Old 03-12-2002, 04:40 PM   #1 (permalink)
First Problem!!
After two years I've encountered the first problem with my X. It started leaking oil between the engine and transmission. Not a lot but enough to make a mess on the garage floor. Took it to the dealer this morning and will let you know what happened. Has anyone else had this problem?
Other than that, it's been perfect. Not even the smallest problem to talk about. This has been the best and most reliable vehicle I've ever owned.
Kelly
2000 EXCURSION PSD Limited 4x4. All factory options except heated seats. Saddleman seat covers.
KELLY BROWN is offline
Old 03-12-2002, 08:57 PM   #2 (permalink)
Re: First Problem!!
I had the same problem, it was leaking off the bottom of the inspection cover. The dealer said it was a high pressure oil line at the back of the head, which they fixed.
'00 Excursion Limited, 4x4, PSD. 6" ProComp lift, Weld (Stone Crusher) wheels, 35" ProComp tires. Dual shocks up front. Airaid air intake. Straight piped. SCMT-80hp, Western Diesel triple pod gauges.
gschneid is offline
Old 03-13-2002, 05:22 PM   #3 (permalink)
Re: First Problem!!
Looks like I had the same problem as gschneid. It was a defective O ring on a high pressure oil line. The oil was leaking into the engine valley and then down to the rear. All is ok now. Parts cost $3.92. Not bad for two years.
Kelly
Old 03-13-2002, 08:21 PM   #4 (permalink)
Re: First Problem!!
I had this same problem also. Dealer #1 said it was the rear main, so they replaced it. Funny thing was, the problem was still there the following week. They replaced the rear main again and insisted they had their "heavy truck "guy working on it. Fortunately, oil dropped again a week later but when i was in a different state. Dealership there fixed the real problem.
On a side note, I had another oil leak last week, but was not related to previous ones (some loose clamps).
I won't ever need underbody coating again because there are about 3 layers of motor oil that will probably never come off.
-Eric
'67 Galaxie Pics | '00 Excursion Pics
erlong is offline
Old 03-24-2002, 08:16 PM   #5 (permalink)
Re: First Problem!!
I think I have the same problem too. Is the 100k diesel warranty cover the bad oring problem?
Clif Smith - Austin, Texas
1997 F-350 PSD, 2WD, Crew Cab. Bone Stock.
Previously owned PSDs:
-2000 Excursion Limited 4x4. Modified Out.
-1999 F-250 Superduty Extended Cab - Stock
clifsmith is offline
Old 03-25-2002, 07:10 PM   #6 (permalink)
whotnow's Avatar
My Photos: (10)
Re: First Problem!!
yes, but why pay $100, when you can fix it for around $3.92??
FOKISD Charter Member from Chillicothe, OHIO
2004 Excursion, Auto, 4X4, 6.0 Turbo diesel, Harley Instument Cluster, Brite box w/Fog Lights, 26/24 inch wipers, 3.73LS, X and F w/350 blocks spring upgrade, XMradio, Grill and tail light gaurds, Sunvisor w/ marker lights, rear spoiler, 2 JL audio 12's, Front Marker Mod, rear swaybar, Hella Highbeams mounted on grill guard, Air rite Airbags, Born On 12-03
whotnow is offline
Old 03-25-2002, 08:01 PM   #7 (permalink)
Re: First Problem!!
I have to take it in for other stuff as well. Is there a Service Bulletin on this problem that I can tell the dealer and can anyone tell me which hose it is that is problematic?
» Sponsor Links
»Garage Storage and Cabinets
