Exhaust Soot in the cab - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 10-26-2009, 10:51 AM   #1 (permalink)
My rear air vents ar blowing black exhaust soot everywhere? Anyone have an idea of what is going on? My headliner is turning black...
gager2002 is offline
Old 10-26-2009, 05:03 PM   #2 (permalink)
The rear system is totally a re-circulation system
Problem is not in your rear AC/Heat system you have exhaust coming in the rear doors or from under the truck.
A check for any exhaust leaks.
B check all door, glass and widow frame seals
Has the vehicle been in a wreak?
Factory exhaust or new system?
Also give us a clue as to your vehicle and equipment/mods.
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Just about finished!(never tell the wife you are done)
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 10-27-2009, 08:41 AM   #3 (permalink)
Well, bought this one used. The po added 4" exhaust (turbo back). 4" intake, (Napa 6637 filter). I am not sure of anything else. All seals look good around doors and windows. The most 'black' onthe headliner is around the roof vents.
Old 10-27-2009, 04:18 PM   #4 (permalink)
Look for black soot on your firewall, behind the turbo. Maybe you have an exhuast leak that is somehow getting into your fresh air intake at the cowl and then into the cab?
Is it soot or maybe dirt/lint? Like how your ceiling fan will collects dust, even while its spinning.
2003 Excursion EB 7.3l 4x4. 145k miles (70k on WVO)
Custom Waste Veg Oil System/DP-Tuner/Pro-Guard 7 intake/4" MBRP Exhaust/Reg. Fuel Return w/ bowl delete/ATS Turbo Housing/Dyna-Trac Free Spin Kit/CCV/Coolant Filter/Trans Filter/By-pass Oil Filter/HPX/AIH Delete/Lots of other stuff I can't remember
6_Myles is offline
Old 10-28-2009, 10:31 AM   #5 (permalink)
Definately soot from the engine/exhaust. I will look today after work. Thanks
Old 10-31-2009, 11:02 AM   #6 (permalink)
Dunbar's Avatar
Probably Up pipe leaks. Get a flashlight and look where the up pipes go into the Y connector that is attached to the back of the turbo. Also look where the up pipes meet the rear of the exhaust manifolds. Look for soot at those connections and on the firewall.
The donut gaskets leak. If you replace them they are likely to leak again. I am in the middle of installing DI's one piece bellowed up pipes. They are pricey but they will never leak. The turbo has to come off and the Down pipe has to come out to get them in.
David Dunbar
2003 4x4 7.3 Excursion Ltd
4" exhaust, Tymar DIY, Vcode & modified Fcode, Helwig, Inappropriately valved Bilsteins, Isspro 3 gauge w/ windshield mount, DP tuner 80-60tow-40tow-HI, 6.0 31-row ATF cooler,
BTS Transmission, DI Up pipes
Tomball Texas
Dunbar is offline
