Exhaust confusion - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 10-23-2009, 03:43 PM   #1 (permalink)
Exhaust confusion
I have been digging around trying to find exhaust parts online. All the ads pop up with upgrading, etc to big diameter systems... So, my question is, starting at the turbo all the way back, do we have the same size piping? Or does it change along the way? What size?
n2dx is offline
Old 10-23-2009, 03:57 PM   #2 (permalink)
aklim's Avatar
I would do it once and do it right. You can simply replace the muffler to a BTM unit but all you have done is move the choke point to the downpipe. You can get a 5 in system but your downpipe will still be 4 in because little more can fit in there without some real work. I am happy with my 4 in MBRP which goes from the turbo back and is 4 inches. It lowers the EGT because of the lower restriction in the downipie when it goes from a stock unit to 4 in mandrel bent.
01 Excursion 7.3L Powerstroke. Gauges with AIH Delete, AIS, CCV Mod, 4' MBRP, BTS Trans, 6.0L Trans Cooler and Intercooler, DP-Tuner F5 chip, ITP In Tank Mod and Boost Annihilator, Diesel Innovation's Regulated Fuel kit, BTS Big Oil system, GTP38R Turbo with 1.15 A/R housing and BPD Stage II AC injectors. Bilstein Shocks with U code front and A code Rear.
aklim is offline
Old 10-23-2009, 07:39 PM   #3 (permalink)
I give you the "other side" of aklim. Not bashing anyones opinion ever.
OEM is a 3" downpipe to 3 1/2" exhaust. The greatest restriction is the OE muffler. For $75 installed the Walker 21470 you cure 75% of the issues. If I am not mistaken the MBRP has a 3 1/2" Downpipe which gains a little flow but sacarifices a little low end torque. You can easily use the $300 on tunes and an intake etc etc. The best egt drop I have witnessed on a BTM to 4" conversion is about 100 degrees max.This was on a digital gauge setup, 7.3 F250. The owner still wishes he would have spent the $ elsewhere (ie. better tunes).
Good luck either way
2001 X, 4x4, White, Limited, PSD,. Oil Guard, Stull 6099 Grille, AFE Intake, X Monitor, Sonnax/Tricumulator, Mobil 1 ATF w/Racor tranny filter, PHP Custom Burn Chip, Walker BTM, W Code Frt Springs, Procomp Add-a-Leaf Rear, Rancho 9000XL's w/5406 SS. Pics @ http://community.webshots.com/user/txangler32
TXANGLER is offline
Old 10-23-2009, 10:26 PM   #4 (permalink)
My MBRP system is 4" from the turbo back. It is a really tight fit, but it does fit.
steve
2000 7.3L PSD Excursion
4" MBRP 409 Turbo Back
Hellwig Swaybar
Isspro EV, Overhead 3-Gauge Mount
300K and rolling right along
Ford AIS
6.0 Liter Tranmission Cooler
BoilermakerSteve is offline
Old 10-24-2009, 12:46 AM   #5 (permalink)
Thanks for the info about sizes. I ran across an issue in my digging around by accident that talks about the seals in the exhaust pipe up near the turbo/downpipe area where they can due to flexing, etc. have small leaks. Is this a 6.0 problem as well?
n2dx is offline
Old 10-24-2009, 06:48 AM   #6 (permalink)
MotionMan's Avatar
Also remember the X is enclosed, unlike a PU so the drone inside can drive you out. I like the BTM option, if I were to do anything I would try that too.
2003 7.3 Excursion Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, Top Gun Bumper, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. PIAA Lights, Toyo 325/60/18s on Chrome Alum rims.http://community.webshots.com/user/stellinm
MotionMan is online now
Old 10-24-2009, 10:00 AM   #7 (permalink)
Does anyone with a 4" downpipe have issues with the exhaust and trans dip stick touching?
2000 4x4 Ex Limited
DIY intake, AIH delete, ISSPRO gauges-egt,trans temp, boost, 4" Diamond Eye Exhaust, JWVB, 6.0 trans cooler
F5 dp-tuner, 60tow, decel, 80tow, 80econ, 120race
cryo powerslots, superduty hq stainless steel lines, hawk super duty pads
V-code front leafs, ITP pre-pump filter kit
leoneo01 is offline
Old 10-24-2009, 10:53 AM   #8 (permalink)
I dont think the 6.0 have up pipe leaks like the 7.3. Mine has been leaking for 2 yrs but its a small leak.
TXANGLER is offline
Old 10-24-2009, 11:27 AM   #9 (permalink)
I have the 4" maganflow with 3.5"downpipe my drone with the chip under load was too much. I just put back on a new OEM system. Quieter but some drone under load with programmer. Weird. Anyway, I don't push it as much anymore due to cost of fuel so backing off a little due to temp is OK with me. I don't think it makes much difference with mpgs. Go with BTM first. Of course I now have two good exhaust systems a 4" Maganaflow with a flex pipe and a new OEM system.
Beast is offline
Old 10-24-2009, 12:59 PM   #10 (permalink)
aklim's Avatar
Not with my MBRP.
aklim is offline
Old 10-24-2009, 08:54 PM   #11 (permalink)
I have the Magnaflow as well and it was noisy with a bad drone then I added the cat back in it was so that the 4" pipes could be welded in and it solved the noise and greatly reduced the drone to only very high load conditions.
But I have a 6.0 with the cat so it is much different.
Bruce1954 is offline
Old 10-28-2009, 03:54 PM   #12 (permalink)
Originally Posted by aklim View Post
Not with my MBRP.
Thanks for the reply. It sounds like i got a potential problem.
2000 4x4 Ex Limited
leoneo01 is offline
Old 10-28-2009, 09:51 PM   #13 (permalink)
boertje's Avatar
My Photos: (29)
I have one of the early Banks systems before they came out with a 4" for the X. Mine is 3.5 turbo back and it seems to do quite well. I see no reason to spend the money to go with anything bigger.
2001 VW NB TDI speed.
SOLD: '02 PSD Excursion LTD Ultimate 4X4 Mineral Gray, PSD badges, Banks Exhaust, AIS air filter, DP-Tuner, Fuel mods, V code (2C3Z-5310-HA, AKA 3C34-5310-ADA) and modified F code (6C34-5560-F aka 5C32-5560-FA) springs with Timbren rear overloads, Bilstein shocks, hellwig sway bar, Powerslot Cyro rotors with Hawk LTS pads, IH CPS part # 1826899C93 (original CPS).
boertje is offline
Old 10-29-2009, 02:39 AM   #14 (permalink)
I have the 4" magnaflow and have no clearence issues and better I have no drone issues.
2003 EXCURSION EDDIE B, 7.3 PS, 4" Magnaflow Turbo Back exhaust with International up-pipes. BD-Power X Monitor, AFE Stage 2 and Edge Evolution. 6.0L Trans Cooler. JVC DVD head unit with 6 Boston Pro series speakers, Rockford Fosgate 12" sub and amps. Oh ya, AC power for the Blender.
scrmn6guns is offline
Old 10-29-2009, 10:52 PM   #15 (permalink)
From what I understand, the drone comes in when people eliminate the stock CAT. It seems that those who retained the stock cat had little or no drone issues...Feedback?
05 PSD Limited Ex
22x10.5 BMF Novakane Wheels
V's and Modified B's(thanks CaryT)
Bilstein Shocks
Billet Badges
30mm Rear Sway Bar
Adjustable Track Bar
Rough Country Dual Steering Stabilizer
2008 SD Custom Painted Diff Cover
SCT Tuner
Isspro Gauges
Mucho Sound Deadening
Sick Audio/Video Upgrades
Silver line T409 Exhaust!
Peace2Peep is offline
