Old 03-05-2007, 02:04 PM   #1 (permalink)
exhaust systems
What's the best exhaust system in terms of durability, power increase, and overall value, to put on my 2000 PSD Excursion?
Thanks,
Dave
2000 Excursion XLT - 4X4 - Black/Gray - Power Stroke - ART Rotors - MBRP 4" turbo back - AFE stage II - FTVB - V & B code Swap - Rancho RS9000's - Hellwig rear sway bar - Firestone air bags - ISSpro EV Gauges - ISSpro TTM - DP Tuner F5 : no start, stock, 40TC, 60TC, 80EC, 120RC - 4x2 Lift Gate Cylinders - Fumoto drain valve.
JDWHITTAKER is offline
Old 03-05-2007, 03:45 PM   #2 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
Re: exhaust systems
I would get a Magnaflow 4" system or a MBRP 4" system. You can order either one from many sponsors on this site. I did not want to install my 4" system myself and I have a local muffler shop that has done my work for years. They happen to stock Magnaflow so that's what I went with. It was a nice kit that bolted right up and looks and sounds great. It was pretty quiet with the muffler on so I had mine removed and I love the straight pipe.
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 03-05-2007, 04:41 PM   #3 (permalink)
Re: exhaust systems
I got the MBRP and have had no problems with EGT, or noise. It seem to be built like a brick house!
2004 X PSD Limited Mineral Grey, 4X4 with second row bench then every other factory option,
----Added----
Clearance Marker Lights,
AFE Intake,
MBRP Exhaust,
Edge Juice with Attitude,
Eclipse 5435 with Sirius & Infinity Seperates,
ART Rotors, Performance Friction Pads, Front & Rear, and
Bilstein Shocks.
JFLemm is offline
Old 03-06-2007, 12:47 AM   #4 (permalink)
Re: exhaust systems
I have a 4" exhaust-turbo back, 5" Magnaflow SS tip, Dynomax Race Magnum sound suppressor. It sounds great and with my chip, it runs like a scalded dog.
scott
01 Black Excursion XLT PSD 4x4, loaded, 3.73LS, 305/70R16 Goodyears, Husky mats, Manik tube steps, J & J grill, K&N, Clifford Alarm, 4" exhaust-turbo back, 5" Magnaflow SS tip, Dynomax Race Magnum sound suppressor, Clear corner lens, back door storage bins."Scotpart 4X2 liftgate strut mod", 2002 headlights, Hellwig sway bar, Monroe Shocks, American Racing Wheels, Driver's A-post handle, Go Rhino 3000 front push bar and rear step.
scotpart is offline
Old 03-06-2007, 01:19 AM   #5 (permalink)
Re: exhaust systems
scott
Speaking of ScaldedDogs, I put an MBRP 4" system on our Excursion, and it's been great!
Mark
''Wise men talk because they have something to say; fools, because they have to say something.'' - Plato
2001 Excursion 4x4, v-codes, Western Diesel guages, AIS with fender sleeve & zoodad, MBRP 4" exhaust, Tru-Cool Max tranny cooler, 203* thermostat, BFG AT 285/75-16's, RS9000X's, Rancho steering stabilizer, tightened steering box, Hellwig sway bar, Air-Lift springs and compressor, Draw-Tite trunnion bar WD hitch, SUVlights.com harness, PIAA driving lights with homemade harness, Cobra 25STWX radio
ScaldedDog is offline
Old 03-06-2007, 03:11 AM   #6 (permalink)
Re: exhaust systems
I have a Magnaflow. If I had to do it all over again, I'd go with MBRP. Not because of quality and not because of price. The stainless steel tip on the Magnaflow is a bit cheesy, IMHO. If I had seen it prior to purchase, I probably wouldn't have bought it. The tip isn't rolled like the MBRP. The 4" pipe extends through the 5" tip. In effect, you see a double edge on the outside.
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Gun Control means using both hands.
Stewey is offline
Old 03-06-2007, 08:01 AM   #7 (permalink)
Send a message via Yahoo to milleryan
Re: exhaust systems
Im making a home made system for the X in my spare tim eat work with pieces from the stock stuff and from a Duramax front pipe.Also have a spare piece of 4" inch I may weldto the end for a tip, its a work in progress.Thing is Im not to impressed with the straight pipe noise yet, was hoping for louder, sure got some serious turbo wine though now,lol.
2003 -- Excursion LTD 7.3 Powerstroke 4x4
-10K mod,Maintain DIY air filter, CHP Cold Air Inake,Home made 4" side exit exhaust-
milleryan is offline
Old 03-06-2007, 07:38 PM   #8 (permalink)
jhf
My Photos: (6)
Re: exhaust systems
I put a 4" MBRP on my '02 and it caused a lot of resonation from the exhaust. So much so that I installed a couple layers of sound dampening material from secondskinaudio.com.
Now I have the performance and quiet comfort to go with it. :-)
You won't regret upgrading to the 4" exhaust. I think it really freed up the acceleration of my Ex. Now I am pushed back into my seat well by 70mph. Before the exhaust it seemed to "bind" somewhat above 50mph.
Enjoy,
JHF
2002 Excursion Limited 4x4 - Steel HX hose, ITP pre-pump and in-tank mods, ITP Regulated Fuel Return, BTS transmission, Autometer Carbon gauges (pyro pre-turbo, 4" MBRP T409 Exhaust turbo back, Zoodad, DP F5 6 pos chip (anti-theft, stock, 40t, 60t, 80e, 120r), "V" springs front, "B" springs rear w/ 1" block
jhf is offline
Old 03-07-2007, 02:00 PM   #9 (permalink)
Re: exhaust systems
Thanks for all of your help. It seems like the MBRP is the way to go. Where can I get a good deal on one?
Thanks,
Dave
Old 03-07-2007, 06:22 PM   #10 (permalink)
Re: exhaust systems
Dave- We have them with free shipping. Check our site for pricing as we are not allowed to talk numbers on the boards. If you have any questions, let me know.
www.performancetruckproducts.com
New Site Coming soon!
4" Stainless exhaust $299 shipped
***December "UNTOUCHABLE" Sale***
FREE T-Shirt with orders over $399
DSTRBD is offline
Old 03-07-2007, 07:29 PM   #11 (permalink)
Re: exhaust systems
THOROUGHBREDDIESEL.COM $470 FOR MBRP 409 STAINLESS (THE UNPOLISHED ONE, ALTHOUGH MUFFLER IS POLISHED) NO SHIPPING CHARGES MODEL NUMBER S6216409 I GOT IT AND LIKE IT THIS IS THE LOWEST PRICE I COULD FIND. HOPE THIS HELPS
NGHTRGR is offline
Old 03-07-2007, 11:59 PM   #12 (permalink)
Re: exhaust systems
I have a Bully Dog on my F250. It is the aluminized and is starting to rust slightly. It is about 4 years old. Who makes a quiet one? I would like to put one on the EX but do not want the resonance under the floor. I sit possible to have the performance and still be quiet?
99.5 F250 4x4
2000 Excursion 4x4
http://community.webshots.com/user/mmsafd
mmsafd is offline
Old 03-08-2007, 12:19 AM   #13 (permalink)
Re: exhaust systems
I have an '03 X w/6.0 and are also looking at different exhausts, how does the MBRP turbo back exhaust sound compared to the MagnaFlow???? Also, how was the installation...anyone have any problems?? Looks pretty tight getting the factory downpipe off???
Thanks for any input....
'08 F350 6.4 Lariat CC SWB SRW 4x4 3.73
JMFINLEY is offline
Old 03-08-2007, 02:15 AM   #14 (permalink)
Re: exhaust systems
For the price you cant beat it
http://www.rpmoutlet.com/powerpipe.htm
I did the 5" on mine and it worked out great with just a little modding of a hanger.
k5chevyblazer is offline
Old 03-08-2007, 02:53 AM   #15 (permalink)
Re: exhaust systems
I never worried much about how the Magnaflow tip looked. At the speed I go by, they don't even notice it.
scott
scotpart is offline
