
To my knowledge no hitch manufactures make a hitch for the Excursions except for Pullrite and there big bucks, see my signature pics. All the Excursions came from the factory with a hitch and it was a part of the blocker beam technology for the Excursions so it was senseless for a hitch manufacture to produce one. You will have to get a new hitch from Ford or have yours rebuilt. My question is if the trailer hitch is rotted out what is the rest of the Excursion like??
FMT
__________________ Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
It is a riveted on unit because it is a part of the safety feature of the truck, It has to be there, like the crash bar behind the valance in the front. No one makes one as economical as OEM. It will fit perfect. The problem is getting the old one off. The best way is heat but you are awful close to the fuel tank so most will chisel them off. I am constantly sanding and painting mine, if i could sand blast it I would rhino line it.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
there are bolted on with some of the bolts having head that snap off when torqued corectely. you can grind the heads off, drill them out or pull the fuel tank and burn them off with a torch. I drilled mine out and replaced the bolts and speed nuts with parts from ford so you can easily take them off, sounds like you need to get a new one coat it wiot POR15 same for your whole truck
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
well, ya it's expensive. I believe the price includes getting the old one off. Not sure. I was debating getting one for my X because I have in excess of 1200# TW. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Google them and find out.
2001 PSD Excursion 4x4 Limited 7" Superlift Softride lift, 315/75/16 Toyo M/T, Fox shocks, Hellwig rear sway-bar, Air-lift airbags, Autometer Ultra Lite tranny/pyro gauges, DP tuner, Swamps 175/146 single shots, Wicked Wheel, AFE Progard 7, 4" turbo-back exhaust, John Woods tranny w/ 6.0 billet TC, and T/C lock-up switch, Tru-Cool Max tranny cooler. Topped off by Jody's famous tunes.
Audio System: Eclipse 8053 head unit, Arc Audio XXK4050 amp, Arc Audio XXK1500 amp, 6" Morel Integra, JL12w6v2.
I know the OEM hitch is a pain to get off, I heard my buddies at the dealer whinning when they did mine, twice! They used a torch to get the bolts off.
I did mine by starting out with a small drill bit in the center of the one time bolt head, the I kept using bigger and bigger bits. you only have to drill as deep as the head of the one time one way bolt and then give it a good whack with a BFH. note run the other bolt out with an air impact then lightly put it back in before working on the one time bolt.
I am pretty good with a torch and with the tank out of the way I could get those bolts out in less then 5 minutes.
I said with the tank out of the way and if you do the regulated return thats the time to do it. like I said I did it the hard way, ford's way
