Old 04-21-2004, 10:03 AM   #1 (permalink)
F-350 rear springs and GVWR rating
I am adding F-350 rear springs to the X to help with the tongue weight of our toyhauler. The rating on the F-350 springs is 6830#. The X springs are 5250#. Does the difference in capacity of 1580# get applied the the GVWR? I realize that I am still limited by the 20,000# gross rating. I am just trying to offset the 1300# tongue weight of the toyhauler and the family of 4 in the X. The factory springs are a little lite in the loafers. Note in my sig I have air bags. Thanks Cliff
2005 F-350 Lariat, SRW, FX4, LB, 4x4, 6.0L PSD, TorqShift, Tow Command, Luxury Package, Camper Package, Inyati Liner, Autometer Guages (3), Banks Monster Exhaust, Trans Cooler w/ Electric Fan, Pullrite 20.5 5th Hitch, God Bless America, Semper Fi
tacobuilder24 is offline
Old 04-21-2004, 10:21 AM   #2 (permalink)
Re: F-350 rear springs and GVWR rating
[img]/ubbthreads/images/graemlins/smile.gif[/img] It's an "it depends" question. Are you talking about the physical capability or the legal GVWR? If you're talking about the legal GVWR from what I understand it won't make a bit of difference. In some states you can actually change the GVWR classification by just applying for a heavier rating, but I don't think that's uniform across all states.
Regards,
Dave
2002 Excursion Limited - 7.3 PSD, 4x4, Auto. Tekonsha Prodigy Controller. ISSPRO EV Gauges in A-Pillar mount. Diesel Turbo Lifesaver. Pre-pump Mod. SCMT-Trimode. AIC. Back Door storage bins. Banks 3 1/2 inch Monster Exhaust. AIS. "U-Code" Springs. Powerstroker Exhaust Brake. Husky Liners. Bilstein Shocks. ART Brakes, Helwig Rear Anti-swaybar. Zoodad Mod. Airlift Rear Airbags. Racor 3550 CCV. Forest River Wildcat 26FBS TT.
2003 VW Jetta TDI - completely stock and 49mpg!
2003 Kubota B2910
dmftoy1 is offline
Old 04-22-2004, 02:51 PM   #3 (permalink)
You are going to love the 350 springs. I put them under mine about 6 months ago and enjoyed a better ride towing or empty since I put them on. Should have been there from the factory!
2000 Excursion Limited 2x4, 3.73 LS,PSD/Auto,ATS turbo shroud,Badging,BullyDog 4" exhaust,AIS,HX crossover,ISSPRO gauges/A-Pillar,SuperChip 1705, Pre-Pump & In-Tank Mod,Banks TransCommand, ZooDad, Baldwin Oil ByPass,Ford AIC, F350 rear springs, Helwig Rear Sway Bar,Michelin's LTX MS
2003 Sunnybrook/Mobile Scout & Hensley Arrow
sail684 is offline
Old 04-22-2004, 05:03 PM   #4 (permalink)
TexasPSDX,
Thanks for responding I was hoping you would. I e-mailed you a while back thanks for the help. I just ordered the springs today from Genuine Ford Parts .com, not a bad price and the springs are new. I also ordered the springs with the auxillary spring. Should have them on next week. I went by the local Ford dealer to look at the F-350 springs and the hitch. The hitch on the F-350 is exactly like the X only rated at 1500,15000#, wonder why? This will really help with my tongue weight on the toyhauler. Thanks Cliff
Old 04-22-2004, 05:14 PM   #5 (permalink)
The different rating could also be attributed to the different frame. Although many of the components are the same, the one difference between the X and F250/350 is the frame. The X frame is lighter. But of course you are not putting the weight in a bed which creates a lot of bending of the frame at the cab. If only the frame was the same. Oh well .....
Beast is offline
Old 04-22-2004, 11:24 PM   #6 (permalink)
My F250's rear leaf springs are toast and was thinking about going to F350 springs. I called the largest Ford parts center in my state and the parts guy advised me not to go with one ton springs because it would put more stress on the rest of the rear end mainly the rear pumpkin. On my passenger side the second leaf from the top is cracked and seperated about an inch and both sides are flat. The parts guy gave me the name and number to a place that custom builds springs for different applications. They either fix/repair the old springs and add a leaf or replace with new. Have to do something and don't want to put 3/4 ton springs back on. Truck has 154K and the springs have been bad for 10's of thousands of miles!
The dealership quoted me $140 per side while another dealership quoted me $204 for the 3/4 ton leafs.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 04-23-2004, 09:28 AM   #7 (permalink)
FamilyRide's Avatar
??? Added stress to the pumpkin? He didn't explaing himself did he?
The springs are springs. What springs a 250 or 350 has depends on how the truck is equipped. Although the 350 has the added helpers, the 250 will accept the brackets to bolt them up. I can't see how a spring will "add" stress. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 04-23-2004, 11:28 AM   #8 (permalink)
Sounds like more dealer BS.
jward is offline
Old 04-23-2004, 01:03 PM   #9 (permalink)
The Excursion frame is also predrilled for the overload brackets to mount, at least mine is.
sail684 is offline
Old 04-24-2004, 07:57 PM   #10 (permalink)
I always heard/thought the X was built on the 250 chassis???
'01 PSD 7.3L Excursion Limited EBM1, 8.5" lift, rear Deavers, 37" PJs, 16x10 Black Rockcrawlers, ORU dual shock hoops, Rancho 9ks all around, Magnaflow T304 system w/5" tip, FTVB w/50/50 mix regular Mercon/Mobil 1 in trans, Mobil 1 PS flush, Tri-pillar loaded w/Di PriCols (EGT,trans, boost), TS 4 pos. switch chip, ConFerr Rack, Cobra CB, TT/sig mirror conversion, 170 hi-amp alt, Hi Lift equipped, UltraDuty rearend cover w/Mobil 1 syn. w/OE friction modifier, Hutch/ITP intank mod, 2 Micron Dahl PrePump, FPR Jack shim mod@ 70psi, 203 deg T-stat & billet housing, Hawk pads, Centric rotors, Valvoline synthetic brake fluid 105.5k so far...
Recent mod: Dieselsite Coolant filter 4/21/05 @ 1100 @72 degs. F ambient temp ;P
Currently sittign in the driveway with a blown up tranny
Dirty X
Clean X
Vindicator is offline
Old 04-24-2004, 08:13 PM   #11 (permalink)
Almost. Its built on a Super Duty chassis. A regular cab short bed chassis. 250s, 350s and Xs use the same frame, just different lengths.
989171 is offline
Old 04-24-2004, 08:21 PM   #12 (permalink)
The X actually has a higher GVWR than a 250 but less than a 350. But they all have a 20,000 GCWR.
989171 is offline
Old 04-24-2004, 08:29 PM   #13 (permalink)
Would this mean that the X has a higher leaf spring capacity rating than the 250, but less than the 350?
Dirty X
Clean X
Old 04-24-2004, 08:36 PM   #14 (permalink)
No, I believe the X has the softest springs on all four corners. Another reason people say the ratings are just a numbers game.
989171 is offline
Old 04-24-2004, 08:40 PM   #15 (permalink)
The X also has 7 cross members instead of the 6 in the 250-350's. I guess cause the box is inclosed in the rear of the X.
Scott
2006 f-250 black Harley Davidson #1909 6.0 CC LB 4" MBRP, AFE 2,08 TT mirrors,
birdman127 is offline
