Old 05-11-2004, 10:13 PM   #16 (permalink)
Re: First "real" tow with my X
Paul,
th speeds I did the comparison at were the same I was running the Cummins at. And typically they are below the posted speed limit here in Florida. On 95 I was running about 67-68 where the speed limit was 70.
By the way Paul, when you tow your rig, assuming you are using overdrive and cruisecontrol, do you see the speed drop off a little on the overpasses and any downshifting like happened to me? I figure us being neighbors we probably traverse the same overpasses to compare on, even though I am pulling a heavier rig.
thanks.
Depends on the size of the overpass, some do and some don't. Mine does real good at 73 mph. Go figure?
Paul B
vc
2001 Excursion Limited PSD,2wd,Auto. Toreador Red,10/2000,4.5 Racor,unTAGed,203*,DP-Tuner,AIS Filter,Riley Coolant Filter,6.0 cooler,Cat ELC,Son/Tri,Underdash Lunar Gauges,Hadley Air Horn,On Board Air,Fumoto,2006 31' Flagstaff TT 6.5K,Prodigy
2000 Honda CRV EX
PIC'S
pabrannan is offline
Old 05-11-2004, 10:30 PM   #17 (permalink)
MotionMan,
thanks for the info. I will get in touch with him in the next few days as work aloows. I appreciate the info. Does your particular unit have a model number I need to give him for the Excursion aplication - or I guess he should have that after all the trial and error you guys did - never mind.
vc
2002 LTD 4X4,Bi-Xenon HID's,Amsoil Dual Remote,Wicked Wheel,under dash 3 gauge pod(Isspro's), 203 t-stat,aluminum t-stat housing,evans coolant,TRU-COOL MAX tranny cooler,external tranny filter,Western Diesel RamAir intake,Edge Evolution tow tune, Edelbrock IAS rear shocks,Landyot's Radius Rods,5 new Pirelli Scorpions courtesy of Ford.
boaterholic is offline
Old 05-11-2004, 10:32 PM   #18 (permalink)
MotionMan,
I forgot to re ask you on the 2 mpg increase you got - was that towing or empty or both?
Thanks.
vc
Old 05-12-2004, 09:59 AM   #19 (permalink)
CHPMustang's Avatar
When pulling the steep grades with a stocker 7.3 it'll seem like a dog and the tranny shifts quite abit as we did that when the Excursion was brand new towing some 7k-8k over 1800 miles.
Following the first big tow we worked on the intake,exhaust and electronics then towing was like in cruise control without even knowing a trailer is hooked up.
Our mileage towing over flat land can bring up to 18 mpg at 65-70 mph but once we hit the hills along I-10 between El Paso and Phoenix it'll drop back to 13-15 mpg which isn't too bad I suppose but we don't scream the RPM's either.
The things that made the biggest difference was the grille cool air fed intake,Wicked Wheel and BTM,try mods similar to those and tow again [img]/ubbthreads/images/graemlins/smile.gif[/img]
2002 Ford Excursion 7.3L 4x4 XLT
9th Annual Powerstroke Rally this Oct 3-5 2008 in Caddo Mills,Texas
CLICK HERE for more Information & Register Here
CHPMustang is offline
Old 05-12-2004, 11:46 AM   #20 (permalink)
CHP,
can you tell me more about the cold air intake, and what is BTM?
Thanks.
vc
Old 05-12-2004, 11:49 AM   #21 (permalink)
MotionMan's Avatar
I saw a 2mpg increase all the way. I am seeing 12 towing 10,000lbs and 18-19 empty. This may be a little high due to the programer, and yes Joe will remember [img]/ubbthreads/images/graemlins/cool.gif[/img]
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 05-12-2004, 11:51 AM   #22 (permalink)
MotionMan's Avatar
Yes CHP, what is this cold air thing, I assume the BTM is a chip of some sort. You are so right, once the mods were done the truck just pulled like a train and with mine it is as mild of a bump as you can get.
Old 05-12-2004, 12:24 PM   #23 (permalink)
Location: Imperial, MO - 20 miles south of St. Louis, MO
I thought BTM was a big truck muffler??
2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners w/ Plasma white bulbs,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day tow heavy in 80HP Mode),Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc.); BTS tranny & new programming if oem ever dies.
In betweeen boats so now I have a custom 2003 HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Ride with friends now...Harley much cheaper on fuel!
http://community.webshots.com/user/jweiler27
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
Old 05-12-2004, 04:54 PM   #24 (permalink)
MotionMan's Avatar
It could be, I have no idea what it is, I just guessed [img]/ubbthreads/images/graemlins/cool.gif[/img]
Old 05-12-2004, 07:05 PM   #25 (permalink)
CHPMustang's Avatar
CHP,
Thanks.
vc
I opened up the fiberglas wall in front of the air intake tube to take all the cool air from the head of the truck,as you can see in this PHOTO I have it taped off to get all the air from the front.
The BTM is short for the Walker brand "Big Truck Muffler" which is a straight thru design muffler,it was only $50 for the muffler which I had a local muffler shop(Not Midas) to install it for $40. Installed Photo
BILL
Old 05-12-2004, 09:38 PM   #26 (permalink)
CHP,
Thanks.
vc
BILL
Boy, that's a Zoodad and a half!!!!
Paul B
2000 Honda CRV EX
PIC'S
Old 05-12-2004, 10:35 PM   #27 (permalink)
MotionMan's Avatar
Cutting that hole helps that much? It looks simple, are you afraid of objects or dirt and water going in there? It looks like it would really gobble air but I am afraid it may injest small birds or even children. [img]/ubbthreads/images/graemlins/ooo.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 05-12-2004, 11:11 PM   #28 (permalink)
MotionMan,
I'm not sure if I understand what you meant with the "This may be a little high due to the programer" statement. Are you saying this is what the overhead computer is saying, or did you hand calculate your mileage and are getting the 2 mpg increase hand figuring it? The reason I ask is because if you are going of the computer I would be reluctant to trust it more after using a chip than before as I have been told that the chips/programmers can send the overhead into lala land.
Old 05-12-2004, 11:15 PM   #29 (permalink)
CHP,
I thought the Wicked Wheel was mostly a benefit to those that were having turbo stalling noises or something to that effect. Are you saying that the W.W. actually is pumping more air into the intake? If so then I could see where it helps.
Thanks.
vc
Old 05-12-2004, 11:19 PM   #30 (permalink)
To all who had sent me email interested in the airbags, they are sold.
Thanks.
vc
