Excursion Shock replacement costs and difficulty - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 03-13-2007, 11:40 PM Thread Starter
detroitfd's Avatar
Just thinking of replacing shocks, and wondering what they cost and how hard it is...
81k miles and they're ridin pretty hard...Not looking for something for offroad, just dependable for towing (7k loaded). Thanks!
Jerry
2000 Excursion 7.3L PSD 4X4
DP-Tuner F5 : no start, stock, 40T, Decel, 80T, 80E - AutoMeter A pillar w/ 3 Phantom gauges - DIY Tymar intake w/ S&B conical filter - Zoodad mod - Suncoast Extreme Duty Trans rebuild w/ TransGo Shift kit, Amsoil synthetic ATF & Magnefine inline filer - BD Triple Disc Billet Torque Converter - 4" Stainless Steel Turbo Back (4" down pipe) Magnaflow exhaust - ATS Turbo housing and 4" intake sleeve - Turbo Master Wastegate Controller - HX Oil Crossover - Morse Ceramic brake pads - Monroe Reflex Shocks - Energy Suspension Bushings - IC foil wrap delete - Fumoto Oil Valve - 08' Aluminum Rear Differential Cover - White Night reverse light system - Garmin StreetPilot c340 GPS - 6.o tranny cooler - Dieselsite Coolant Filter w/ CAT ELC coolant - Amsoil Single Bypass Oil Filter w/ Rotella 5W40 synthetic oil - APC white gauge cluster face - Dual in-dash DVD w/ Infinity Reference speakers & Blaupunkt 200A powered sub - 4.5" LED marker/turn lights in front bumper - ViAir HD onboard air system w/ 380C compressor, 2.5 gal tank & Grover stutter tone air horn - FireStone RideRite suspension air bags -
TOWING:
2004 Dutchmen 31BH travel trailer
detroitfd is offline
post #2 of 13 (permalink) Old 03-14-2007, 01:03 AM
ScaldedDog's Avatar
Re: Excursion Shock replacement costs and difficulty
It's only 10 bolts for all four shocks. You'll need an extension to get to the top mount on the rears. I did mine in under an hour, and I work slow. The concensus around here seems to be Bilsteins, but I put Rancho 9000's on mine. I think I'll try Bilsteins next time.
Mark
''Wise men talk because they have something to say; fools, because they have to say something.'' - Plato
2001 Excursion 4x4, Western Diesel gauges, DP-Tuner, T500, ATS housing, TM wastegate controller, 6637, MBRP 4" exhaust, 6.0 tranny cooler, BTS, BFG AT 285/75-16's, Red Head steering box, Hellwig sway bar, v-codes/AirLift bags
ScaldedDog is offline
post #3 of 13 (permalink) Old 03-14-2007, 10:55 AM
Feedback Score: 3 reviews
Takes maybe 1/2 hour to 45 min. check Donahoe Signature shocks out, a little more $$ but won't corrode or rust since they are cleared.
Cary
caryt is offline
post #4 of 13 (permalink) Old 03-15-2007, 10:42 AM
boertje's Avatar
My Photos: (29)
I used Bilsteins. I am not looking back and am very happy with them. Easy job. About 30-60 minutes worth.
2001 VW NB TDI speed.
SOLD: '02 PSD Excursion LTD Ultimate 4X4 Mineral Gray, PSD badges, Banks Exhaust, AIS air filter, DP-Tuner, Fuel mods, V code (2C3Z-5310-HA, AKA 3C34-5310-ADA) and modified F code (6C34-5560-F aka 5C32-5560-FA) springs with Timbren rear overloads, Bilstein shocks, hellwig sway bar, Powerslot Cyro rotors with Hawk LTS pads, IH CPS part # 1826899C93 (original CPS).
boertje is offline
post #5 of 13 (permalink) Old 03-15-2007, 11:36 AM
Location: Imperial, MO - 20 miles south of St. Louis, MO
Bilstein's...BE5-6209-HO on rear and BE5-6208-HO on the front. I've had mine on for I believe over 70k miles and have towed many times with them...they work great for me.
*SOLD - 2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day including towing),Cryo treated Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Harley much cheaper on fuel! Joined the other side with a 2004 2500 HD CC SB GMC Duramax...got a great deal!!
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
post #6 of 13 (permalink) Old 03-20-2007, 09:10 PM
Jerry,
I used the Blistens as well.
I don't see that you have the rear sway bar installed yet?
If not, do that soon.
The shocks make a small difference but the sway bar is the best easy install for improved handling I have installed so far.
The shocks need replaced solely because: if you look close, you will see the OEM shocks leaking!
Chuck
2001 Ford Excursion 7.3 New Bilstein shocks, Hellwig rear sway bar, Baldwin Coolant Filter, 81000 miles-1/09/2008, UPDATE 100,200 Miles 7/28/2009, Update 105,000Miles: 12/2009, 4/2015 150,000 miles
1999 Honda Valkyrie Interstate- Sold
2007 BMW R1200RT
1991 Ford Taurus- Donated
2002 KIA Sedona- SOLD-
barlowcw is offline
post #7 of 13 (permalink) Old 04-01-2007, 03:55 AM
Bilstein for me too....just did them and they work great. I should say that I don't know much about the others, but they made a big diff over the OE.
dohannes is offline
post #8 of 13 (permalink) Old 04-01-2007, 11:41 AM
aklim's Avatar
Bilsteins for me too.
I would advise you to change the "nuts" that the rear shocks screw into. Sometimes they break when taking them out and sometimes they break after you put the screw back in. Ask me how I know. Best get 4 of them, replace them and forget about it.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
post #9 of 13 (permalink) Old 04-01-2007, 01:40 PM
turbodave's Avatar
Anybody have the Bilstien numbers for a 4x2?
TurboDave, EWCS(SW)USN Ret
H&N Turbo 6 Racing
Seviervile TN
A MAN AND HIS TRUCK, IT'S A BEATUFUL THING
01 Excursion LTD (EBM3) 7.3L, PSD, Turbo, 4X2, 177K, TTS chip (original owner)
86 Buick Grand National (original owner)
87 Buick Grand National (second owner) (Sold)
12 Lincoln MKT, 3.5 twin turbo Ecoboost
turbodave is offline
post #10 of 13 (permalink) Old 04-01-2007, 05:07 PM
FamilyRide's Avatar
Here.
Looks like BE5-6206-H0 front and BE5-6207-H0 rear
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #11 of 13 (permalink) Old 04-03-2007, 10:34 AM
turbodave's Avatar
Here.
Thanks! Gotta get rid of these KYB's soon. They're worse than stock!
H&N Turbo 6 Racing
Seviervile TN
post #12 of 13 (permalink) Old 04-03-2007, 11:49 AM
FamilyRide's Avatar
Glad to finally hear some real world feedback on KYB's. So many people have such good things to say about them as a good cheaper alternative, but that's when they are brand new.
post #13 of 13 (permalink) Old 04-03-2007, 11:18 PM
The KYB's work pretty good on some cars I've owned but not nearly as good as the adjustable Koni's that came stock on the Omni!
I've never done shocks on the 235K mile F250 or 171K mile Excursion.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor, ais, adrenaline pump, muffler delete
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited triple pod Rancho 9K's (JUNK SHOCKS), muffler delete
02(12/01)Excursion PSD 4x4 Limited Ultimate No Boundaries Edition 175/146 swamps, hydra, S&B
03 Excursion PSD 4x4 Eddie Bauer (parts vehicle, 120K miles) CRUISE CONTROL FIRE VICTIM
04 & 09 PJ 15k dump trailers 04 H&H 9K tilt bed 07 Dreamshak Hydraulic 20ft toy hauler/fish house.
86GLHS is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
