Old 02-01-2006, 03:05 PM   #1 (permalink)
flo-pro 4" exhaust, very loud
I have installed a 4" flo-pro exhaust thsi weekend and the sound of the turbo is incredibly lous, to the point I do not want to drive it. Has anyone installed this exhaust and encountered the same? the model I installed is 817. This is a turboback system.
If you have encountered this, were you able to overcome this noise and how?
Thank you
Ronald
rwhans007 is offline
Old 02-01-2006, 09:00 PM   #2 (permalink)
FamilyRide's Avatar
Re: flo-pro 4" exhaust, very loud
Installed on what?
BTW, you need to post this in Aftermarket for whichever engine you have.
BTW2, if it's a 6.0, especially a 2003, and the system eliminates the CAT, that's the problem The CAT killsmost of the obnoxious turbo whistle, and I say annoying only because it's waaaayyyyyyy too loud. I had my CAT welded back in and it sounds good!
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 02-01-2006, 09:59 PM   #3 (permalink)
I just put the XL system on my X a few weeks ago it is loud when cold but normal driving I can not tell the difference.
I like what I am seeing MPG wise but have thought about putting the cat back on.
Looks like it could be welded in a 4" pipe without going back down to the
3-1/2" just cut it on the taper and tig together.
Not sure how much restriction this would add back but it does not seem like it would be much.
What did adding the cat back do for you? Good and Bad?
Bruce
2005 X PSD Limited Mineral Grey, 4X4 Has Second row bench then Every other factory option available.
Under Construction
4x2 Lift Gate Lifts,
Tekonsha Prodigy
Ford 30MM Rear Bar
Catch All Linners
750 W Inverter
06 Chrome Package Grill,bumpers and hooks. After an encounter with a Honda, (She got the ticket)
2005 Ex and Specs and Pictures of 2002 X
Bruce1954 is offline
Old 02-01-2006, 10:20 PM   #4 (permalink)
MotionMan's Avatar
You know, as much as I want the power of a 4" turbo back I am affraid of the noise. The turbo and exhaust resonaite inside these where-as a pick up is open and the exhaust sound is not so bad, the turbo would be the same I assume. I know this is the next step in performance and I do have to do it, I just have to have the same dbs or maybe a little more but not a vibrating box.
Some people are like Slinkys. They are good for nothing but still put a smile on your face when you push them down a flight of stairs. 2003 X Limited Ultimate, Mineral Grey Metalic. DVD, Limited Slip, Badged, Cab Lights, Magnaflow, Thule Rack, 3" Lift, T Prodigy, Air Bags, Edge Programer, XM Radio, Extreme sound system. 315/70/17s on AR Chrome/Aluminium.http://community.webshots.com/user/stellinm
MotionMan is offline
Old 02-02-2006, 09:37 PM   #5 (permalink)
FamilyRide's Avatar
Bruce,
I had the CAT welded in when the system was installed. And you're right, they cut it at 4" and welded it to the 4" pipe. It's not perfect, but the alt. was no CAT and I wasn't ready for that. I've been curious what it would sound like, but Magnaflow won't sell any parts to the system anymore so I can replace that section of pipe to test it. I may take out the muffler to see what's that's like. Most reports are that it won't sound any different, until I get on it. Who knows....
MM,
Mine sounds pretty good, better with some miles on it, but unless you know it has aftermarket exhaust, you wouldn't know it. I cna't even hear anything from the inside, but from the outside I was surprised how it sounded.
Old 02-11-2006, 11:25 PM   #6 (permalink)
MBRP makes a muffler and resonator that will fit the 4" you have now and they could knock down some of the annoying drone or noise that you have. The resonators are like small mufflers and could be the direction you might want to look at first. Just a thought!
Horsepower Upgrades offers the industry first and only <font color="red">30 Day Price Guarantee!</font>
Ford, Dodge, GM, Hummer, Jeep, VW, Mercedes, Audi, BMW, Mini Cooper, Mazda, Porsche, Motor Homes, International, Agriculture Equipment diesel and gas performance products and more. 1-888-882-0003 / www.horsepowerupgrades.com
HP_Upgrades is offline
Old 02-12-2006, 05:08 PM   #7 (permalink)
Ronald007,
All theirs have a NO Packing muffler, basically just a hollow core can, that's what's making it so loud. Get yourself a good muffler like an MBRP that's packed with a ceramic blanket and stainless steel wool and you'll be OK. Call us if you have any questions etc.
Mark @ DPPI
DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM GUARANTEED PRICES DISTRIBUTOR of MBRP & AFE EXHAUST, EDGE PRODUCTS, SMARTY, AUTO METER, ISSPRO, & DiPRICOL GAUGES, SUPERCHIPS, PREDATOR by DIABLO, AFE FILTERS & INTAKES, PML TRANNY PANS & DIFF COVERS, ARP, FLUIDAMPR, POWERSLOT & HAWK, TS PERFORMANCE, BULLY DOG, AIR DOG FUEL SYSTEMS, BOSCH, SUNCOAST, STANADYNE AND MORE.
Mark Craig is offline
Old 04-24-2006, 10:59 AM   #8 (permalink)
Ronald007,
Mark @ DPPI
Hi mark,
I received the MRBP resonator and glass packed muffler from your store. It looks like I have no pulling power with the muffler on. When I take it back off, it seems fine. Am I having too much back pressure?
Old 04-24-2006, 11:41 AM   #9 (permalink)
Ronald007,
The resonator or a muffler that has a 4 inch straight thru core will not make enough back pressure to change any operation of the engine.
You've got some other issue going on becides the resonator.
Mark @ DPPI
» Sponsor Links
»Garage Storage and Cabinets
