Old 09-15-2005, 10:39 PM   #1 (permalink)
BenBone's Avatar
Excursion rear air bags....
I would like to add air bags to my excursion. Is there a kit specifically for our excursions? I assume its not that hard to install...where are the most common places for the tank and compressor? Can you run other things off of the compressor? (air horns) If this has been discussed before excuse my repost....others on here have wondered too.
2004 6.0l 4WD Limted Excursion
Road Armor Stealth Bumper with Titan Guard, BFG AT 305's, AR Mojave Teflon's, Tint, Stereo, Remote Start Alarm, Strobes,MBRP Turbo Back T-409 Stainless Steel Exhaust System, AFE Pro Guard 7 Mega System, Edge Insight, Coolant Filter, ARP Studs
http://photos.thedieselstop.com/show...t=1&thecat=500
1999 Ford F250 CC LB 4x4 7.3L
DP F5, MBRP 4", AFE Satge II, DM 3 pod, 95 Gallon Transfer/Toolbox Chest, BGF AT 295's, AR Mojave Teflon's,Tint
BenBone is online now
Old 09-15-2005, 11:17 PM   #2 (permalink)
Re: Excursion rear air bags....
I would like to add air bags to my excursion. Is there a kit specifically for our excursions? Yes.
I assume its not that hard to install...where are the most common places for the tank and compressor? Some install Tank & Compressor on the frame behind the transfer case, or on frame behind running boards, Compressors under hood where one battery is currently by moving both batteries to one side.
Depends on the compressor, but usually they will handle most accessories.
If this has been discussed before excuse my repost....others on here have wondered too. Try a search in the Superduty Forums too, many posts & photos on many different installs. Good Stuff!
Dennis
My Photos----- BTS BUBBA "Life Member"
2002 7.3L Excursion 4x4, FTVB, MBRP 4" SS Exhaust, Rancho 9000X shocks, "V" code Front Springs & "B" Code Rear Springs, Ride Rite AirBags, Rear Hellwig Swaybar, Cut Front BumpStops, DieselSite Ext Trans Filter Kit - Coolant Filter Kit & 203 stat, "Scotpart" mod, "Hutched & Pooned", "LandYot" Radius Rods US Gear Overdrive 75mph @ 1750rpm's
2001 7.3L F350 CC LB 4x4 5" Exhaust, pillar guages, BTS Trans, US Gear Underdrive, DP 6 pos chip, V10 Trans Cooler, DieselSite - Coolant Filter Kit, Evans Coolant, 203 stat, DI reg Fuel Return, GT38R BB Turbo, AFE 2 Intake, Banks Intercooler, Air Rite Bags,
2000 Excursion Limited V10 4x4 7" Lift
"Family of 5 saved by Grace"
Snowman269 is offline
Old 09-15-2005, 11:19 PM   #3 (permalink)
Here is a link to a system I had on my 02
Bags with surge tank
I did not have a compressor but the surge tank did help with the bounce some have had with bags.
Do some reading the info is here
Here is the info on the above system
Write up on bags with tank
Hope this helps
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
