Finished The Inverter Wiring
We use an inverter a good bit and when I got the new truck the guys in the shop got me a 750 watt inverter for Christmas of 05. I had it wired up with a dual feed from the right rear and left center power point providing plenty of power when the truck was off, up to 400 watts. But I had wanted to give it a real power feed for when I needed it. So with a surge of 1500 watts (I would not even try that) it comes out way over 100 Amps. I went with a #6 marine grade battery cable, very flexible ( expensive to [img]/ubbthreads/images/graemlins/shocked.gif[/img]) # 6 is good for 80 amps all day long and can handle a surge of 150 no problem. So at 80 amps and 12 volts I have 960 watts. Could have used #8 but the thought of hot wires under the carpet just didn’t sound good.
I used the 10 amp customer access wire under the dash that is only hot in run to turn on the relay under the hood to feed the #6 wire. The power points are fused at 20 amps each. You do not want to back feed that #14 wire with the 120 amps that the #6 is fused at so I used a full wave bridge that we stock at the shop but Radio Shack should have a 30 AMP Full wave bridge or you could do it with two 30 diodes since that is all you are using in the bridge.
The diagram looks like this:
<font class="small">Code:</font><hr /><pre>
-----Feed from right rear PP---->/+AC-\
/ FW \
- Bridge + ------->------------O
\ / l
-----Feed from left cent PP----->\+AC-/ l
l
l
1
--From left bat-->-2-60 Amp Fuses in Parallel-->--] Relay[->--O->---Inverter
</pre><hr />
The diodes in the bridge prevent any electrical back feeds, power can only go one way, to the inverter.
I had put a little thought and time into this so I thought I would share.
And yes the picts are posted
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
