Old 07-12-2004, 08:17 PM   #1 (permalink)
nogm4me's Avatar
Are F-350 rear springs interchaneable with Excursion springs?
If so how much lift would you get by swapping stock excursion springsfor F-350 springs?
99.5 F-250CCSB 6spd 4X4 ESOF, X-spring, TS75hp,285/75/16 Mich.
02 X 4X4 ESOF, X-spring, 285/75/16 Mich.
nogm4me is offline
Old 07-12-2004, 10:54 PM   #2 (permalink)
FamilyRide's Avatar
Re: Are F-350 rear springs interchaneable with Excursion springs?
Look down the list a little bit and you'll find 1 or maybe 2 threads on F350 spring swaps. Seems like <1" lift but firmer ride and they didn't use the overloads.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 07-13-2004, 07:43 AM   #3 (permalink)
nogm4me's Avatar
can ya use overloads?
nogm4me is offline
Old 07-14-2004, 12:24 AM   #4 (permalink)
Have F350 rear springs on mine. I would guess about 2" life in rear. Mine always looked low in rear before. Lay a level on the roof and the bubble in centered now. As far as overloads, I removed that spring from mine. You could use it, but you would have to get the brackets they hit when overloaded. My frame is drilled for them, but I choose not to get them.
2000 Excursion Limited 2x4, 3.73 LS,PSD/Auto,ATS turbo shroud,Badging,BullyDog 4" exhaust,AIS,HX crossover,ISSPRO gauges/A-Pillar,SuperChip 1705, Pre-Pump & In-Tank Mod,Banks TransCommand, ZooDad, Baldwin Oil ByPass,Ford AIC, F350 rear springs, Helwig Rear Sway Bar,Michelin's LTX MS
2003 Sunnybrook/Mobile Scout & Hensley Arrow
sail684 is offline
Old 07-16-2004, 05:05 PM   #5 (permalink)
nogm4me's Avatar
Texas,
any part numbers or prices on springs and stops/brackets? Thanks!
nogm4me is offline
Old 07-16-2004, 05:16 PM   #6 (permalink)
Never looked at part #'s or cost since I wasn't going to add them.
sail684 is offline
Old 07-17-2004, 03:02 PM   #7 (permalink)
nogm4me's Avatar
Any advantages to the overloads?
nogm4me is offline
Old 07-18-2004, 04:04 PM   #8 (permalink)
The overloads won't affect ride any. If you still use the 4"rear blocks they will give you a little more lift in the rear. I really can't imagine being able to load an Ex enough for the overloadsprings to ever be used. We are getting ready to do a swap for X code fronts and F-350 rears. Probably not going to do the overload springs because as I said before I can't imagine loading it enough for them ever to be used.
We haven't been able to find any springs locally so it looks like we are going to order direct through Ford. My dad gets a discount because the parts manager at one of the local dealers is one of his old runnin buddies. We aren't really sure which springs to order for the rear though. We guess B code rears are ok but we don't know if those come with the overloads or not.
I'll be sure to keep you guys posted.
John
2000 Excursion Limited 4x4
265 Goodyear Wrangler MT/R's for winter
285 Bridgestone Revo's for the summer
X-codes and F-350 B-code rears
Polyurathane bushing kit
4" exhaust, intake, and gauges in the future if the price is right.
twoodballa is offline
Old 07-19-2004, 05:50 AM   #9 (permalink)
Send a message via ICQ to coldair
If you want to go higher with a better ride then stock just use the edge spring shackles in the front and a block in the rear
2002 Excursion LTD(PCM:NQW5)Pheltech Tru-Cowl Induction Hood BTS transmission ITP fuel system, 38/15.5/20 Toyo's on Weld 12" wide wheels,15k warn and warn 9.5k rear 4:56's ARB air lockers front and rear. Trail ready front bumper,Road Armor rear bumper light force driving lights, PIAA backup lights,Dakota digital gages, F5 DP tuner chip,Hypermax stage 2 injectors,4" exhaust, 11" Edge lift, King shocks, edge crossover steering, ORU ram assist steering
Fabtech ladder bars,TN turbo, Dynatrac conversion kit. Alpine F1, Zapco amps. two dc1100.1, three dc1000.4, 1 dc750.2, driving seas reference series front stage and Zapco competition rear fill and 2 Jl audio 13w7 subs
AP Racing big brakes, Amp Research running boards
coldair is offline
Old 07-21-2004, 11:41 PM   #10 (permalink)
Does anyone know if you have to used the spacer that goes inbetween the main spring and the helper spring. We are going to install the helper springs but will it be too high with that spacer installed and the 4" rear blocks?
John
Old 07-22-2004, 09:16 AM   #11 (permalink)
I would not think you have to install it, I think its there to give somelag time before ya hit the helper spring. It should only stiffen the ride if ya remove that spacer [img]/ubbthreads/images/graemlins/frown.gif[/img]
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is online now
Old 07-22-2004, 10:28 AM   #12 (permalink)
Sorry for the dumb question (new here), what are X code fronts? I'm assuming that they are some other Ford SD front spring...
Maverick4x4 is offline
Old 07-23-2004, 10:07 AM   #13 (permalink)
Not a dumb question at all. You are correct. They are the front springs off of SD trucks that have the snow plow package.
...danny
2001 'X' 7.3l PSD 4x4 Limited
Oxford White / Medium Parchment
K&N Air filter, Husky Floor Liners
20' H&H Speedloader MX Tiltbed Trailer
Bilstein shocks(BE5-6208 front, BE56209 rear) $259.80 to my door.
AllAboutJeeps is offline
Old 07-23-2004, 06:43 PM   #14 (permalink)
ok I just did the X code spring swap 2 weeks ago and WOW. I also added a mini 2" spring pack in the front and a add a leaf in the rear. I will post pictures on monday after a busy week end. I removed the spacer block and the overloads. I now sit about 5 inches higher than a stock X. Bilsteins round out my lift and the ride is rough....1 ton springs are...well 1 ton springs. I plan on running 315/75/16 nitto's next spring since the 305/70/16 goodyears have a ton of tread left. I will be taking it to show at Carlisle for the All Truck Nationals Aug.6,7,& 8th in PA.
Scott
2006 f-250 black Harley Davidson #1909 6.0 CC LB 4" MBRP, AFE 2,08 TT mirrors,
birdman127 is offline
Old 07-27-2004, 10:03 PM   #15 (permalink)
lifted X
Scott
