You May be in for a surprise as I was, there is less than a 100#s difference in the front to rear. The front does weigh a bit more when empty but not by much. a full tank a just a little gear you are at 50% 50%. Don't ask me what the heck is back there that adds up, it doesn't sound right but others have scaled out about the same.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available. Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket) 2005 Ex and Specs and Pictures of 2002 X
Works for me, the total weight adds up really fast........ I just seem to be finding signs that my tires have been overloaded and thought maybe it was because the combined capacity of the front two wasn't enough to carry the weight - guess that isn't my problem......
Thanks for your input........ BTW, is there a spec I could look up somewhere?
2001 'X' Ltd 4x4 - 4" exhaust/TS Performance 3 position flip chip/Triple gauge pillar mount/K&N air filter/rebuilt and upgraded TC and transmission (local guru)/grill guard/front lighted logo/superduty grill/Lund screen front/clear corners/cowl induction hood/ Hella 550s / X code front springs / Add-a-leaf rear springs / Powershot 2000 / Evans NPG+ Coolant / Rancho RS9000X / http://www.webshots.com/search?query=beastdriver&new=1
Interesting. I weighed my stock 4x4 PSD X on our electronic scales at the trucking company where I worked. With roughly a 1/2 tank diesel and my fat butt out of the truck it weighed...
Total = 7,920# = 100 % [img]/ubbthreads/images/graemlins/wink.gif[/img]
Weight transfer when braking? On my 4wd ex with 285's, after measuring to get equal axle center distance to the ground, I have 2 psi more in the front than the rear. Dale
7.3 Excursion, it's a diesel thing.
Chicago MOB member.
My REAL question is......... why the 'D' rated tires? The tank weighs 8140# - that isn't light. My experience has been that my tires seem to be pushed too close to their max rating and tend to overheat and change shape on long trips causing it to develop an ever-increasing shake at speed. More pronounced in the summer and almost non-existent in the winter........... Hmmmmmmm.......... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My guess - Ford wanted the softer "Soccer" mom ride. Thus, the soft springs and tires. E load range tires on the F250 but load range D tires on the Excursion. The F250 weighs less empty than the Excursion but have similar maximum weights.
Now Ford/Firestone are switching to E load range tires. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
What is next? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Hope this helps,
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
Looks like they learned their lesson for the '03 version - my '01 came with D rated tires - I sold them to a guy with a Super Duty and he blew all four on a trip. Guess we both learned something there.............. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
