I never worried much about how the Magnaflow tip looked. At the speed I go by, they don't even notice it.
scott
The pipe inside the tip is not very noticeable and it still looks great...trust me I'm nitpicky so if it looked bad I would change it. Im sure the pipe could be cut back and the tip welded on if you were that worried about it.
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel! http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
I have a Bully Dog on my F250. It is the aluminized and is starting to rust slightly. It is about 4 years old. Who makes a quiet one? I would like to put one on the EX but do not want the resonance under the floor. I sit possible to have the performance and still be quiet?
The Magnaflow was surprisingly quiet when I put mine on but still sounded good with zero flutter. I prefer it a little louder so I had the muffler deleted.
I agree with RPM , I bought a 4" sysytem through them for my 03 Duramax.Was a great system, and the tech support guys were easy to talk to and helpful,price was great too.I believe the muffler on it was a flowmaster.
2003 -- Excursion LTD 7.3 Powerstroke 4x4
-10K mod,Maintain DIY air filter, CHP Cold Air Inake,Home made 4" side exit exhaust-
I think it is the XL...I had mine installed by a muffler shop I've used for years...I did have them get me the 4" DP though...the system was supposed to come with a 3.5" DP but they did not charge me any extra for the 4". It came all SS with the polished muffler and 5" tip.
I may havd to talk to the wife about a system for her X. I just do not want it to resonate under the floor and be loud. The one in my truck even gets annoying on a trip. I will check on the Magnaflow, thanks.
So has anyone heard the difference between the Magnaflow and MBRP on a 6.0 X???? I noticed the MBRP 4" turbo back exhaust only has a 3.5" downpipe, the Magnaflow has a true 4", unless you buy the tuner series XL version. I like the idea of a full 4", as long as it fits???
'08 F350 6.4 Lariat CC SWB SRW 4x4 3.73
I got my MBRP exhaust system yesterday. I had it installed by a local performance shop, due to time constraints, but it seemed like it went on very easy. Installation took a little over an hour. It looks and sounds great. I wouldn't even mind if it was even a little louder than it is.
It has a deep rumble to it. No Drone.
Thanks for all of your help.
Dave
2000 Excursion XLT - 4X4 - Black/Gray - Power Stroke - ART Rotors - MBRP 4" turbo back - AFE stage II - FTVB - V & B code Swap - Rancho RS9000's - Hellwig rear sway bar - Firestone air bags - ISSpro EV Gauges - ISSpro TTM - DP Tuner F5 : no start, stock, 40TC, 60TC, 80EC, 120RC - 4x2 Lift Gate Cylinders - Fumoto drain valve.
With the 6.0, the Magna sound almost stock. MBRP may be slightly louder, but I'm guessing not much, if at all. With time, they'll get louder, but still not a "rumble". Need to get rid of the muffler for that, which is surprisingly not that loud either.
