Sounds like a leak in either, or both, the intercooler boots and the up-pipe doughnuts.
I fixed both of these and the fuzzy, oily haze has been gone for some time.
Mine is the same.....I can see the intercooler boots but what/where are the up pipe doughnuts ?
2000 Limited, 118K, 7.3L, 285 Cooper ATR's, super chips 1705 on tow/performance, Bilsteins, Isspro EGT/Boost/ Trans temp.
1997 4runner,5spd,TRD supercharged,Bilsteins,H&R coil springs front and rear
1968 roadrunner,383,4spd
1970 roadrunner,383,4spd,pistol grip,58k 0riginal miles
1970 Charger,383,4spd,pistol grip,my first car
They are behind the turbo. Look at your firewall, just behind the turbo. If it is black and the exhaust up-pipes are black, then you have leaking doughnuts.
2003 Excursion EB 7.3l 4x4. 145k miles (70k on WVO)
Custom Waste Veg Oil System/DP-Tuner/Pro-Guard 7 intake/4" MBRP Exhaust/Reg. Fuel Return w/ bowl delete/ATS Turbo Housing/Dyna-Trac Free Spin Kit/CCV/Coolant Filter/Trans Filter/By-pass Oil Filter/HPX/AIH Delete/Lots of other stuff I can't remember
Thanks ! Did you replace the intercooler boots also ? Or just tighten them ?
Did you use stock or aftermarket boots? If you used aftermarket what would you recommend and where did you get them?
