Old 04-15-2007, 09:08 PM   #1 (permalink)
My Photos: (10)
F-code modifications-another way.
So far I am very satisfied with the spring changes I have made to my X. However one of the things that has bothered me is that the spring forward of the rear axle rests entirely on the variable weight leaf giving it little "spring." There are those that have used the bottom leaf of the original X spring pack but this too bothered me since it is much shorter than the thick variable bottom leaf. Towrig mentions that the 2nd leaf is perhaps a good choice. As I was looking at the F code and the original X spring pack I noticed that the 3rd leaf fits almost perfectly between the think variable leaf and the 4th leaf that normally sits on the variable leaf. So I gave it a try. All I had to do is trim about 1/4 inch off the forward end of the leaf to be added and also remove the retaining bracket from said leaf. Pics are here.
The mods are the pics dated 4-15-07. The pics show the unmodifed F-code and the modified F-code with the added leaf. It also shows that now there is space between the bottom leaf and the thick variable leaf giving me some "spring" and a litle bit of travel. Originally I had added .66 inches of shims in the form of a piece of the original anti wrap leaf and leaf spacer but these I removed since the added leaf and the additional shim plus a shim on the very bottom of the spring pack add up to the same as what I had removed.
Since I first installed the F-code the rear of the X had dropped by 0.25 inch from 40.75 to 40.5. Now with the newly modified F-code I am at 41.0 inch. The ride is good and there is a little more spring. Perhaps this mod might solve some issues on towing with the F-code and perhaps this applies to the B-code as well.
'02 PSD Excursion LTD Ultimate 4X4 Mineral Gray, PSD badges, Banks Exhaust, AIS air filter, DP-Tuner, Fuel mods, V code (2C3Z-5310-HA, AKA 3C34-5310-ADA) and modified F code (6C34-5560-F aka 5C32-5560-FA) springs with Timbren rear overloads, Bilstein shocks, hellwig sway bar, Powerslot Cyro rotors with Hawk LTS pads.
boertje is offline
Old 04-15-2007, 11:58 PM   #2 (permalink)
Re: F-code modifications-another way.
How does the ride differ since you have made the change? Notice any difference?
'08 F350 6.4 Lariat CC SWB SRW 4x4 3.73
JMFINLEY is offline
Old 04-16-2007, 09:56 AM   #3 (permalink)
Boertje,
You read my mind. This weekend I was also looking at the length of the springs. I was looking into the 2nd or like you the third spring.
Let me know how the 3rd spring is working out.
Thanks,
2005 Black XLT PSD Excursion 6.0
Bilstein Shocks, V and F code springs
CFM intake Elbow, ZooDad Mod
SCT Tuner by Eric at ID
ldmc is offline
Old 04-16-2007, 10:09 AM   #4 (permalink)
boertje,
I'm glad you tried this out. I have been holding off until warmer weather hits.
Like the others said, please let us know how the ride changed, both unloaded and loaded. You said it is good, but how is it different?
2001 Excursion Limited 4X4, V10
Done so far:
Rear Hellwig (#7643),
Front Poly Frame Mount Sway Bar Bushings (Energy Suspension #4.5180G),
Gen II Landyot Radius Rods,
Rancho RS9000X's (RS99267 front, RS99266 rear),
Rancho steering stabilizer (RS5410),
Super Duty Front Bumpstops (F81Z-3020-DA)
Domelight & Foglamp overrides, Heated & Lighted TT Mirrors, Silverstars, Husky Floor & Cargo Liners, Husky molded mudflaps, V10 badges, OEM clear headlights & corners, latex tubing in door weatherstrips
U Code Front Springs (2C3Z-5310-GA),
F Code Rear Springs (6C3Z-5560-F) with added leaf from original spring pack (the 38" long leaf, 3rd from bottom, not including anti-wrap leaf)
Landyots Removed during spring change, may add Gen IV's in the future as an experiment
<span style="color: blue">2001 Excursion Pictures and Mods</span>
towrig is offline
Old 04-16-2007, 10:56 AM   #5 (permalink)
My Photos: (10)
Unloaded in the few miles I have driven it, the ride seems more cushioned in the rear. I purposefully drove rough roads too. Loaded, well in May I am driving from CA to TN and finally Iowa with the family and loaded with stuff...I shall report back.
Just drove 150 miles with the new spring mods. The handling is the same but the ride is softer on the rear. There is more give or "spring" than before. I find that a good thing.
boertje is offline
Old 04-17-2007, 09:39 AM   #6 (permalink)
I like it!
The only question I have come up with is spring wrap, the way the original variable rate leaf sits it helps prevent spring wrap.
On the other hand I have always wondered if the X was so heavy it was always into the variable rate anyway and not able to give the softer ride we want in the back.
Looks like a great set up for springs only rear end.
You can sure see the difference in the arch in your pictures this will also help in high rebound situations since the lower leaf will disengage and lessen the rebound effect. Not sure it this will happen in normal driving but it can't hurt.
Now the only question is if stock Fs with a sleave type air bag set up would be better. Guess I will have to build it and see.
Bruce
Bruce1954 is offline
Old 04-17-2007, 09:47 AM   #7 (permalink)
Bruce stated my thoughts exactly concerning axle wrap. I was wondering if the fact that the variable rate spring being engaged on the Excursion is what helped with the axle wrap/wander issues some of us have. I have the V and B codes to swap in, still trying to decide if I want to modify the B codes or not.
2004 Excursion Limited, Black, 4x4, 6.0L, Hellwig 30 mm Rear Antisway, V Codes & Modified B Codes, Rancho RSX's, MRBP Turbo back, AFE Intake, Quadzilla XZT
Sam Eaton
Dallas, TX
TxSam is offline
Old 04-17-2007, 10:46 AM   #8 (permalink)
My Photos: (10)
I too was thinking about that but so far I cannot tell if this is an issue. It drives fine with a little softer ride yet feels solid on bumps. I like the difference so far.
But wouldn't an air bag decrease the engagement of the bottom leaf from the variable leaf even further and thus increase the potential of spring wrap?
Jack
boertje is offline
Old 04-18-2007, 10:28 PM   #9 (permalink)
Jack
Yep
"Engineering" another word for Compromise [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Bruce
