F350 (snow plow package) X-Springs and Rear Blocks - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Old 10-25-2009, 02:38 PM   #1 (permalink)
I have had my new to me Excursion since March. I bought it to pull my jeep around and for the convenience of being able to camp within the back of it. It is 2002 7.3L and I picked it up with only 75,000 miles on it.
Like most mine was riding on the front bump stops so I started looking for a solution and through this site I found the remedy. I got the F350 X-springs and blocks. This is definitely how these trucks should have left the assembly line.
Before
2002 7.3L Excursion, DIY BHAF 6637, 08+ Al Rear Dif Cover, F350 X-springs and blocks
http://s165.photobucket.com/albums/u42/rkik/Excursion/
rkik is offline
Old 10-25-2009, 02:39 PM   #2 (permalink)
The parts
Front Springs 2C3Z*5310*AF
Rear Block Left F81Z*5598*FA
Rear Block Right F81Z*5598*GA
Rear U-Bolts F81Z*5705*EA
rkik is offline
Old 10-25-2009, 02:40 PM   #3 (permalink)
After
rkik is offline
Old 10-25-2009, 02:41 PM   #4 (permalink)
And a picture of the jeep it tows
Now to save up the money for some wheels and bigger tires …
rkik is offline
Old 10-26-2009, 03:41 AM   #5 (permalink)
boomboom's Avatar
You are sooo right about (this is how they should have come) Did same thing 6 years ago. I only added 60k miles sense then but it still looks level. I'm not sure if they have sagged any but front wheel well sits 40" dead center of hub and rear is 41" with 285x75x16 . What is your ride height with virgin springs ?? NICE RIG"S and GREAT POST !!!
boomboom is offline
Old 10-27-2009, 12:22 AM   #6 (permalink)
Will get some measurements ASAP.
rkik is offline
Old 10-27-2009, 02:23 PM   #7 (permalink)
Feedback Score: 3 reviews
Now you just need Bilsteins and a rear 30mm SD swaybar..along with modded b codes.
Cary
caryt is offline
Old 10-29-2009, 01:06 AM   #8 (permalink)
39.50 Front
40.50 Rear
with 265/75r16s
Going to try to squeeze some 285/75r17 Toyo MTs on some 17x8 ATX Mojave Teflons under it.
Those are on the to do list along with some new front bump stops.
For the bilsteins are these the part numbers I should go with:
Front F4-BE5-2818-HO
Rear F4-BE5-6209-HO
rkik is offline
Old 10-29-2009, 01:30 AM   #9 (permalink)
nycpsd's Avatar
Might need to get yourself about a 4 inch lift for those set of wheels.
02 F-350 Reg Cab Auto Trans L2 Blue, Marinco Mod, ZooDad Mod, Bilstien HD Shocks, Ford Alarm Code 3 Remote Start, Energy Suspension Spring Bushings and SwayBar Bushings, 2500 Watt Inverter, Sirius Sat. Radio, (Hardwired), Garmin Nuvi 250 (Hardwired), Blue Sea 6 Circuit Fuse Panel X2, Western 8' Pro Plus Ultra Mount Plow, 08 Taillights, Stancor Mod, Ford AIC, AIH Delete, Stainless HPX, Foil Delete, 05 PTM Tow Mirrors, 05 Upfitter Switch, 05 Center Dash, Federal Signal Smart Siren with Signal Master...
nycpsd is offline
Old 10-29-2009, 03:13 AM   #10 (permalink)
boomboom's Avatar
Thats great, it doesn't look like my springs sagged at all over the years sense the differance between our two tire sizes would be 1/2" in truck height I'd really like to see pic's when you get them .It shouldn't be a problem if you got same backspacing on new wheels as stock. Might have to trim plastic spoiler a little. Might be a little more work getting those tires on that blue truck in the picture though.
boomboom is offline
Old 10-30-2009, 01:35 AM   #11 (permalink)
Really? Figured since most fit 285/75r16 (~33) on stock springs that with the X springs up front (at least +2.5") I should be able to fit a 1" diameter bigger tire (285/75r17 = ~34) without much problem. Plan to run them on 17x8s with 4.5 BS. I don't mind trimming the plastic valance or massaging/trimming the plastic fender liner. I appreciate any help before I spend the cash so if my logic is incorrect please let me know.
Anyone else have inputs?
Yeah I found that pic online while searching for tires. Not sure what all that blue f150 had to do to get those to fit. Can't find pics of them installed on the truck but his plan was for BDS 2 1/2" leveling kit along with their 1" rear block kit?
I am hoping that by not going wider than 285s and sticking with 8" wide wheels that I will minimize some of the clearance issues?
rkik is offline
Old 10-30-2009, 03:23 AM   #12 (permalink)
nycpsd's Avatar
Sorry just realized the truck in the pic with the tire is not the same truck from the other pics of your truck, you should be fine with 285's
nycpsd is offline
Old 10-30-2009, 01:03 PM   #13 (permalink)
wow! nice thing u got there eh?
good luck on ur project.
richkcmo is offline
Old 10-30-2009, 03:36 PM   #14 (permalink)
just curious, where did you buy the parts? Directly from Ford? Do you mind telling what it all cost to do this? looks great!
'00 Excursion, soon to be grease-fed
fiveohpatrol is offline
Old 10-30-2009, 06:36 PM   #15 (permalink)
boomboom's Avatar
I got mine from dealer but can't remember how much $$, I got mine 6yrs. ago. The springs are heavy so I wouldn't even try to buy them online or anything like that. Shipping would be EXPENSIVE !!
boomboom is offline
