Old 09-15-2005, 04:22 AM   #1 (permalink)
First Mods to my X
I am going to do an cold air intake, which this is pretty straight forward.
I am also going to cut out the muffler and run straight pipes. Any problems with doing this?
And noise isnt a problem.
k5chevyblazer is offline
Old 09-15-2005, 07:56 AM   #2 (permalink)
BenBone's Avatar
Re: First Mods to my X
I have not cut my muffler off but others on here have had mixed opinions. I remember a few threads about this.. I decided agaginst it after reading up on what others disliked about it (noisey, very loud inside, not much preformance gain)
2004 6.0l 4WD Limted Excursion
Road Armor Stealth Bumper with Titan Guard, BFG AT 305's, AR Mojave Teflon's, Tint, Stereo, Remote Start Alarm, Strobes,MBRP Turbo Back T-409 Stainless Steel Exhaust System, AFE Pro Guard 7 Mega System, Edge Insight, Coolant Filter, ARP Studs
http://photos.thedieselstop.com/show...t=1&thecat=500
1999 Ford F250 CC LB 4x4 7.3L
DP F5, MBRP 4", AFE Satge II, DM 3 pod, 95 Gallon Transfer/Toolbox Chest, BGF AT 295's, AR Mojave Teflon's,Tint
BenBone is offline
Old 09-15-2005, 10:32 AM   #3 (permalink)
Mine is straight piped. Im 34 yrs old, I love it. My wife prefered it with a muffler, and she now does not like the windows down when in the Excursion. My 56 yr old Father thinks it is ridiculous and hates it. Most of the guys I hang with love it, and folks on sidewalks or out in thier yards/porch turn to see what kind of monster tractor trailer is coming up the road with the pipes roaring. At a cruise on the highway, it is barely noticeable. At idle its same as before, but push some pressure on the go peddle and she can get down right obnoxious!
2000 Excursion 33,500 miles and counting!
Banks Big Hoss LVL 4, Banks 6-Gun, Banks Power-elbow
Banks Big-Head Actuator (set at 25 PSI), Banks Quick Turbo, Banks Compressor Wheel, Banks 4" Exhaust system but straight piped!, Banks Intercooler, Banks TQ Convertor, Banks Trans-Command, Westin Nerf Bars
Ultimate Bull Bar, Helwig rear sway bar, V-code springs, 2 HELLA 500 Driving lights, 2 KC Dayliters, Lights mounted on a custom home fabricated mount on the Ultimate Bull Bar.
285-75-16 MT Tires, Visor over windshield and rear air dam over hatch. Custom painted monochromatic in factory dark green. Amsoil 3000 Synthetic engine oil With AMSOIL EA Synthetic Filter and Amsoil Synthetic differential lube. Warn manual hubs.
I'm ready for a hook at the next truckpull!
larry0071 is offline
Old 09-15-2005, 10:55 AM   #4 (permalink)
FamilyRide's Avatar
You need to check out the 6.0 Aftermarket Forum.
An intake that's got good filtration and good flow is expensive and for the most part, people say they wish they would have saved their money and kept the stock intake. The 6.0 intake is not bad at all.
As far as exhaust, straight piped 6.0's do not sound goo at all, in my opinion. From the outside the driver can't hear how obnoxious the turbo sounds. I like the sound of exhaust, but I don't like a striaght piped 6.0. 7.3 is a different story, that sounds good. (I have just under 600HP in a 540 cid in my boat and I run full open, no baffles or mufflers, straight out the back and I like it! [img]/ubbthreads/images/graemlins/laugh.gif[/img])
I think pulling the muffler woudn't be bad at all, and maybe even pull the cat and keep the muffler would be OK, but the turbo would be loud. I'v got Magnaflow with the CAT in place and it sounds good, but I'd like to get a little more sound, but not the turbo! I can hear the turbo fine as it is now!
Try replacing the muffler with a BTM (Big Truck Muffler) and see how that works. It's prety cheap and should get some better sound without going completly crazy.
BTW, do you realize that removing the CAT is a Federal offense regardless whether your state emmisions tests diesels or not?
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 09-15-2005, 11:43 AM   #5 (permalink)
Pharmer's Avatar
I think K5 picked up a 00X. I have a 03 with 7.3, no mods so far. Only ones I may consider are Walker BTM and Ford AIS intake. So far I like the way it runs stock.
03 Excursion Eddie Bauer 4WD 7.3L, 265 REVOS, U's and F's(mod), 3rd row headrests
68 Cougar xr7 390GT http://www.supermotors.net/vehicles/registry/3724
Pharmer is offline
Old 09-15-2005, 11:47 AM   #6 (permalink)
FamilyRide's Avatar
Oh, well if that's the case!! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
I have actualy heard a 7.3 in an Excursion (an ex TDS Member) with the BTM and it sounds really good! Nothing like being straightpiped, but sounds really good.
Old 09-15-2005, 12:03 PM   #7 (permalink)
My bad, he is right it is a 00 X, and it doesnt have a cat already, it was original sold in Idaho, so all I'll be taking out is the muffler.
Old 09-15-2005, 01:35 PM   #8 (permalink)
When I first cut the muffler off of my X it really sounded cool. I really didn't like the small amount of lag that showed up after I did it. Since then put Magnaflow 4" and sounds better and much better response.
2000 Excursion Limited PSD 4X4 Green/Tan 5" Superlift Selectride, Bilsteins, 35" BFG A/T, 16X10 Eagle Alloys, 3.73 gears, 203 Thermostat Turbo back 4" Magaflow Exhaust, 5" tip, Superchips Power Programmer,K&N Cold Air Intake,DVD system,2 SAVV and 1Audiovox LCD monitors, Custom Bumper,4 KC Hilites
http://community.webshots.com/album/321346005bpfSxB?7
jguzman75 is offline
Old 09-15-2005, 01:53 PM   #9 (permalink)
My Photos: (10)
I put the Aero-Turbine 4040 on my X instead of straight piping it and am really happy with the results.
ShayB is offline
Old 09-15-2005, 02:42 PM   #10 (permalink)
And here is the first mod already done, sounds mean now :bounce: In the end when some money comes around I will probably do the turbo back system from Magnaflow.
http://beer.thisdysfunctional.org/ki...1265.sized.jpg
Old 09-16-2005, 09:32 PM   #11 (permalink)
the 7.3's dont sound as good as the 6.0's with a straight pipe. also just from expierence its runs better with a muffler on. its up to you. if you want attn. youll definatly get it with the straight pipe.
FORZFED is offline
Old 09-17-2005, 01:25 AM   #12 (permalink)
FamilyRide's Avatar
Something I just remembered, the 7.3 with the BTM that sounded so good, it also had a new wheel (turbo), so it didn't flutter. I HAVE heard 7.3's straight piped that fluttered and sound bad!
